Question about Sony Cyber-Shot DSC-S90 Digital Camera
White screen power works but screen stays white.  lense opens, can take picture but screen is white with no display of any kind.
  • Sony Master
  • 586 Answers
Hi,  This problem caused by the malfunctioning of CCD IMAGER. Which is to see to objective. Therefore you have to replace it from any SONY SERVICE CENTRE nearby to you.
  Thanks for using FIXYA!
Take care.
Posted on Mar 11, 2009
    Sergeant:
    Champion:
  • 231 Answers
Possible bad CCD imager device and or CCD imager board ribbon.Unless it got wet and corrosion is on video process area. try alamo camera service .com
Posted on Jun 24, 2008
I have compaq MV7500 COLOUR monitor n when i turn on the screen then i m getting only white line in the middle on the screen how can i fix the problem
When the following conditions, you need to replace the LCD screen:
No image on the screen, but the power indicator stays in
Dark display but still readable
Results - 1 of 1 / from by by 2 to a few seconds are of the the the the scintillator of the screen and Close for between the
The power indicator has been lit, but nothing display and sound
No image on the in the screen, but the LCD TV still comes with audio
Pictures cycle open and close the, as well as lamp closed for non high-power LED
http://www.lcdinverter.info/hp-pavilion-dv61247eo-lcd-inverter-p-11136.html
May 15, 2013 | Computers & Internet
Error code S0042, DIMAGE G600
The S0042 error code relates to a problem with the zooming mechanism (lens would not retract or extended)
Press the power button on and hold it down while extending and twisting the telescopic zoom lens. It might fix your problem. Let me know if it worked!
Feb 14, 2008 | Konica Minolta DiMAGE G600 Digital Camera
I have a Toshiba Regza 32lv 703G lcd tv. I switched it on and I have lost my colour. It only displays in black and white although the menu screen is till displaying in colour. Kindly advise. Thanks!
It is pretty much junk, sorry to say it but your picture tube went out and it is cheaper to buy a new t.v. My grandpa use to fix them for us for free but he passed:( If you call some where see how much they would charge for a picture tube, I bet it's expensive???
Jan 15, 2012 | Toshiba REGZA Televison & Video
My CRT TV displays a single horizontal white line across the screen. It will flicker and try to display the picture. If you smack it you'll get a quick picture then back to a line. After about 10-15...
The single line means that the vertical deflection doesn't work. And since it is working when you kick the tv or has warmed it's clearly a bad connection - open the case and reseat the wires going to the tube coil.
Dec 21, 2009 | Toshiba 32A33 32" TV
Screen stays either black or white
Replace the entire DAC board (board with power suplly going into it) for easiest solution.
Aug 19, 2009 | ViewSonic VA703mb Monitor
Screen will not read lense
Sounds like you accidentally pressed the DISP or DISPLAY button on the back. This manually turns the screen on/off to save batteries. Just press it one more time to turn it back on.
Apr 25, 2009 | Canon Cameras
Canon Power Shot S1 IS
canon has a recall on this camera. call them and they will send you a box to send it back. If you are one of the lucky ones the will send you a canon s5is back...really nice camera
Oct 29, 2008 | Canon Power-shot S1 IS Lens Converter
Finepixz20 digital camera
That is actually the exact same thing I am experiencing but mine has grey lines on the display window. I was able to take photos to a grey screen connect it to my comp...low and behold my pics showed....I am furious....need some answers as I will never hear the end of it from my daughter.
Grrrrr
weelassy
Oct 20, 2008 | Fuji FinePix Z10fd Digital Camera
Charging flash stays on and i cant take a picture what can i do?
help me solve this problem. - my camera stays "charging flash" and cannot take pictures
Sep 30, 2008 | HP Photosmart 735 Digital Camera
Hp photosmart r725 6.2 megapixels.
If you're getting the 18-4489-957-000 error code, then give it a good tap on the corner where the lens cap is. A little tapping and the lens cover should pop closed. When you turn the camera on again it will probably work just fine.
I was just about to junk my camera when I googled the error code and found this very tip in another thread. It worked like a charm.
May 29, 2008 | HP Photosmart R725 Digital Camera
Sony Cyber-Shot DSC-S90 Digital Camera Logo
96 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
Are you a Sony Camera Expert? Answer questions, earn points and help others
