Question about Maytag Neptune MAH5500B Front Load Washer
Got od message and tried to adjust latch on door and now it won't shut
Maytag Neptune MAH5500BWW received a OD message.  Read a lot on web and they suggested using flat head screw drive on latch.  Now the latch is down and the door won't close.  Any ideas
Www.applianceaid.com/neptune.html
Posted on Jun 03, 2008
What does the code od mean?
The "od" code appears when you must open the washer door. The Maytag Neptune washer requires that you open the door between cycles.
Read more: Maytag Neptune Washer Error Codes ' eHow.com http://www.ehow.com/list_7170826_maytag-neptune-washer-error-codes.html#ixzz2GZKry68n
Dec 30, 2012 | Maytag Neptune MAH5500B Front Load Washer
Won't start/"od" displayed
Yes, OD is a open door error code. You may need a new door latch assembly. pn 22002262.
Jul 23, 2010 | Maytag Neptune MAH5500B Front Load Washer
I have a maytag neptune tl that comes up with an error code "od" Has anyone any idea what this is and how to fix it? Thanx Bruce
Open Door Error. - Problem with the door latch mechanism or sensor. For the od error, open the door and jiggle the locks.
It's possible that soap has gotten there and is making them not knock whatever it is they need to knock to register that the door has opened.
You might need something fairly long and thin such as jeweler's screw drivers
OD :The door has not been opened after two complete wash cycles. Door switch was not seen open since the last two final spins.
Here is a shop manual for your model.
Try to run the diagnostic mode, see manual. Or unplug for 5 minutes. Remember if this code reappears you may have a stuck or bad door latch.
if after running a diagnostic, and th latch is still reporting an error - it will need to be replaced.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Oct 04, 2009 | Maytag Neptune FAV6800AW Top Load Washer
"od" on screen
OD = Open Door.
Your door latch senssor has failed - or the door is not shut completely.
For the od error, open the door and jiggle the locks. It's possible that soap has gotten there and is making them not knock whatever it is they need to knock to register that the door has opened. You might need something fairly long and thin such as jeweler's screwdrivers.
Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
May 14, 2009 | Maytag Neptune MAH5500B Front Load Washer
It stands for 'open door'. The control board didn't see that you've opened the door since the last cycle and won't start another cycle until it see's that. Probably a bad switch in the door latch assembly. If you can verify a bad switch, it's best to replace the whole latch assembly. It also may be a shorted wire, trace the wiring back from the latch to the board and check for any signs of damage. It's possible, but very unlikely, that the control board is bad. If everything else checks out it's the board.
Jul 17, 2008 | Maytag Neptune MAH5500B Front Load Washer
Maytag Neptune TL
Puy knife inserted at the outside cornes opens it up and you can play arround with them with you fingers try WD-40 to cur the sticky detergent residue and make sure they are connected. are you sure it didn't say OP?
Jan 16, 2008 | Maytag Neptune FAV6800AW Top Load Washer
"od" = Door Open. Most likely a relay or wax motor in the door latch assy.
Jan 09, 2008 | Maytag Neptune FAV6800AW Top Load Washer
Maytag Neptune MAH5500B Front Load Washer Logo
330 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
