Question about Kitchen Ranges
F13 code show when we trun oven on - Kitchen Ranges
    Sergeant:
  • 168 Answers
I heard about alot owners with this, with several answer (all diferent solutions); Sears, about error code F13 on a gas range, was told to unplug the range for 30 minutes.
I think she meant 30 seconds - to reprogram the microchip, I unplugged it for 15 minutes or so, then reconnected, and it worked.
Try it and tell us news; remember to rate this answer if solve your problem. Good luck.
Posted on Sep 30, 2010
What does code F-13 indicate?
Why is my Kenmore oven giving me an F13 error code ...
www.shopyourway.com > kborders06 > Questions
The F13 fault code on this type of range indicates that the EEPROM (Electrically Erasable Programmable Read-Only Memory) on the control board is bad.
Sep 08, 2015 | Kitchen Ranges
What is error code f13?
The F13 fault code on this type of range indicates that the EEPROM (Electrically Erasable Programmable Read-Only Memory) on the control board is bad. This can be caused by a power surge or glitch through the electrical lines. You can try to reset the control board by completely unplugging the range (or shutting off the breaker) for 5 minutes. If the error code returns after plugging the range back in, then the control board for the range will need to be replaced.
Feb 05, 2015 | Thermador C301U Electric Single Oven
F13 tappan error code, what is it? tappan goes from code 12 straight to 14? there isn't a 13
the code is for the clock timer for bake and broil. The "clock board" will have to be replaced. About $120.
Dec 15, 2014 | Tappan Kitchen Ranges
F13 code
Hello friend, thank you for your post!
Based off the information you have provided your question is under an "F13" error code but you also stated that it is showing you an "F1" error. I have researched both error codes for you. "F13" usually indicates error identification, which could be an issue within your control board. "F1" typically can indicate that the range has detected an issue with the runaway temperature (overheating). Both codes could be corrected with a reset, which you can do by flipping the household circuit breaker for roughly ten minutes. If that does not correct the issue I would recommend contacting a professional. I hope this is helpful. -Matt
Aug 07, 2014 | Frigidaire Ovens
Why my oven shows f 13
your eoc is bad, electronic oven control (clock)
Apr 11, 2013 | Frigidaire FEF336BC Electric Kitchen Range
What does F13 Error mean?
Here is what the F-13 error code means and the fix for it.
F13 Internal CPU checksum errors 1. Disconnect power for 1 minute.
2. Reconnect power.
3. If failure remains, replace the touch control module
So it says the main computer control had detected a error in the touchpad control
I hope this helps,
Gene
Aug 01, 2011 | Kitchen Ranges
When I try to turn on the oven it say f13 err
Most of the F13 fault codes say it is either the Main board or a temperature sensor.
May 10, 2011 | Ovens
Error f13 on my frigidaire oven how do i fix it
The "F13" error code means "Bad EEPROM identification/Checksum error".
If reseting the power did not help then according to Frigidaire suggested corrective action the electronic oven control (aka EOC) has to be replaced.
- The part number for the EOC is AP3874704
Feb 19, 2010 | Frigidaire 30" Self-Cleaning Freestanding...
Kitchen Ranges Logo
301 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
