If i am away for any length of time, do i put the temp on vacation? does the water still get warm?
  • 3,287 Answers
Since you didn't provide the brand & model of the thermostat, only generic help can be provided.
Most furnaces that run on oil or gas, make hot water all the time, 24 / 7 - winter, summer and everything between so to speak. They are controlled by an aquastat that may be set for any value between 140 - 180 degrees F. This is called "hot start" - simply because when the thermostat is set to a temperature higher than the room (turning heat ON), the water is already hot in the furnace, and is circulated immediately. If it was a "cold start", you'd have to wait for the water in the furnace to heat up from room temperature. This would substantially increase the amount of time it would take to heat the room.
Generally, the "vacation mode" simply halts the program from running. If your thermostat changes temperatures several times during the day / night, it will simply hold the lowest temperature - or a predetermined temperature built in - or chosen by you. You'll need to consult your manual to determine just how your thermostat handles the vacation mode setting. Post again if you can't find the manual - but tell us what brand and model it is.
I hop ethis helps - good luck!
Many heating thermostats don't allow for setting a temperature below 45 degrees F so freeze ups shouldn't be a problem.
Posted on Oct 01, 2010
I have a Bradford white water heater- how do I check if it is on vacation mode?
The gas valve dial, which is in front of the heater near the bottom, will say "Vacation" mode. Just line up the pointer with the word vacation. Some models no longer use the word "Vacation", replaced with "Low or Warm". It will be the setting just before "OFF"
See Pics (inside blue box) answers your questions:
Feb 13, 2015 | Water Water Heaters
Rennai
TAKE OUT THE ELECTRODES AND EMERY CLOTH THEM TO A SHINE. THEY GET A BUILD UP ON THEM NOT LETTING THE BURNERS RUN AT THEIR FULL CAPACIATY.
Sep 09, 2014 | Water Heaters
I have a 96 cadillacsls that is over heating- no leaks but it is pouring out the over flow tube?
Did you over heat warning message come on " Urgent shut off engine" or check coolant message? My coolant message came on but once car warmed up, it was late summer. No leakage but coolant level was low; added some coolant. Then it happened again but once car warmed up the check message disappeared. Then a few days later I got the Urgent Shut off Engine message! Thankfully I was able to pull off road and shut down immediately. Had it towed to Caddy shop. My water pump had gone out. New Pump and replaced all hoses. Then a year later check coolant light came on again, once car warmed up, light went off. This time tho a small leak in the radiator. My husbank put in a new radiator. Car has 117K miles and a few weeks ago outside temp 35, running late for work and didn't allow car to warm up but just a minute or two and when I puled away the check coolant light came on; but once the car warmed up (temp gauge needle in center) the light went out. Being the car is 17 years old I try to treat her like a baby and not push her so I do let the engine warm up before driving away. Do you have to add oil between oil changes? This is normal for the Northstar engine; your regular garages or full service stations don't know this; also make sure if you aren't using an authorized Cadillac garage that they put the right amount of oil; they want to put less than what is required. Not sure if this is really a solution more comments than anything... :)
Feb 01, 2013 | 1996 Cadillac Seville SLS
Does vacation mode still leave the pilot on so you don't have ot relight it. I want to put up the themostat 2x or 3x a week and save on gas bills as I'm not home too much. How long will the water stay hot.
Yes the pilot should stay lite in vacation mode, just know yhat a strong wind down the pipe could blow it out. As far the temp. of water just to many variables, but if heater isn't real old it should be able to recover in a very short time
Nov 06, 2009 | Water Heaters
Power vent 50 gal tank flashing code 2-3
1. Turn off power vent blower and set water heater temp to vacation (lowest temp)
2. Turn on power vent blower
3. Turn the water heater temp from vacation (lowest temp) to hot (highest temp) four times.
4. Set the water heater temp to normal
Aug 21, 2009 | Rheem Water Heaters
Am I supposed to keep the button on the lower left side of my Bunn coffee maker in the ''on'' position all the time? If I don't, the coffee is weak and barely warm.
Yes that is the vacation switch and should be left on to allow the tank heater to keep the water at the right temperature for brewing coffee. It only needs to be turned off when you will be gone away for 4 or more days. If you do turn it off, it takes 15 min to heat the water back up to the correct temperature.
Apr 16, 2009 | Bunn 10 Cup Home Coffee Brewer
Heating & Cooling Logo
66 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
