Question about Whirlpool AD50USL Dehumidifier
Dehumdifier not collecting water. - Whirlpool AD50USL Dehumidifier
    Sergeant:
  • 168 Answers
It may be that the humidity level or temperature in the room where your dehumidifier is located is too low.
When the outdoor temperature is below 50 F, the indoor air will be dry even when the air inside is warm, therefore when it's cold outside the dehumidifier may collect little or no water.
Air conditioners will also remove moisture from the room, even if it's hot and humid outside, resulting in little or no moisture collecting in the dehumidifier bucket.
Some dehumidifiers have a deicer which turns off the compressor but keeps the fan running. When the compressor is off, moisture is not removed from the air. The deicer turns off the compressor when the room temperature is cold.
Some dehumidifiers do not have a deicer. If the room temperature is low enough, ice may form on the evaporator coil. The ice prevents the dehumidifier from removing and collecting water. If ice forms on coils, unplug dehumidifier until ice melts and room temperature rises.
The filter (on some models) may be dirty or clogged. If so, clean the filter. For instructions on cleaning the filter.
I hope this help to solve, if this answer solve it, remember to rate it. Good luck.
Posted on Oct 01, 2010
Dehumidifier runs without putting water in bucket
Posted on Mar 18, 2011
I HAVE A WHIRLPOOL 25 Pint Dehumidifier model AD25BBL2 serial starts with QM. Anyway it Seems to work ok as water does collect in water tray. About every 30 minutes it makes a single KNOCK NOISE. Unsu
Hello, Consumer. We're sorry to hear about the difficulty with your dehumidifier. Below are links to our Use & Care guides, Parts Diagrams, Troubleshooting information and the Service are of our website. We hope this helps! http://bit.ly/112Lu7q
May 21, 2014 | Whirlpool 25-Pint Dehumidifier
Dehumdifier runs but there is never no water in the bucket and our basement is very damp from all the humidy and the floor is sweeting there should be water in the bucket
There are many reasons why a dehumidifier willnot work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrongwith their dehumidifier
Dehumidifier is running but no water is in bucket
heatman101
Aug 07, 2011 | Haier HD308 Dehumidifier
Bad smell coming from dehumdifier from the air outlet
Lin, the air intake filter may need cleaning and the water collection bucket may have a mold and mildew buildup. Cleaning both things, may solve the smelly problem.
Jul 14, 2011 | Danby DDR607EE Dehumidifier
Have a Sunbeam DHC-20M dehumdifier (42pint) that quit running by blowing the circuit breaker. Suspect it's the capacitor, but don't know how to test it since it has probably a dozen contacts on the end. ...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
It could be the cap. but probably it is the compressor that is toast...
There can be many reasons why a dehumidifier will not work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrong with their dehumidifier
http://www.fixya.com/support/r4662409-dehumidifier_running_but_no_water_in
heatman101
Sep 03, 2010 | Sunbeam Dehumidifiers
Dehumidifier is on but nothing happens
air filter clean.
water level switch problem.
control card problem
start at these points first........
if fan is working may be compressor.
Apr 20, 2010 | Comfort-Aire BHD-501 Dehumidifier
Tank fills up but connected to hose FDL70S1
I had the same problem. It seems that you need to add another hose washer to the drain hose that connects to the dehumdifier. I wasn't able to tighten it enough by hand to keep it from leaking. BE CAREFUL ! ! The plastic connector in the dehumdifier is just that PLASTIC so don't try to overtighten with a pliers, etc... I still get a minimal amount of water in the bucket but only have to dump every 4-6 weeks, if even that.
Jul 24, 2009 | Frigidaire Dehumidifiers
Servicing a dehumidifier
Keep the filter clean and when not in use empty the water tank and store the dehumidifier in a dry environment
Jan 11, 2008 | Maytag M7DH45B2A Dehumidifier
Connecting a drain hose
Most units have a drain connection, either on the machine itself, or in the collection pail. These connections usually fit standard garden hoses.
Jul 05, 2007 | Maytag M3DH30B2A Dehumidifier
Another question
I have the same problem. I believe it is because it has a refrigerent leak. When there is little refrigerent, the begining of the coil will freeze up. I would really suggest calling the manufacturer. It is defintely something to do with this specific model
Sep 07, 2006 | Goldstar DH504EL Dehumidifier
Everything works, but does not collect water
I have the same dehumidifer - make and model. I bought it less than a year ago. It too runs fine, but now collects no water. Did you ever discover how to fix the problem?
Sep 04, 2006 | Goldstar DH504EL Dehumidifier
Whirlpool AD50USL Dehumidifier Logo
1,203 people viewed this question
Top Whirlpool Dehumidifiers Experts
Bill Long
Mike Squire
Terry Schneider
Are you a Whirlpool Dehumidifier Expert? Answer questions, earn points and help others
