Question about Linksys Wireless-G WRT54G Router
Want to remove code to modem - Linksys Wireless-G WRT54G Router
    President:
  • 566 Answers
Press the reset button in the back of the router for 30 seconds with a sharp object (an unbent clip for instance) to reset the modem to factory settings. This will remove the router password and any protection settings. For detailed instructions with images, check this FAQ: Resetting the Linksys Router to Factory Default to remove .
Next, open a web browser window on the connected computer and type http://192.168.1.1 into the address bar and press enter.
A window will pop up prompting you for a username and password to access the configuration page for your router. Enter admin for both the username and password. enter the new settings.
Check this FAQ: Accessing the Router's Web-Based Setup Page and the other mentioned at the itsend.
You can get more FAQS and support for your router here: http://homesupport.cisco.com/en-us/wireless/lbc/WRT54G
Posted on Oct 01, 2010
Modem Unlock code
What's your Modem Brand and model?
you can get the unlock code for your modem from MobileUnlockSolutions.com here they render unlock code for Huawei, Alcatel modems. Using this you can Remove the Network restriction from your modem permanently.
Oct 22, 2014 | Cell Phones
What is the unlcok code for a huawai valiant
The unlock code for every individual mobile phone is unique and based upon the IMEI number of the device. You can visit ClassicUnlocking.com submit the required details and get the accurate unlock code at affordable cost. Good luck.
..............UNLOCKING INSTRUCTIONS..............
f your Huawei Device is a mobile phone:
1.Switch on your Huawei Phone using another networks SIM card.
2.Your phone should ask for an unlock code(NCK Code).
3. Enter the unlock code we sent you.
If your Huawei Device is an USB modem, please follow these instructions:
If your modem software asked for an unlock code when you tried using another network's SIM card, directly enter the unlock code we sent you when prompted by the software.
Otherwise try one of the following
Method 1:
This method requires your PC to have a software called Hyperterminal which can be found on the Start Menu in Windows XP, 2003 and other older versions of Windows:
Start - > Programs -> Accessories - > Communications - > Hyperterminal
1.Remove all other modems, printers and other devices connected to your PC other than your monitor, keypad and mouse.
2.Start your pc, connect your USB modem and open Hyperterminal.
3.Enter any name and select any icon and click OK to continue.
4.Set Connect using to your modem port, Huawei Mobile Connect - 3G Modem or the right COM port.
5.In the properties window that opens, without changing any values, click OK to continue.
6.Type the following command(replace the word UnlockCode with the unlock code we sent you):
AT^CARDLOCK=UnlockCode
and press enter.
7.Your modem should now be unlocked. Close Hyperterminal, disconnect your modem and connect it again.
Method 2:
Use this method if Method 1 does not work or if you are not able to follow method 1.
If your PC does not have Hyperterminal or if your using Windows Vista or Windows 7 you can use the following method.
1.Download our Modem Communicator Application. This application has been scanned by Mcafee and contains no virus. For your safety, please scan the application again after you download it.
2.Switch off your PC, remove all other modems, printers and other devices connected to your PC except your monitor, keypad and mouse.
3.Start your pc, connect your USB modem and open the application you downloaded(mc.exe).
4.Click on the Check for Ports button and wait for the response.
5.Click on the Check for Modems button and wait for a response.
6.Click on the Send AT Command button and make sure you get the response "OK".
7.In the text-box next to the Send User Command button, type the following command(replace the word UnlockCode with the unlock code we sent you):
8.Click on the Send User Command button.
9.Your modem should now be unlocked. Close the application(Modem Communicator), disconnect your modem and connect it again.
Jul 29, 2014 | Huawei MetroPCS M735
PLEASE help unlock my device E5331s-2 IMEI::860667017553111
Hi. You can unlock your Huawei E5331S-2 safer and easier using unlock code. You can get the unlock code for a Huawei E5331S-2 from SimpleUnlocking.com at affordable cost.
If your Huawei Device is a mobile phone:
Method 1:
and press enter.
Method 2:
Jul 14, 2014 | Huawei Unlocked E5331 Wireless Hspa 21m...
Unlock huawei E353Tu-6 mobem
HUAWEI E353 TU-6 and Huawei E353 are same modem...You can Unlock it using the Unlock Code...Visit the site Prounlocking.com/huawei-modem-unlocking-service/rs8wp10/ get the Unlocking service for your HUAWEI modem and unlock it from service provider lock.Follow the instructions below and unlock it step by step...
Method 1:
and press enter.
Method 2:
6.Click on the Send AT Command button and make sure you get the response"OK".
Oct 12, 2012 | T-Mobile Huawei T-Mobile Webconnect USB...
I need the sim unlock pin code so i can switch over to Tmobile without getting a new phone.
Hi, You can get the unlock code for a Huawei U8652 Fusion from www.unlocking4u.com/huawei-fusion-u8652/rs6wp9/ at affordable cost.
Here are the steps for unlocking a Huawei U8652 Fusion,
Method 1:
and press enter.
Method 2:
Sep 22, 2012 | Huawei U8652 Fusion Blue/blackandroid In...
[How-To] Unlock Airtel DataCard Micromax MMX 610U With Universal ...
Hi gulzar_ah228,
If you wanted to insert any other operator sim card on your Micromax MMX 610U Airtel USB datacard you really need to unlock it. If you wanted to unlock the modem you will be needing a Software and guide to do the process. Please see the steps below on how to unlock Micromax MMX 610U USB Datacard:
1. First download the software here:
Universal Master Code Generator
2. After downloading install the software. Now you need to remove the Airtel SIM card from the modem.
3. Insert a different Operator Sim card.
4. Open the Universal Master Code Generator.
5. Please enter the Micromax MMX 610U IMEI number. You can locate the number on the card.
6. Once you already entered the security code, press calculate. On the left side you will get 2 codes the unlock code and flash code.
7. Connect the modem to your PC, wait until a screen pops up, it will requires you to enter the unlock code.
--> please use the unlock code that was generated in step 6.
Hope it helps.
Thank you for using FixYa.
Feb 17, 2011 | U.S. Robotics (SPORTSTER0484)...
Sir i m kuntal,i have purchased airtel micromax mmx 200g detacard.it is fixed with airtel network.i want to use other sim card in it,but it does not support any other sim card except airtel sim...
Remove the SIM from Modem then insert any other Operators Sim Card.2.
Visit http://a-zgsm.com/huawei.php
and enter Your Microimax MMX 610U IMEI number (written on the Card itself). Enter the Security code then press Calculate, You will get 2 Codes Unlock Code and Flash Code.Now connect your Modem to PC, a Screen will be put up to enter the Unlock code, Enter the Unlock Code generated above and you are Done. Your Card is Unlocked....
Nov 26, 2010 | Computers & Internet
Code 10 problem showing in on modem(device manager)
that is a problem with your DIAL-up modem which is the old style, use your phone and dialin type of internet connection. so basically if you're on high speed you dont really need it, you can right click and disable. if the modem is in a desktop in a pci slot, you can actually just remove it all together. code 10 means the device wont start either due to hardware failure or bad drivers...but again, its a dialup modem and oyu're on highspeed so you dont even need it.
Apr 26, 2009 | Arris SM56 (SM-56-PCI) Modem
Error code 680 when I try to connect to my server
The error 680 means There is no dial tone. The modem is not detecting a dial tone There are many possible causes of a No Dial Tone Error. 1.Check cable is correctly inserted into back of modem and phone socket 2.Check properties of connection, make sure correct modem is being used 3.Disable "wait for dialtone before dialing" in My Computer > Dial Up Networking > Properties of Connectoid > Configure > Connection > remove checkmark under call preferences 4.Try removing fax machines or other devices connected to the line 5.Make sure no one is using the telephone when trying to connect
Jul 07, 2007 | Actiontec (GT701) Modem
Linksys Wireless-G WRT54G Router Logo
241 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
