With these pool cleaners, there are several things you will want to try. Check the filter screen in the in line filter and the skimmer basket, pump basket, and pool filter. Clean any if necessary. Make sure that all hoses, connections, and swivels for leaks that could cause loss of water pressure. Make sure that your wheel RPM is correct. Make sure that your thrust jets are positioned correctly and that you have proper waterflow.
Google found this:
it is behind the front passenger wheel fender
The battery is buried within the front section of the passenger side front fender.
Disconnect the neg battery cable close to the firewall.
Remove the bolts holding the air cleaner assembly in place.
(Removing the air feed tube from the air cleaner assembly helps)
Once this is removed, you should be able to see the battery hold-down bolts.
Remove these and remove the hold-down assembly.
If you are removing the battery, remove the 1st battery cable.
Depending upon what battery you have, you may be able to slide the battery back toward the wheel and disconnect the 2nd cable.
Jack the vehicle up, put on jack stands and remove the passenger side wheel.
On the front side of the wheel well there is an access panel that needs to be removed in order to access the battery. There are 6-8 1/4" screws to remove. Then manipulate the cover until you can remove it, bending it slightly.
If you were unable to disconnect the 2nd battery cable earlier, you can now move the battery further towards the rear of the car. Remove the 2nd cable clamp from under the hood.
Slide the battery all the way out. It is heavy!
Reverse the instructions for reassembly.
Hope this helps.....
Read more: http://wiki.answers.com/Q/Where_is_the_battery_on_a_1998-2004_Chrysler_Concorde#ixzz28j7Sd3O0
