Question about Microsoft Xbox Console
My original Xbox started turning on and staying on by itself without touching it. Is there an easy fix or is it safe to just unplug? I hate doing that of course.
  • 27 Answers
My original also had that problem but that is why i bought a cord switch that is safer to turn off the xbox without harm to you and to the house
Posted on Oct 01, 2010
What can cause my samsung 46 inch smart tv to turn on and off
Sounds like main board fault. Contact any service technician. These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Nov 24, 2014 | Samsung LN46C550 TV
My xbox got water damage, how can i fix it?
there is water in the buttons so they are contantly triggered, i suggest u get a new one or have it rebuilt.
Aug 28, 2012 | Microsoft Xbox 360 Console
I need a replacement container that holds the paper. It is broken so the door open light stays on..
a quick fix. on the bottom of the unit there is a safety switch that engages when the unit is placed on the container. it is located in a little channel on the front end opposite the power cord end. tape a paper clip or comething else into the channel so that the switch engages. do this of course with the unit unplugged. that should make the unit turn on without the original container. use an ordinary wastebasket to catch the shreddings.
good luck and be safe.
Jul 31, 2011 | Techko SH1524CP Shredder
Games will not load on xbox 360
If once you put a game in the disc tray but it is does not load, you still have the dashborad on the screen or its just says "Reading" then "Open tray". You'll need to check first that you didn't set your Xbox 360 to boot to the dashboard.
To check this turn on the Xbox 360 with no discs in the disc tray. Go to the System section then Console Settings then Start up make sure it's set to Disc not Dashborad.
If you select disc the Xbox 360 will play the disc when you turn it on. But if you select dashboard the Xbox 360 will stay on the dashboard when you turn it on.
If you did so and still not loading, try another thing. Make sure this issue isn't with this disc only. Try some other discs and DVDs if you have to make sure is it an issue with this disc specifically and by then you'll need to get another disc or it's the console itself.
You'll need also to make sure that your Xbox 360 is not overheating and it's in a well ventilated place.
Check that the date and time are set correctly. To check this go on the System section then Console Settings then Clock then Date and Time. If it's not set to the correct date and time, set them correctly.
The last step to try is to unplug the Hard Drive and try some discs without the Hard Drive attached just to test is it the Hard Drive or the Xbox 360 itself faulty. If you did so and it worked without the Hard Drive, it would be obvious that it is the Hard Drive's issue.
Take care.
Jul 17, 2010 | Microsoft Xbox 360 Console
Ps3 will not start up yellow light then red light
I think the motherboard need a reset ! the probleme look similar to the XBOX. there's a way to reset the box But use it at your own risk , as it can cause permanent damage to your systeme if not apply properly.
and don't do anything without somebody confirming the methode.
It consist in blocking all the fans with a wooden cocktail stick , turn on on box and wait till the systeme overheat then reset itself. then unplug le box , remove the sticks, replug and start the ps3 . good luck and be carefull
Feb 21, 2010 | Sony Playstation 3 (PS3) Console
"Key" issue - how to find
So you got the RROD on Christmas day, man that was a good present. The two lights (1 and 3?) usually means the system overheated and it cuts power to the CPU and GPU. If you did the bolts/washer fix, you actually do not want this to occur. You want it to stay on for 30-35 mins or so without doing the two lights (1 and 3). Usually you can do this by cooling the CPU fan and not the GPU. There is a good tutorial for the clamp fix here (http://www.llamma.com/xbox360/repair/ring_of_light_x-clamp_fix.htm). It worked for my XBOX 360.
Unfortunately, It sounds like you turned on the XBOX 360 with the DVD drive disconnected. If so, I hate to add to your headaches but your XBOX 360 is probably banned from XBOX live.
If not, there is a good tutorial for replacing your XBOX 360 drive at: http://www.360-hq.com/xbox-tutorials-61.html It also talks about rekeying the drive.
If all else fails, you might trying talking to 360 Pros (http://www.360-pros.com/%28X%281%29S%28oyqpez55tpvpar451buhwgfi%29%29/xbox-360-repair-service.aspx). I know some people who have used their repair server and if you've opened the XBOX 360, you can not use Microsoft.
Jan 01, 2010 | Microsoft Xbox 360 Console
Motorola SB5101 SURFboard Cable Modem Reboots Itself
If your modem has a reset button I would start there. If it doesnt, then you might be able to configure it manually, usually typing in 127.0.0.1(you can still access your modem even if you do not have internet) See if there is a reset button inside the settings, if not, then just keep a look out for any odd settings that might explain what it is doing. If none of this works, then you probalby have a bad cable modem, however, I would try a different CAT5 cable just to be safe, you never know, it could be a bad wire causing a short-out or something.
Jul 17, 2009 | Dell Latitude D600 Notebook
Samsung hcm4215w Convergence board problem
Use PANASONIC STK's.They are expensive,but they hold up!Safe,durable repairs require OEM or BETTER quality replacement parts.
Sep 27, 2007 | Samsung HCM4215W 42" Rear Projection...
Microsoft Xbox Console Logo
89 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
marley mcelhinney
Tre Elkins
Martin Murray
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
