Question about Frigidaire ATF6000ES Front Load Washer
Can you stop washer and open door while washer is operating
    Sergeant:
    Champion:
  • 351 Answers
Yes if you hit pause or stop timer
Posted on Oct 01, 2010
Does dispencer door open during operation
Yes, it does and normally it flips open but you if there is something BLOCKING it from opening then you need to move it. If you Run the cycle and it is still full, the Release for the door may not be connected and that is why MANY stop using the door and only throw the Packets into the Dish Washer and never get them repaired...
Jan 03, 2015 | Dishwashers
Why does my washer say door open when it's closed
Hello Friend, this is Z. Thank you for allowing me to assist you!
I understand that your door indicates it is open and your washer will not operate. Try resetting your washer by either unplugging it or flipping the household circuit breaker off. It is best to wait approximately ten minutes and then turn on your washer. Select a normal cycle and verify if your washer will start. If your washer will not operate then it possibly have a faulty door lock assembly or a communication problem with the control board. At this point, I recommend contacting a professional to move forward accurately. Best regards!
Aug 08, 2014 | Frigidaire Washing Machines
Door closed but says open
Good Afternoon Mickey, thank you for allowing me to assist you!
If your washer door alarm has been triggered, it often indicates that it is open. This will stop your washer from operating. Try resetting your washer by either unplugging it or flipping the household circuit breaker to the off position. Wait approximately 2 minutes and turn on your washer. Select a normal cycle and verify if your washer will start. If your washer still does not operate, then it may possibly have a faulty door lock assembly or a communication problem with the control board. I am fairly confident that an authorized service agent will be able to restore your appliance to its normal operating condition. You can often locate a qualified service technician on the manufacturer website.
Best regards!
Jan 31, 2014 | Frigidaire Fasg7074Lw 7.0 Cu. Ft. Gas...
I load the clothes into the washing machine, I turn it on select cycle and the door locks and will NOT unlock. The door will however unlock after the cycle is finished.
Not sure if you're unable to open the door AFTER you stop the cycle. That may be normal operation as a safety measure (won't open until after your cycle has completed). However, if your model DOES allow for opening the door during cycle operations then your electronic door lock may be defective.
Mar 08, 2011 | LG WM-2277HW Front Load Washer
What does error code F26 mean? The washer will fill with water, work for about 5 minutes and then post error F26 and stop working. Where do I find the error codes?
DOOR SWITCH ERROR
If the door has not been opened for 3 consecutive cycles or the door switch is open while the door is locked for more than 5 seconds.
Possible Causes/Procedure
-Door not opened during 3 consecutive cycles.
1. Open and close the door.
2. Verify CCU operation by running a Diagnostic Test or any cycle.
-Door switch open while door is locked.
1. Push the door and check if it is completely closed.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.$$$$
May 05, 2010 | Kenmore HE2 Plus Front Load Washer
Our Kenmore HE2t reads F26 and stops running half way through cycle
DOOR SWITCH ERROR
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.####
Mar 09, 2010 | Kenmore HE2 Plus Front Load Washer
Stopped operating in the spin cycle
With a heavy blanket you probably have an out-of-balance condition which doesn't let the machine spin out and drain. This would keep the door lock from opening. Try hitting the Stop button twice. This should cancel the cycle and let the door lock open after a little while. Then either redistribute the load or add some items and run a Spin and Drain cycle.
Mar 05, 2008 | Kenmore Elite 45986 Front Load Washer
Frigidaire ATF6000ES Front Load Washer Logo
13 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
