Question about GPS
1993 Jeep Grd Cher. Laredo fuse panel diagram to determine which runs the turn signals, emerg. flashers work so don't think it is a flasher. fuse panel door is missing as is owners manual.
    Brigadier General:
  • 3,917 Answers
Please find the diagram in the bellow provided article:
http://www.jeepforum.com/forum/f13/zj-fuse-panel-diagram-1993-1995-a-611159/
Thank You
Posted on Sep 30, 2010
Where is the emergency flasher relay for 1993 Buick Century?
check to make sure there is a relay for the hazard lights as normally the switch just connects the 4 flashers and works thought the indicator flasher unit.
Jun 22, 2015 | 1993 Buick Century
Turn signals don't work
near your fuses, in the fuse panel you will find a silver/grey colored, often round thing, this is called a "flasher" this is probably your problem, replace the "flasher"
Jul 13, 2012 | 1990 Dodge Ram
My turning signal don't work but the flashers do work. I have changed all fuses and they still don't work.
since you know where the fuses are, you also know where the flashers are. the flashers are the same part so unplug the one for the emergency flasher and put it into the socket for the turn signals and vice versa. if the signals now work but not the emergency flasher you know to get a new flasher unit at any parts store. the flasher units are cubes about an inch on each side plugged into the fuse panel.
Jun 27, 2011 | 1995 Chevrolet Caprice Classic
The fuse for the cooling and heating systems keeps blowing when I use the turn signal I have a 2003 Jeep grand cherokee laredo. they must be on the same circuit. the fuse will only blow when I use both the...
I have the same problem and am going to trace wires for shorts-what I am reading is 80% of the time its the flasher module. Keep in mind the emergency flashers will work even though the fuse is blown and flasher module may be faulty. Flasher modules run about $70 on average-so be careful you don't roll the dice on the fix and be out $70. Again-if I cant find visible shorts, I'm replacing the flasher module. Check the internet for discussions on this subject-it is a very common problem with the 03s. Let me know if this was your fix if already repaired. Thanks and/or good luck.
Oct 06, 2010 | 2003 Jeep Grand Cherokee
1995 F150 the turn signals do not work, but
Look in the fuse panel and the turn signal flasher is the big round most likely yellow or silver in the corner of fuse panel. The emergency flasher is in the back side of fuse panel right directly behind the turn signal flasher.
Remove the emergency flasher and install it in place of the turn signal flasher and see if this corrects the problem and if so get a new flasher. If this does not correct it problem will most likely be the multi-function switch.
Mar 13, 2009 | 1984 Ford F 150
Turn signals and ac stopped working at the same time
don't know if they are related. as for the turn signals check the flasher. there should be 2 of them.one for the turn sinals the other for the emer. flashers
Mar 11, 2009 | 1999 Jeep Grand Cherokee
Blinker dont work flasher and other lights work
The turn signals don't work, but the emergency flashers do? If that's the case, replace the flasher, you have 2 flashers, one for emergency (hazard) flasher, and one for the turn signals. It should be on the fuse block under the dash.
Oct 23, 2008 | 1995 Jeep Cherokee
Diagram
ok, the dash does not show the blinker is on, did you check the front and back to see if any of the turn signals were on, but not blinking? Also the side marker lights should light up if the turn signals aren't working, do they? Let me know. Next check the fuse box, it's on the driver side, under the dashboard. The fuses will be labeled, check the fuse for the turn signals.
Check to see if it"s blown. If it is, or you aren't sure, replace it with one of the same amperage (the # of amps is on the fuse). The fuses can just be pulled out to check them. If you still don't have working blinkers, go back to the fuse block under the dash. There are 2 round canister shaped units plugged into the fuse block. One of them is the turn signal flasher. They are about the diameter of a quarter, and a bit over an inch thick. If your emergency flashers are working, unplug one of the flashers. If they don't work after unplugging one, then you just unplugged the emergency flasher, so the other one is the turn signal flasher. Replace with a new one, identical to the old one. Let me know when you have followed all these instructions and what happens. countrycurt0
Aug 11, 2008 | 1999 Jeep Grand Cherokee
Blinkers not working
Did you check the bulbs? If one bulb is burned out, the blinkers won't word on that side. You could have one bulb burned out on each side. Start the car, put left signal on. Check front and back lights. Is one light on but not blinking? If that's the case, the light that's not on at all is burned out and has broken the circuit so the good light stays on and won't blink. Check the other side. You also have a 'flasher' , actually 2. One for emergency flashers, one for the turn signals. It could be that the turn signal flasher is shot. You just have to unplug it to remove. It's probably located near the fuses. good luck countrycurt0
Aug 10, 2008 | 1999 Jeep Grand Cherokee
Turn signals not working --- 2001 Cherokee Limited
Check the flasher under the dash to the left of the steering column. It's got about 8 or 10 wires plugged into it.
May 30, 2008 | 2001 Jeep Cherokee
GPS Logo
231 people viewed this question
Top GPS Experts
Are you a GPS Expert? Answer questions, earn points and help others
