Hi i have the linksys model wub54g router an adapter i would like to put a password on t stop other uses on my internet
Wusb54g is linksys wireless adapter that connects to a wireless router. Are you using a linksys router? If yes, open a browser, type in the router's ip (ex. default ip is 192.168.1.1 note: don't put www or http just the numbers - if you wan't to check the default gateway go to the command prompt type in ipconfig and look for the default gateway). it willl ask for a username and password, leave username blank and the default password is admin (note: it's case sensitive - all lower case). Once you're in the router's user interface, click on the wireless tab. First tab is basic wireless settings, just change the ssid or the network name to any name you want then svae the settings. Then click on wireless security tab(one of the sub tabs under wireless). If you select wep just use 64 bit encryption then just type any key word under passphrase then click generate, write down the code under key 1, that's your security key. or if you're going to select wpa for you're security you can type in alphanumeric code (atleast 8 characters, just make it all lower case, no space, no special characters) then save it. That's how you secure your network using a linksys router.
Posted on Jan 06, 2010
    Sergeant:
    Champion:
  • 326 Answers
U don't need a password. U need to set U'r router to a secure mode, not open ended. use WEP or other (64 bit or 128 bit) encryption. linksys allows U to select a paraphrase, example: "Love2Air" and it will generate a code, i.e. "7D23C678867". This will allow others to see that there is a wireless system, but they have to have the code to use it. U will have to have the code in your other wireless pc's in order to use the system. U can also tell the router what MAC address' (pc address') to allow or disallow to use the system.
A password is used to keep others out of U'r routers setup and changing U'r code or paraphrase. If U'r system gets highjacked, there is a reset on the router and everything will revert to the book defaults. Don't loose the book.
Posted on May 26, 2008
I have a Linksys WUSB11 ver. 2.5 at school and kids are using it, I was wondering if i can put a password on to it.
You will need to a password on the wireless router not the USB device. What is the model of the wireless router?
Feb 11, 2014 | Linksys WUSB11 802.11b Wireless Adapter
Where do i put hinternet connection cord at?
1. Go to Best Buy. Get a Linksys wireless router. Hook up your internet to the slot in the back that says INTERNET. Then attach an internet wire into slot 1. Plug the other end into your computer. Repeat with any other computers. Put the CD in any computer hooked up with the Linksys. Set it so wireless connections are allowed and set a password. Use the internet channel, wait until your Linksys pops up, and enter you password. You're good to go.
Note: I was talking about this Linksys: http://www.linksysbycisco.com/US/en/supp...
2. Get a $40 Wi-Fi adapter and hook it up to your computer (assuming it has internet). After setup, You will have Wi-Fi, but it has a tiny range. I recommend the router. The router has a MUCH larger range and costs $20-$120 depending on how fast and how large of a range you want. Any router will work as long as it's wireless.
Feb 26, 2011 | Nintendo Dsi Pink Console
Trying to connect a new laptop to my linksys wireless setup and I enter the WPA key and it says it is aquiring network address, but never does. What am I missing.
Stop and start over with Router Setup by using a paper clip to press router reset button. Now, with router connected via CAT-5 cable to a computer's NIC. On this computer, using IE or other web access, go to http://192.168.1.1 to access router web setup. Set the Wireless properties, such as SSID (Network Name) and Security properties, like WEP/WPA passwords. This password will be needed by all computers accessing this router's signal. At this point, your router should be putting out a signal identified by the SSID name, all other settings for the router should be set already to the point where it will work, like the IP addresses declared in the router setup. Best left alone, at least till it is up and running. It gets the network address from your Internet Provider, and they are the only ones that can give you an IP address.
Dec 15, 2009 | Linksys (WIFIDESKTOP) Wireless Adapter
No internet access with new Linksys wireless PCI Adapter
Don .bin is a firmware that can upload to the linksys router or any router.
So it seems that your unable to connect wirelessly using the linksys adapter? The Internet connection before is working properly?
*I might advise you to reinstall the driver of your wireless adapter using the latest driver that you can download in there support site.
- Check the Internet connection hardwired to the router if connection works it seems that problem is on the adapter.
Mar 07, 2009 | Linksys Rangeplus Wireless Pc Adapter
Using a linksys g adapter card in my laptop cannot get internet
U have to configure the router.Then & then your internet will work.You can see the instruction set given with the linksys router or instruction set cd.Follow the steps,which will ask you ip,user name,password etc. information.Fill the right information save & reboot it must work.
Jan 03, 2009 | Linksys WPC54G Wireless-G Notebook Adapter...
Forgot security key/passprease
the security passkey or passphrase will be found on the router user interface. if you are also using a linksys wireless router...you can try this out..
1. open internet explorer...type 192.168.1.1 on the address bar and hit enter.
2. it will ask you for a password, default username and password for a linksys router is username - nothing, password - admin.
3. go to the wireless settings tab and wireless security tab then look for the password.
Oct 08, 2008 | Linksys (WMP54GS) 802.11g/b Wireless...
Linksys SPA2102 conflicts with my Router
I have the same problem and I configure my router in PPPoe with my username and password provided by my ISP and now my router is working...
Sep 04, 2008 | Linksys SPA-2102 NA Analog VoIP Adapter...
How To Set Up PPPoE DSL Connections with a Linksys Router
This article describes how to manually configure a Linksys Router for broadband DSL that uses PPPoE (Point-to-Point Protocol over Ethernet) for authentication. For automatic configuration options, please try: 1. Linksys Easy Connect (see Answer ID 1650 for more information), or 2. The Linksys Setup Wizard CD-ROM software that came with your Linksys Router. Simply insert this CD-ROM into an online computer before connecting your Linksys Router, and the Wizard will provide step-by-step instructions on how to install and configure your router. If you are unable to set up your Linksys Router by using one of the above options, use the steps below to manually configure your router. NOTE: It is recommended that you print this article for offline reference. STEP 1: Before You Begin In order to set up your Linksys Router, be sure to first have the following: 1. A Linksys Router. 2. A DSL modem. 3. A working computer that can be wired in directly to the router for initial configuration and testing. 4. Two (2) standard Ethernet network cables. Linksys Routers come with one (1) standard network cable that you can use. 5. The PPPoE DSL username and password assigned by your Internet Service Provider. Depending on the provider, your username format might be similar to username, vzn123456, or an e-mail address (username@isp.net). If you are not sure what your username and password are, contact your Internet Service Provider for more information. STEP 2: Check Your Internet Connection Before installing your Linksys Router, it is important to first verify that you can successfully access the Internet by connecting directly to your modem (without your Linksys Router installed). 1. If you are connecting for the first time, follow the instructions provided by your provider to set up your modem and computer for online access. 2. Verify that you are able to access the Internet without any problems. If you are not able to get a connection, contact your Internet Service Provider for assistance. When you are able to access the Internet using your modem, continue to Step 3 and proceed with the installation of your Linksys Router. STEP 3: Connect the Hardware Follow these steps to connect your Linksys Router to your modem and computer. 1. Shut down your computer and unplug the power cords connected to your modem and Linksys Router if they are currently powered on. 2. Disconnect the network cable that connects to the back of your computer. 3. Connect the network cable that you just removed to the Internet port (or WAN port) located on the back of your Linksys Router. Your modem should now be connected to your Linksys Router. 4. Connect a second network cable back into your computer (into the same port that was disconnected in #2). 5. Connect the other end of the second network cable to one of the numbered ports located on the back of your Linksys Router (labeled 1, 2, 3, 4, etc.). Your computer should now be connected to your Linksys Router. The following diagram shows how your network should be connected. Verify that your connections are correct, and continue to the next step. 6. Plug the included power adapter into the router?s Power port. Then, plug the other end of the power adapter into a nearby electrical outlet to supply power to your router. 7. Turn on your computer. Do not turn on your modem at this time. Only your router and computer should be turned on for Step 4. STEP 4: Configure the Router Follow these steps to configure your Linksys Router. 1. On the computer that is connected to the Linksys Router, open a web browser such as Internet Explorer or Netscape. 2. Type http://192.168.1.1 into your browser?s Address or Location bar and click Go or press the [Enter] key on your keyboard. The IP address 192.168.1.1 is the default IP address of Linksys Routers. 3. A user name and password prompt will appear. Leave the user name field blank (empty), and type in admin (lowercase) for the password. The password admin is the default password of Linksys Routers. NOTE: The following username/password prompt screen will vary by operating system. 4. Once logged in, the router?s web-based Setup utility should load. In the section labeled Internet Connection Type, or WAN Connection Type depending on router model and firmware version, select the PPPoE option on the drop down list. Click here to view what an older Linksys router interface looks like. 5. Once PPPoE is selected, enter your PPPoE DSL username and password provided by your Internet Service Provider into the router?s User Name and Password fields. Depending on the provider, your username format might be similar to username, vzn123456, or an e-mail address (username@isp.net). If you are not sure what your username and password are, contact your Internet Service Provider for more information. NOTE: Be sure to
Feb 16, 2006 | Linksys EtherFast Cable/DSL Router
How To Set Up PPPoE DSL Connections with a WRT55AG Router
STEP 1: Before You Begin In order to set up your Linksys Router, be sure to first have the following: 1. A Linksys Router. 2. A DSL modem. 3. A working computer that can be wired in directly to the router for initial configuration and testing. 4. Two (2) standard Ethernet network cables. Linksys Routers come with one (1) standard network cable that you can use. 5. The PPPoE DSL username and password assigned by your Internet Service Provider. Depending on the provider, your username format might be similar to username, vzn123456, or an e-mail address (username@isp.net). If you are not sure what your username and password are, contact your Internet Service Provider for more information. STEP 2: Check Your Internet Connection Before installing your Linksys Router, it is important to first verify that you can successfully access the Internet by connecting directly to your modem (without your Linksys Router installed). 1. If you are connecting for the first time, follow the instructions provided by your provider to set up your modem and computer for online access. 2. Verify that you are able to access the Internet without any problems. If you are not able to get a connection, contact your Internet Service Provider for assistance. When you are able to access the Internet using your modem, continue to Step 3 and proceed with the installation of your Linksys Router. STEP 3: Connect the Hardware Follow these steps to connect your Linksys Router to your modem and computer. 1. Shut down your computer and unplug the power cords connected to your modem and Linksys Router if they are currently powered on. 2. Disconnect the network cable that connects to the back of your computer. 3. Connect the network cable that you just removed to the Internet port (or WAN port) located on the back of your Linksys Router. Your modem should now be connected to your Linksys Router. 4. Connect a second network cable back into your computer (into the same port that was disconnected in #2). 5. Connect the other end of the second network cable to one of the numbered ports located on the back of your Linksys Router (labeled 1, 2, 3, 4, etc.). Your computer should now be connected to your Linksys Router. The following diagram shows how your network should be connected. Verify that your connections are correct, and continue to the next step. 6. Plug the included power adapter into the router?s Power port. Then, plug the other end of the power adapter into a nearby electrical outlet to supply power to your router. 7. Turn on your computer. Do not turn on your modem at this time. Only your router and computer should be turned on for Step 4. STEP 4: Configure the Router Follow these steps to configure your Linksys Router. 1. On the computer that is connected to the Linksys Router, open a web browser such as Internet Explorer or Netscape. 2. Type http://192.168.1.1 into your browser?s Address or Location bar and click Go or press the [Enter] key on your keyboard. The IP address 192.168.1.1 is the default IP address of Linksys Routers. 3. A user name and password prompt will appear. Leave the user name field blank (empty), and type in admin (lowercase) for the password. The password admin is the default password of Linksys Routers. NOTE: The following username/password prompt screen will vary by operating system. 4. Once logged in, the router?s web-based Setup utility should load. In the section labeled Internet Connection Type, or WAN Connection Type depending on router model and firmware version, select the PPPoE option on the drop down list. Click here to view what an older Linksys router interface looks like. 5. Once PPPoE is selected, enter your PPPoE DSL username and password provided by your Internet Service Provider into the router?s User Name and Password fields. Depending on the provider, your username format might be similar to username, vzn123456, or an e-mail address (username@isp.net). If you are not sure what your username and password are, contact your Internet Service Provider for more information. NOTE: Be sure to clear the ?Password? field before entering your account password. AOL USERS: Enter in your PPPoE username as screenname@aol.com. 6. If the Keep Alive option is not selected, be sure to select it instead of the ?Connect on Demand? option. The ?Keep Alive? option will ensure that your connection stays connected even when it is not in use. 7. Scroll down to the bottom of the page and click on the Save Settings, or Apply button depending on router model, to save your changes. OR 8. Once your changes are saved, you will be presented with a button to return or you will be returned to the previous page automatically. If prompted, press Continue to return to the router?s Setup page. 9. Close and exit the web browser. STEP 5: Power Cycle Follow these steps to power on and off your devices in the correct o
Feb 16, 2006 | Linksys WRT55AG Router
Computers & Internet Logo
167 people viewed this question
David Payne
David Payne
