Craftsman 3 gal. Air Compressor, 1.5 hp, Horizontal k Logo
Posted on Sep 30, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My craftsmen air compressor wont build pressure. How do i fix it?
Marc Powers
Level 2:
Scholar:
  • Expert 146 Answers
  • Posted on Oct 01, 2010
Marc Powers
Expert
Level 2:
Scholar:
Answers
146
Questions
0
Helped
82870
Points
284
If the unit will not build up pressure you need to remove the compressor head from the compressor and inspect both the intake and the exhaust reeds as well as the piston ting on the compressor.
Without the model number of the compressor this is about as far as I can help with.
2helpful
2answers
Craftsman air compressor model 919.16726 wont build pressure and makes a rattling sound
My compressor runs for about 5 min and shuts off.....does any one knows what could be the problem?
thanks
1helpful
I have a 5 gal, i hp craftsmen compressor, 3 years old, used once a year to blow down sprinkler system. Compressor ran up to 120 lbs upon turn on, would not cycle off. manually shut off unit and turned...
Oil free pumps do tend to blow the piston ring (not too expensive) available at searsparts.com. Remove covers to pump and manually turn crank until piston is at top and look at the condition of the cylinder neer top, If it looks scratched, order cylinder kit with piston ring. If it looks good and shiney, could be the valve plate in the head. There are reed valves that tend to break. Run pump however with covers removed and check with soapy water for air leaks and repair as needed (air leaks under the cover will prevent unit from filling). Good luck
Craftsmen air compressor #919.155730-motor runs,pump moves, but doesn't build pressure. how long does it take? could I not be waiting long enough?
Your unit should fill within 5 min. Compressor may have worn cylinder or just leaking. Easy test. Spray soapy water on all connections/fittings including drain valve and regulator while compressor is running. Repair as needed. If no leaks, remove plug from outlet, remove cover and examing cylinder. Turn crank by hand till piston is all the way up into cylinder. Examing carefully the condition of the cylinder close to top. If the cylinder is scratched or worn then pressure is leaking between piston/cylinder and will not fill tank. Replace cylinder kit available at Sears, cost under $50. Good luck with your project.
2answers
Porter cable model 2005 type 3 wont build pressure
The check valve is most likely the problem,or the compressor is bad.The check valve actually holds the air in the tank,without allowing the air to retreat backwards into the compressor.
Husky comp on 1st start builds up 75 lbs and wont restart
Check the reset button on the motor to see if it tripped. The motor may be overheating. Some motors have an internal breaker and they have to cool off before they restart. Also check the pressure switch. Move the switch back and forth ( on and off ) and listen for a click. If it doesn't click with low to no air pressure then the switch is bad.
Top Craftsman Air Tools & Compressors Experts
Steve Sweetleaf
Steve Sweetleaf
john h
Are you a Craftsman Air Tool and Compressor Expert? Answer questions, earn points and help others
