Hello Rory MRP, We have a Zebra 110 XiIII Plus, that is having some printing issues. To me it seems like a tension problem with the printer ribbon, because it seems that the ribbon is creasing/folding and causing there to be blank "stripes" cutting through our labels. We predominately print skinnier (19mm) non-tear off labels. Do you have any tips for adjusting the tension correctly? Thanks! Dave PS- Zebra is all set to have us spend $1000+ to have someone come out to change our printhead and platen, and to pm the printer. To me it seems like something easy to do ourselves?
SOURCE: Zebra 105 SE Printing Blank Labels
Seagull Scientific has drivers. Their Zebra driver is recommended by many.
http://www.seagullscientific.com/aspx/drvrmain.aspx
That's the link for their printer drivers page. Go to the bottom and click on 'Download a printer driver'. Then scroll the list to find the one you need.
Posted on Jun 10, 2008
SOURCE: Zebra Z4MPlus Ribbon Wrinkles
I changed the print head, and the issue was solved.
Posted on Aug 04, 2008
SOURCE: Zebra Strip prints blank labels
Please download a new driver from www.zebra.com (don't use your old windows driver) and then this will fix the problem.
Posted on Sep 17, 2008
ginko
  • 19396 Answers
SOURCE: We Dont have the installation
CHECK HERE :
Drivers & Downloads
Posted on Nov 24, 2008
  • 54 Answers
SOURCE: only printing 1/2 a label
recalibrate the printer in the set up.
Don't just do a quick cal from the front panel.
Make sure your driver is the correct dpi zebra driver, either zebra or my preferred seagull scientific.
by .5 of the label, do you mean width or heigth.
If it is heigth, check to make sure you are set for top of print correctly. Also you will have to back feed for a label that short.
Posted on Feb 24, 2009
I keep getting wrinkled ribbon in my zebra XiIII printers Part seems to be caused by static, the ribbon will not rewind properly
Its probably not static. 1. Wipe the print head and platen roller with alcohol dampened qtip or lint free cloth. Print about 30 labels while gently pressing on the ribbon supply, causing it to drag a little and observe if the wrinkles stop. If so tighten the nut on the end of the ribbon supply a little at a time until wrinkles disappear. Check the head pressure toggles on top of the print head and make sure they are adjusted about the same. If you have been printing a lot of the same size labels, check the platen roller (white) at the point where the right edge of the label rides on it for a slight offset where the roller is worn down. If it is worn, the only fix is to replace the platen roller.
Feb 17, 2011 | Zebra Xi Series 170XiIII Thermal Label...
I have a Zebra 110 XiIII p it does print different size bar codes
Keeping up with the Drivers is a very good idea, it will fix little problems that come along from time to time. Try resetting the printer defaults by entering the menu system and exiting, at piont of exit don't save permanently but cycle around to load defaults and exit. Go back in and set the printer up again, this time exit saving permanently.
Jan 21, 2010 | Zebra 110XiIIIPlus Label Printer
How to put the paper roll in Zebra V600 stripe printer
Send me your email address. I can send you the directions.
Rory Cardenas
Midrange Repair and Parts
Alsip IL 60803
3821 w. 127th place
708-597-4222 x240
rcardenas@mrp.to
AOL IM: RORYMRP
Jul 29, 2009 | Zebra Stripe S600 Thermal Label Printer
I GOT THE ALERT HEAD ELE. BAD ON MY S4M ZEBRA PRINTER
Seems like your Printhead needs to be replaced.
I have new 3rd party in stock at this time if needed.
Please contact me back.
Thanks
Rory Cardenas
3821 W. 127th Place
Alsip IL 60803
708-597-4222 x240
rcardenas@mrp.to
AOL IM: RORYMRP
Jul 29, 2009 | Zebra S4M00-2001-1100T Thermal Printer
Zebra xi III Plus printing shadows and blurred text on labels. Initial printing was fine but all prints now have a shadow and blurred text.
Try adjusting your printhead. If that doesn't work you might need to replace.
Please contact me if you have any question or if you come across needing a printhead for your unit.
I carry all parts for that printer in stock .
Thanks
Rory Cardenas
Alsip IL 60803
708-597-4222 x240
rcardenas@mrp.to
AOL IM: RORYMRP
Jul 01, 2009 | Zebra 110Xi III Plus Thermal Printer
Printing loop
Have you tried sending print jobs thru the parallel port only? I think it has to deal with your jetdirect box. You can try reseting that as well.
Rory Cardenas
Alsip IL 60803
708-597-4222 x240
rcardenas@mrp.to
AOL IM: RORYMRP
May 26, 2009 | Zebra Z4M Printer
Hi, I have a zebra 110 xi||| plus which is printing extra labels.
Did you design the label? Do you have any control over the label design? This is usually a sign that the printer is trying to excede the page limit (usually by one dot row) and is going to the next label to finish. By making the label length slightly smaller, you can stop this.
Mar 20, 2009 | Zebra 110Xi III Plus Thermal Printer
Only printing 1/2 a label
Feb 24, 2009 | Zebra 110Xi III Plus Thermal Printer
Zebra 110xi
what is the problem with your unit?
I have all zebra parts in stock refurbished with a 30/day warranty. I can take your as an exchange for the good one at a reasonable price. Please let me know I can be reached at 708-597-4222 X240 or email rcardenas@mrp.to.
My name is Rory Cardenas.
Thanks
Rory Cardenas
Account Executive
Midrange Repair & Parts
708-597-4222 x: 240
Dec 09, 2008 | Zebra 110Xi III Plus Thermal Printer
140XiIII left side print right side completely blank
Verify your LCD Display Print Width setting is set wider than your actual label width. The printer will only print to the width of the PRINT WIDTH setting. Also verify any driver or software settings as these override your printer settings.
Jun 30, 2007 | Zebra 140XiIII Plus Thermal Label Printer
64 people viewed this question
jasbo
jasbo
