Question about Toshiba A105-S4054 Notebook
A105-S4054 Model Number fot changed automatically & common module terminated problem
Hi I use A105-S4054, i ave used 2 times recovery DVD given by Toshiba, right now when i tried to use that it say not compact able when check the model number now it is A100. How to fix this & also i facing common module terminated while am trying to open Toshiba HW Setup please tell me the setup how to fix this. my mail id j.sriram.82@gmail.com
  • 93 Answers
Hi, according to what you indicate in 2 occasions utilizastes the DVDs given for toshiba and they operated correctly and already not, it is possible that your equipment has gone to guarantee and they have replaced the card mother and they forgot to do the DMI to him in order that it recognizes the discs of recovery, they can do alone it in an ASP, for what I recommend you go to the nearby.
Posted on Jan 10, 2009
I have an older toshiba laptop and i want to reset it to factory defaults because it used to be my sisters and now its mine. help?
try this
Hard Disk Drive Recovery using the recovery partition
You have the options of recovering your system using the Hard
Drive Recovery partition
to the factory-set default, or recovering
just your C: drive and leaving other partitions (for example, a D:
drive) intact, or changing the size of your C: drive and then
recovering it.
To recover your hard disk drive using the utilities stored on your
computer's HDD:
1 Make sure the computer is turned off.
2 Press and hold the 0 (zero) key on your keyboard while
powering on the computer. When the computer powers on, the
Toshiba Recovery Wizard screen displays.
3 Select one of the options, and then click Next. The options are:
? Recovery of Factory Default Software
? Erase the hard disk
1 On the Toshiba Recovery Wizard screen, select Recovery of
Factory Default Software, and then click Next.
The Recovery of Factory Default Software screen appears.
(Sample Image) Recovery of Factory Default Software screen
2 Select Recover to out-of-box-state, and then click Next.
A confirmation message displays reminding you that all data
will be lost during the recovery process. Be sure to save your
work to external media before proceeding.
3 Click Next to begin the recovery.
Once complete, a message displays that the HDD has been
recovered.
4 Press any key on the keyboard to restart the computer.
To recover only your C: drive:
1 On the Toshiba Recovery Wizard Screen, select Recovery of
2 Select Recover without changing the hard drive partitions.
A confirmation message appears, reminding you that all
information on the C: drive will be lost during the recovery
process. Be sure you have saved your work to external media
before proceeding.
3 Click Next to begin the restoration.
recovered.
4 Press any key on your keyboard to restart the computer.
Jun 12, 2011 | Toshiba A105-S4054 Notebook
Need to restore to factory settings
Hi charles1700m,
There are 2 options if you want to Restore the laptop to its factory settings. You can either use the Recovery Disk if you have one or use the Hard Disk Recover. I've posted here the guide on how to do a Hard Disk Recovery. Just follow the instructions on the manual.
Manual 1 and Manual 2
Rate me if this helps so that I can help others. Thanks for using Fixya.
Feb 04, 2011 | Toshiba A105-S4054 Notebook
Need diagram for compressor terminals .need to know what is common,start and run terminal
As you are looking at the terminals
The nine 'o clock terminal is the common
The 2 'o clock terminal is the run,
The four 'o clock terminal is the start
http://www.lodgingac.carrier.com/Files/LodgingAC/Global/US-en/52CP_Wiring_Diagrams_52cp-2w.pdf
I hope that this will help you to solve your problem!
Thanks for using Fixya!!
Heatman101
Dec 18, 2009 | Migali Refrigerators
DRIVER FOR WIRELESS WINDOW XP
http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/home.jsp?nav=Download
Nov 25, 2009 | Toshiba Satellite A105 Notebook
Black screen, will not load up?
Is the battery charged? Might be a defective charger.
Jul 18, 2009 | Toshiba A105-S4054 Notebook
Installing windows XP - Error encountered
Can you reboot and get into windows or is now corrupt?
What do you mean by 'uninstalled XP'??
You cant uninstall it unless you format the drive, in which case the recovery discs are now probably useless as they rely on a folder on the HDD called i386.
Recovery discs normally dont have the OS on them, they rely on the I386 folder to gather info about the computer and then restores it to the state when it was new.
If you can acess the system, reboot and go into the bios and change the boot sequence to CD, then insert the first recovery disc. then save the settings and the computer will reboot and start the recovery process again, this should clear up the error.
If it does not it will be because the i386 folder is missing in which case you can either explore the recovery discs for it or you will have to buy a copy of Windows XP.
Aug 11, 2008 | Toshiba A105-S4054 Notebook
Adding RAM
no there is not a order for that but you can try one by one like that you'll see if that is detected or not so if any one is not detected or does what it was on the first time may be there is a bad one so try it
Jan 05, 2008 | Toshiba A105-S4054 Notebook
Toshiba a105-s4054
Try pressing the following 2 keys simultaneously- Fn & F5. Do this only once. If this doesn't fix the problem, be sure to hit both of them simultaneously 1 more time to set the machine back in it's original state. What you are doing is switching between the internal monitor and an external monitor, should you ever have a reason to attach one.
R-
Nov 07, 2007 | Toshiba A105-S4054 Notebook
Laptop LCD mounting bracket broken.
try ebay search for toshiba Satellite A105-S361 "for parts only". you may get one for less than $10.00.
Sep 16, 2007 | Toshiba A105-S4054 Notebook
Satellite A105 S4054 display problem
Hi, you may need tore-install the video driver. May have been a windows update which messed with the driver.. just a guess. The part of only a portion of the screen being shown indicates that the settings in the bios may have been changed. If that's the case, get back tome. Otherwise, the video card may be crapping out on it. I've had 2 or 3 of these units do that. Good luck Harvester3
Aug 18, 2007 | Toshiba Satellite A105 Notebook
Toshiba A105-S4054 Notebook Logo
356 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
