Why does my wifi on my i pod have full signal strength, but then doesnt connect.
  • 823 Answers
Maybe you need to turn on home networking in your desktop pc and allow other devices to connect to the internet through it. If you have not turned on home networking or set up your wireless connection access in your desktop pc then go to the ICON's in the control panel and follow the instructions.
Set up wireless first by going to the control panel and looking for the wireless set up wizard. Then follow the instructions.
Then do the same for home networking. Look for the Home networking Icon in the control panel and choose set up new network and follow the prompts.
Posted on Oct 01, 2010
Wifi network not working in some rooms
Change the position of the WiFi router, because there are things like duct work, metal studs and electrical wiring concealed in the walls that can and will have an effect on WiFi signal strength.
Oct 05, 2015 | Linksys Computers & Internet
Wifi connection problem
Need To Double Check Password And Connection Info. One Error Sets The Whole Thing Off As Wrong.
Feb 02, 2014 | Noria 7 Android 4.2 Tablet - White
Proline laptop w24/250cu
is there an ICON in your taskbar for the signal strength of your router if so right click on it should bring up the wifi network so you can turn it on.
Aug 26, 2013 | Computers & Internet
Cant get wifi unless I am a couple of inches from router. All other wifi devices work perfectly. I even downloaded the latest driver directly from Intel and problem still exists.
Having a wireless Internet signal in your home allows multiple devices to use the same Internet connection without having to run lengths of Ethernet cable to each device. Given that the wireless network is transmitted over the air, the consistency of your Internet connection depends on the strength of the wireless signal. If wireless signal strength is not strong enough to give you a consistent Internet connection, there are a few simple steps for finding the problem and improving your signal strength.
Reset all devices. The majority of Internet issues, including poor wireless signal strength, are very often solved by a simple power cycle of all the devices in the network. Locate the power cords of both your modem and your wireless router and remove them (if you use a modem/router combination, simply unplug the power to that device). Leave them unplugged for a full 30 seconds, plug them back in and restart your computer. When your computer fully reboots, check your wireless signal strength to see if it has improved. If it has not, further troubleshooting is required. Move your computer closer to your router, or your router closer to your computer. Wireless routers do not have unlimited range. One reason your computer may be getting a weak signal strength from your wireless network could be because your computer is simply outside of the router's range. Typically, ISPs (Internet Service Providers) will install your modem in one specific location in the house and the modem will not work at other locations, so moving the modem or modem/router combination may not be a possibility. If this is the case, you may need to move the computer to a location that is within the range of the wireless router's broadcast. If you still get poor signal strength, your router may be experiencing a malfunction. Contact the technical support department of your router manufacturer. Router malfunctions often are not the result of a bad or broken router, but of something much simpler, such as the router's needing a firmware upgrade or an incorrect setting on the router's internal setup. If your router manufacturer is unable to improve your wireless signal strength, it may be time to purchase a new router. Purchase a new router. Wireless routers are priced in part based on how widely their wireless signal broadcasts (in other words, the more expensive the router you buy, the larger a wireless signal the router will broadcast). Included in the packaging of each wireless router is the approximated range, in square footage, of that router's wireless network. A good rule of thumb is to know the square footage of your house and buy a router that can accommodate that square footage. That way, as long as the router is functioning properly, you will have strong wireless signal strength throughout your entire home.
Mar 01, 2013 | Samsung 19628 NP300V5A-A0AUS NP300V5AI
Poor signal with WiFi on my zeepad
Reset all devices. The majority of Internet issues, including poor wireless signal strength, are very often solved by a simple power cycle of all the devices in the network. Locate the power cords of both your modem and your wireless router and remove them (if you use a modem/router combination, simply unplug the power to that device). Leave them unplugged for a full 30 seconds, plug them back in and restart your computer. When your computer fully reboots, check your wireless signal strength to see if it has improved. If it has not, further troubleshooting is required. Move your computer closer to your router, or your router closer to your computer. Wireless routers do not have unlimited range. One reason your computer may be getting a weak signal strength from your wireless network could be because your computer is simply outside of the router's range. Typically, ISPs (Internet Service Providers) will install your modem in one specific location in the house and the modem will not work at other locations, so moving the modem or modem/router combination may not be a possibility. If this is the case, you may need to move the computer to a location that is within the range of the wireless router's broadcast. If you still get poor signal strength, your router may be experiencing a malfunction. Contact the technical support department of your router manufacturer. Router malfunctions often are not the result of a bad or broken router, but of something much simpler, such as the router's needing a firmware upgrade or an incorrect setting on the router's internal setup. If your router manufacturer is unable to improve your wireless signal strength, it may be time to purchase a new router. Purchase a new router. Wireless routers are priced in part based on how widely their wireless signal broadcasts (in other words, the more expensive the router you buy, the larger a wireless signal the router will broadcast). Included in the packaging of each wireless router is the approximated range, in square footage, of that router's wireless network. A good rule of thumb is to know the square footage of your house and buy a router that can accommodate that square footage. That way, as long as the router is functioning properly, you will have strong wireless signal strength throughout your entire home. Hope this helps.
b>
Dec 13, 2012 | Computers & Internet
Router gives strong and weak signal in same place
If you think that your router signal is weak then you can follow the given points:
->Router positioning has an impact on the strength of a wireless signal. Brick walls and metal objects such as radiators, refrigerators and file cabinets can weaken a signal.
->Change the WiFi Channel
->Update firmware or drivers
->Reduce wireless interference
If you need any technical help on wireless router then you can reach at http://www.vtechsquad.com/
Nov 14, 2012 | Vizio Xwr100 Dual-band Hd Wireless...
Bought a 7" allfine netbook
what type of internet connection do you have at home?.
First, Try using an ethernet cable from the notebook to the router (modem)
Before doing do disable the wifi connection
To disable the wifi connection,
go to the network connections folder which you will find on your start menu or control panel
select the wifi connection right click on it and say disable
Dec 27, 2010 | Computers & Internet
Hi i have Gtalk but some of the wifi it is
It is mostly becuase of the poor wifi connectivity in those areas. Make sure you have proper signals in those areas. If you don't have proper signal strength in those areas then you can use some wifi repeaters to boost your signal strength.
Hope this might help you solve your problem Best Regards NextDoorNerd
Jul 18, 2010 | Google Talk
Wi-fi connection does not work
go to settings and wifi...look for your network and tap on it.
Join your network and if it is secure it is asking for the WEP key which is on the label of the router.
Enter that kep and it should join.
if it is truely an unsecure wifi you should be able to get right on by joining it.
You may be seeing full signal but it may be your neighbors or next door
Good Luck
Mar 10, 2009 | Apple iPod touch
Computers & Internet Logo
52 people viewed this question
David Payne
David Payne
