Question about Hotpoint Refrigerators
Plugged in new hot point refrigator and waited 24 hours to adjust cooling thermostat. the refrigator is not cooling after the initial 24 hours and an additional ten hours.
    Guru:
  • 1,524 Answers
Contact the place where purchased. Unit is under warranty.
Posted on Oct 01, 2010
How can I disable the programmable function and just use as a conventional thermostat
5. Temperature Adjustment
Extended Hold (Vacation) Mode
1. Press the HOLD button to bypass the program schedule. The current set point temperature will be held either permanently or for 24 hours, depending on the setting selection made in section 4.
2q==
2. Press the
HOLD button again to return the thermostat to the normal program operation.
3. The hold period will last until the hold is released as in step number 2 above, or is limited to 24 ours if the default was changed in the User Options Settings (see section 4).
4.Programming User Settings
Setting the Extended Hold Time (see also section 6)
The default setting is Long (indefinite) Hold. If the HOLD feature is activated, the current set point will be held until HOLD is released.
1. In normal operating mode, press and hold the
RETURN button for 4 seconds. Press RETURN again to skip past differential setting. The display will show "HOLD LG", where LG is indefinite hold.
z
2. Press the or button to change the Extended Hold time from indefinite (LG) to 24 hours (SH).
3. Press the
RETURN button again to set the Filter Check Monitor or wait 30 seconds for the thermostat to return to the normal mode.
6.Additional Operation Features
Resetting the Thermostat
The Reset feature allows the user to completely reset the thermostat to register new manual switch settings.
1. To erase all entered programs, current time of day, day of week and other user settings, gently press the
RESET button using a paper clip or a small pencil tip.
2. This will return all thermostat settings to their default values and register all new manual switch settings for proper operation (incl.
Extended Hold = Indefinite).
Dec 28, 2014 | Proselect PSTS21P52 Programmable 2 Stage...
Brand new mini fridge was on it's side before being set up. Plugged in too soon. Now it won't start cooling. Are we out of luck?
It could be that liquid coolant got into the low-pressure part of the cooling system when it was on its side, and is preventing the expansion valve from doing its job converting high-pressure liquid coolant to gas. My recommendation is to unplug it, wait the 24 hours, and plug it back in. Excess fluid should have drained to the bottom of the cooling system by then, and normal cooling can begin.
Dec 19, 2013 | Black & Decker Food Processors
Dometic refrigetor won,t cool
Have you adjusted the temperature setting? Try adjusting it to a cooler setting and wait about 24 hours to see if it is getting cool. If not, it may need a new thermostat.
Aug 22, 2013 | Refrigerators
The 1.7 cubic foot Chefmate refrigerator will not cool. I"ve left it plugged in for 24 hours and it's still not cooling. The refrigerator is only 2 yrs. old. Thanks
Hello ,
Do you hear the compressor come on? If yes , Wait a few minutes then feel the condenser coils at different spots. It should be hot to the touch .Also , there should be gurgling coming from inside freezer section.If neither, there's no refrigerant .
If compressor does not come on, listen for click as if it wants to start. Click means thermostat ok but start relay or capacitor problem or seized compressor (bad). No clicking could be thermostat.
Best procedure here is to use a test cord to see if compressor starts manually.
Was this helpful?
Aug 16, 2011 | Refrigerators
My refrigerator freeze work gest find but the bottom part of the refrig is not cooling?
The defrost thermostat is not functioning as it should.The problem is with defrost.
Try manual defrost reset procedure first : ----
First unplug the unit from main power outlet. Then empty whole unit completely. Then keep both the doors open. Wait for 24 hours. All the ice collected on the coils and in the freezer section will get melted. Clean the water from the sections. Then Connect the power cord of the unit to main power outlet after 24 hours/.Then set the temperature to normal in both fridge and freezer section. It will take near to 4 hours to get run in its proper cooling cycle. Then check, if the problem returns again. If the same problem occurs then it's defrost problem. ---------- . It's starting the cooling procedure, and then while defrosting, it's not working. The defrost assembly consists of three main parts. The defrost thermostat, the defrost heater and defrost board. Any of the one is not functioning. When thermostat sense the maximum cooling, it triggers the defrost heater to start heating and this defrosts the ice collected on the coils and the system works. Both thermostat and heater are controlled by defrost board. First the thermostat and defrost heater to be checked, if both check ok by meter and visually, then its defrost board causing the problem. You can get required parts from online sites like: --- www.repairclinic.com or from searspartsdirect online site.This should help.Thanks.Helpmech.
Apr 06, 2011 | Refrigerators
GE TBF 17DB 17,2 cu.ft. refrigerator/freezer runs continuously.
Set both controls to their middle settings. Put a glass of water in the frig with a thermometer in it and check the temperature in 48 hours. I is normal for the newer appliances to be on longer than off. Power consumption is highest during start up and it is more efficient to start less often and run longer. When adjusting controls ONLY change one by one number and wait 24 hours before making another change.
Eric
Apr 18, 2010 | Refrigerators
Can't seem to adjust new refrig. thermostat
turn dial to warmest setting. be patient. wait two hours turn dial up another notch. be patient, wait one hour.ect until you get to setting 5 or 6. do not put food into frige until you have run it at least twelve hours.
Sep 11, 2009 | Refrigerators
Freezer temp
Hello I can help with this problem , You can set it to the factory setting thats normaly in the middle , wait 24 hours for temps to equalize and check temp in freezer with an accurate thermometer it should be -10 to +10 deg. Far. to adjust temp move dial up or down only one digit at a time and wait 24 hours on each adjustment until its at a correct temp.
Dec 30, 2008 | Kenmore 53612 / 53614 Side by Side...
Pluged in a new one and it does not seem to be cooling off
did you tilt it prior to plugging it in you are supposed to wait 12 to 24 hours to plug them in if theyve been tilted at any time during transport.
Dec 25, 2008 | Frigidaire FRS3R5EMB Side by Side...
Refridgerator with bottom freezer. Fridge is not cooling at all, but bottom freezer is just fine. What do I do
With almost all refrigerators, all the cooling takes place in the freezer and a fan then blows some of the cooled air into the refrigerator section to cool it. Look for a non functioning fan in the freezer, frost or ice build up in air ducts leading from freezer into refrig section, and make sure controls are not set to the coldest freezer setting. (that keeps most of the cold air in the freezer)
Sep 01, 2008 | Maytag Refrigerators
Open Questions:
Refrigerators Logo
55 people viewed this question
Top Hotpoint Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Sal De
Are you a Hotpoint Refrigerator Expert? Answer questions, earn points and help others
