Question about Car Audio & Video
How to remove the stereo from dash - Car Audio & Video
    Brigadier General:
  • 3,917 Answers
Please follow the detailed steps provided in the article bellow:
http://www.howtodothings.com/automotive/a3510-how-to-remove-a-car-stereo.html
Thank You
Posted on Sep 30, 2010
How to remove the stereo on a 1996 mazda mpv
Mazda MPV Dash Trim Removal, Stereo Removal - Auto ...
? 3:38
https://www.youtube.com/watch?v=REoTeVM2S-o
Jul 1, 2013 - Uploaded by Robert DIY
Dash trim removal: 5 minutes. This video will show you how toremove the dash trim piece on the Mazda ...
[PDF]MAZDA 1996-UP MPV - Scosche
www.scosche.com/media/guides/ma381.pdf
164. 1996-UP MAZDA MPV. MINIVAN. RADIO REMOVAL USING SCOSCHE DT-1 TOOLS . FRONT DOOR PANEL. FRONT AND REAR DOOR 61/2" 3-HOLE.
DIY Mazda Car Radio and Speaker Removal, How to Remove
www.carstereoremoval.com/htm/stereoremovalMazda.htm
'96-99* Car Stereo Removal · Ford Stereo Removal Tools Stereo Removal Tools. How To Install and Remove Mazda MPV Van Car Radio and Speaker, '89-95*
Jan 31, 2016 | Mazda Cars & Trucks
How does the cd player stereo come out?
Remove the two end panels on the dash. These are the panels that are located on either end of the dashboard. Place a rag over the tip of a flat tip screwdriver and wedge the tip behind the panel. Then pry the end panel off the dash. Do this for both panels.Remove the nine screws holding the glove box in place. Remove the two screws under the side panel on the passenger side (removed in step 1), four inside the glove box, two under the glove box, and one in the bottom left corner of the glove box (you can only access it after removing all of the other screws and extending the glove box down beyond what is normally allowed with the other screws in). Remove the screws holding the dash on under the steering wheel. Remove the two under the panel on the driver's side panel (removed in step 1), three on the underside of the dash, one on either side of the steering column, and one near the bezel covering the stereo.Pull the dash off from around the stereo controls.Remove the clip and wiring for the hazard switch using a flat tip screwdriver.Remove the six screws holding the HVAC unit and stereo unit in place and pull the stereo straight out of the dash. Unplug the electrical connection from the back of the stereo.
Jan 10, 2011 | 2006 Pontiac G6
How do you take of the dash paneling to install a new aftermarket cd player?
  • Disconnect the negative battery cable from the Jeep Cherokee battery with the 10 mm wrench.
  • 2 Remove the five screws on the top edge of the dash panel with a Phillips-head screwdriver.
  • 3 Pry the trim panels surrounding the climate control knobs away from the dashboard with the trim panel removal tool.
  • 4 Remove the trim panel that surrounds the headlamp switches (located to the left of the steering column) with a trim panel removal tool.
  • 5 Remove the two screws behind the trim panel that surrounds the headlamp controls with a Phillips-head screwdriver.
  • 6 Pull the dash panel that surrounds the stereo and covers the instrument panel of the Cherokee, away from the dashboard by hand.
  • 7 Remove the two screws from the stereo mounting bracket. One screw is on the bottom left corner, the other screw is on the top right corner. Each screw can be removed with the 10 mm socket and drive.
  • 8 Pull the factory stereo from the stereo mounting dock.
  • 9 Disconnect the stereo wiring from the back of the factory unit.
  • 10 Connect the Jeep Cherokee factory stereo wiring to a wiring harness adapter. Connect the wiring harness adapter leads to an aftermarket stereo. Slide the aftermarket stereo into the stereo mounting bracket and replaced two screws at the opposite corners with the 10 mm socket and drive.
  • 11 Replace dash panel that stretches across the top of the steering column.
  • 12 Replace the two screws at the top of the headlamp control switch. Replace the trim panel around the headlamp switch.
  • 13 Replace the trim panel that surrounds the climate control knobs.
  • 14 Replace the five screws on the top edge of the dashboard with a Phillips-head screwdriver.
  • 15 Replace the negative battery cable over the negative battery terminal and tighten the cable to the negative lead post with the 10 mm wrench
  • Dec 24, 2010 | 2006 Jeep Grand Cherokee
    How do i take out my radio from my toyota corrola
    The Toyota Corolla has been around long enough that many owners find themselves needing to replace the factory stereo. Installing a new stereo in the Toyota Corolla gives improved sound and updated features. Swapping out the stereo in the Toyota Corolla takes basic tools and less than an hour. This article covers models from 1990 to 2000.
    Open the hood and remove the negative battery cable from the terminal. Apply the parking brake and place the car in "D."
      > Remove the trim from around the stereo by prying with your fingers at one corner. Some early models have two screws at the top of the trim piece to remove first. Allow the trim to hang on the drivers side of the dash if it's connected to the cigarette lighter.
      > Locate and remove the four screws holding the stereo in place. Pull the radio out of the dash and disconnect the wires from the back of the head unit.
      To install
      > Connect the wiring harness adaptor to the original harness and let it hang from the dash. Slide the new stereo into the Toyota radio mounting kit, which is a thin metal cover and secure it per the manufacturer's instructions. Most adaptors have screws to hold the stereo in place, however some have clips, which engage automatically.
      >Plug the wiring harness adaptor and antenna wire into the back of the new head unit and push the entire assembly into the dash. Reconnect the negative battery cable and turn the radio on.
      > Ensure all of the stereo controls and speakers are working. Secure the radio in the dash with the original four screws and replace the trim.
    Dec 05, 2010 | 1990 Toyota Corolla
    Don't know what faceplate to buy for Kenwood Stereo SER# r8188309
    So if i understand your question correctly, you still have the stereo in your dash, but the face has been stolen, is this correct, Because if this is the case you can remove the rest of the stereo from the dash and somewhere on this unit it will tell you what model it is.
    Jan 15, 2010 | Car Audio & Video
    How do you get in to remove the stereo?
    No don't take the whole dash apart there is usually a bunch of screws and you may have to take apart half of the dash.
    There is usually some sort of plastic panel that must be removed than a bracket underneath it all to release the stereo sometime's for example fords have special lock key that you must use to remove it
    Sep 24, 2009 | 1992 Jeep Cherokee Sport
    How can i replace the manufacture radio in my car and replace it with aftermarket car stereo
    You best bet, because of a warranty, is to have a professional shop install your stereo. But if you are like all of us guru's here, you like to get your hands dirty.
    First you need to remove the dash around your factory stereo. Be patient here and try not to break any of the dash. You may need to remove screws and pop loose plastic retainers located on the backside of the dash.
    Wire the after market stereo to the harness located below by maching the colors provided. Thank the stereo companies for making this simple. Use crimp connectors or solder your connections, which ever best suits you. Tape up any remaining wires with eectrical to minimize the chance of a short.
    Take the metal sleeve provided by the sereo you choose and install it into the install kit located below. Once you have removed the factory stereo, test fit the install kit and attach any tabs neccessary provided by the kit.
    Now take the aftermarket stereo and place into the sleeve you installe din the install kit until it clicks into its locks. Now, the harness you wired up earlier, plug it into the factory harness and then into you stereo. Hook up the antenna, you may need to purchase a antenna adapter. Now before you install the stereo, do a test run to make sure everything is working. Once you are content that it is all working, install the new stereo and then reverse the steps in removing the dash panel and stereo.
    Below are pictures of the needed hardware:
    Sep 14, 2009 | 2003 Pontiac Vibe
    Im trying to find where i can gt a complete guide on how to install a car stereo from color coding the wires to installing a dash kit
    1. DISCONNECT THE NEGATIVE TERMINAL ON YOUR BATTERY!
    2. For an old stock stereo, you may have to remove the dash or certain parts of it to access the stereo. Do that by locating screws and bolts and taking them off. Make sure to keep them in a safe place.
    3. For an aftermarket stereo, insert DIN tools into each slot on the stereo behind the faceplate. Slide the whole stereo out.
    4. Disconnect the antenna wiring (The wire with the big metal tip)and the stereo head unit wiring (wire harness).
    5. Reconnect the antenna into your new stereo.
    6. Use **** connectors and wire crimps to connect the stock wire harness with a car specific one that is sold seperately. The color of the wires on each harnass should match up.
    7. Reconnect the negative terminal on your battery and see if it works.
    8. Slide the stereo back into the dash and remount the dash that you removed, including screws and bolts.
    hope this will help you
    Jun 05, 2009 | Kenwood KDC-MP208 Car CD/ MP3 Player
    Dash Removal in a 1998 Mitsubishi Galant
    go to metraonline.com then look up the dashkit and go to product instructins
    Apr 24, 2009 | Car Audio & Video
    Radio installation in 1983 dodge ram van
    remove screws from dash face, remove dash face. two 10mm bolts hold stereo in place,remove bolts, gently pull stereo out. unplug stereo. install new stereo by reversing the directions
    Oct 19, 2008 | 1983 Dodge Ram Wagon
    Car Audio & Video Logo
    15 people viewed this question
    Top Car Audio & Video Experts
    xxxxxx xxx
    Are you a Car Audio and Video Expert? Answer questions, earn points and help others
