Question about Microwave Ovens
I have a Gaggia Factory 106 that's 2 weeks old. In the boiler cap, the retaining clip on the pressure relief plunger disintegrated. I replaced it, but now the cap leaks steam, although the boiler gets up to pressure. Nothing else has changed since I replaced the clip! Should I replace the pressure relief spring with a slightly heavier one? Is the spring adjuster maladjusted?
I think it's an extra safety mechanism if you leave the machine on, for extended periods, inadvertently
Posted on Dec 28, 2013
Microwave HV Transformer Melted
Yes! you can, just make sure it is unplugged and discharge with a screwdriver, before you change the transformer, put your digital meter on ohms and put the test leads across the capacitor remembering to unhook the one side to prevent misleading readings, If cap reads .2 ohms or less it is defective, but if readings are infinity or open cap is good, check the high voltage diode the same way.
Jul 11, 2012 | Microwave Ovens
I bought a refubished pressure cooker there is something funny the presure release device sits to loosely on top I wonder if its broke? Or where can I get a new pressure release device to replace this...
It should rattle if it is a pressure cooker This item will be round and should have a hole
in it. steam will escape from this hole as its cooking and it will rattle. It is a weight.
If it is a pressure canner it will have two items,
a pressure relief and a pressure gauge. Many had wing nuts which held the
lid in place such as mine has.
Wikipedia has a nice treatise on pressure canners as a reference.
hope this helps.
Mar 05, 2011 | Microwave Ovens
My new gaggia platinum vision will not prime. it says "prime water circuit" and makes several loud clicking sounds and then says "restart to solve the problem", but this doesnt solve...
We had the same problem on our machine, and it was fixed by backing the strength setting (the physical dial on the front of the machine) off from the "maximum" setting a small amount. Somehow this was creating too much back pressure, and the useless "will not prime" message appeared.
Dec 29, 2010 | Microwave Ovens
My faema e91 turns on but only reads p0.0 on the display. It won't steam and the espresso part works but isn't hot when it comes out.
theres a tempature probe on the upper right side of the boiler that tends to go bad, its a brass screw in sensor with two wire sticking out leading back to the board, replace this. also verify correct water pressure, if its not the sensoe then check your elment for continuity. e
Nov 15, 2010 | Microwave Ovens
How to remove the rack holder from a GE JMV1340WW002 microwave.
Hi best way is to remove the outer case and cut the back of the clip off, alternativly you can just lift the old clip from inside the oven cooking cavity with a flat knife or spreader untill the plastic clip on the rearside breaks off, it'l just fall down and sit in a void in the bottom of the oven and wont cause any damage. The new clip is just installed using an upward motion whilst pushing inward untill it clicks into place.
Hope this helps
Jan 07, 2010 | Microwave Ovens
My 15 year-old RHEEM Warrior Model 71-40S forty gallon electric water heater is leaking, and the element also needs replaced. I am thinking it is likely time to get a new, energy-efficient model versus...
Rheem makes great products. Lowe's sells whirlpool brand and they are not all that bad for the money. I would buy something better than the budget 7 year warranty model though. My preferred choice is AO Smith. I would definitely replace your water heater if it is 15 years old- most don't go much longer than that, although mine is 27 years old and going strong! Please remember to make sure and extend your pressure relief valve down to within 6 inches of the floor when replacing the water heater as Code requires. A water heater blanket will also earn its keep in a short amount of time.
Jan 02, 2010 | Microwave Ovens
Is there a replacement microwave for thermador MBBS that fits MT30S trim kit?
Thermador doesn't make one, but we found the GE JEB1860SM1SS from Home Depot fit perfectly. For only $259. The repair to fix our Thermador was $618. It was only 5 years old. I couldn't believe it already went out. I won't be buying anymore Thermador appliances.
Dec 20, 2009 | Thermador MBBS Microwave Oven
Our Sharp microwave oven turns on, makes a loud humming noise, starts to smell like something is burning, but doesn't heat. Well, actually, we don't think it heats, we're too scared to let it run because...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman";} This can be caused by grease etc. inside the oven and on the wave guide which is the paper like thing in the oven. If you can remove it look for burnt areas which may can be scraped off or you may need to replace it. An appliance parts store usually has the material you can cut to fit you own.
Dec 10, 2009 | Sharp R-530ES Microwave Oven
NEED TO REPLACE THE WHITE PLASTIC CATCH ON NEXT TO THE CONTROL PANEL AS IT SNAPPED OFF AS MY SON SLAMMED THE DOOR
By the nature of the oven main face plate and the locking latch being attached to the safety system the replacement cost is usually higher than a replacement microwave oven.
In your case replacing the microwave with another one is more sensible. Your oven is an obscure model as it is, I'd suggest a sharp brand.
Regards,
Worldvet
May 15, 2008 | Zanussi ZM24STX 900 Watts Microwave Oven
Microwave Ovens Logo
42 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
