Question about Cuisinart WM-SW2 Sandwich Maker
Its not heating. red light is not coming. as you switch on we are getting the green light straight away without heating.
  • vlad chaso Nov 01, 2012
    where to get safety thermostat?
Replace safety thermostat.
Posted on Nov 01, 2012
Light on beko lcd tv goes from red to green and back to red without coming on
Main board fault. Shorted component/s on this board. Contact any service technician. This is not a user repairable fault. Gopakumar Gopalan Google
Mar 05, 2014 | Beko 17WLB450S 17 in. LCD TV
I have the sony bravia KDF E50 A12U The tv went pop and wont work. On switching on the tv, the light stays green, then goes over to 3 red light flash then green. What is this and is it easily fixed?
  • This model had a problem with the lamp door warping from the heat.
Remove the door and hold it edgewise to see if warped..
There is a peg on the back of the door that engages a lever when the door is closed---if door warped set will not come on.
A simple way to confirm or deny this is to use something not metal to with the door removed ENGAGE and hold the lever forward.
DO NOT IF THE THIS SET COMES ON LOOK AT THE LIGHT OR OPERATE IT FOR PROLONGED PERIODS OF TIME.
Do not put the outer shield cover back on without the door as heat can get it also.
If set comes on with door lever engaged you need to replace the door--widely available on the internet and or from Sony---not a bad idea to buy a spare one.
let me know what happens.
Mar 15, 2012 | Sony KDF-E50A12U 50" LCD HDTV
Ok so i'm driving hit a straight away gun it get up to 80pmh... and it just shuts off.... i hear the fan so i think well it must have over heat?? wait a bit try to turn it on nothing the fule pump doesn't...
FUSES? Ignition switch? We need more info - what are you doing to try to start it? ECM could be bad - does the red light turn on when you cycle the key?
Feb 05, 2011 | 2004 Buell Lightning XB12S
The waffle maker has two lights. A red one which indicates te power is on and a green one which lights up when it reaches the desired heat (and the thermostat circuit opens and the device stops heating...
There seems to be a problem with your thermostat or temp cutout switch if the machine is getting exceptionally hot. This could explain the green light not coming on.
Jan 26, 2011 | Krups FDK2 Waffle Maker
On the charger it will go red green red green forever and i halve to charge it a week to go ten minuits
hi my son has not used the scooter for a while so i went to charge it and the green light comes on the charger straight away and the scooter is not working can you tell me what the problem is?
Mar 13, 2010 | Razor E100 Electric Scooter
My ps3 switched off by its self recently and when i tried to switch it back on the power light was flashing red i pressed it once and it turned solid red then pressed it again it went green for around a...
Yes this is the YLOD (Yellow light of death) to fix it you need to stop the heat build up getting to the main chips in the motherboard to do this you should use the recommended PS3 Repair guide.
It is created by the same person as the top selling Xbox guide>>
PS3 Repair Guide
Nov 24, 2009 | Sony Playstation 3 (PS3) Console
The fan motor doesn't come on with the central air nor if I switch the fan switch to "ON". But the fan motor comes on if I switch to heating.
This is an either - or.. thermostat or bad green wire . To find out ,go to the unit where the thermostat wires are, or the terminals strip ,and connect the red wire from the unit to the green. Or connect a jumper wire straight to the red to green terminal strip. and it should start. If does then the problem is the thermostat or the green wire so go from there!
Sep 03, 2008 | Carrier Heating & Cooling
Cuisinart WM-SW2 Sandwich Maker Logo
215 people viewed this question
Top Cuisinart Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Dale Anderson
Dale Anderson
Level 1 Expert
Tom Chichester
Are you a Cuisinart Kitchen Appliances - Other Expert? Answer questions, earn points and help others
