Question about Singer White Speedylock 1634
Fourth thread keeps breaking, cannot find instructions to make sure I am threading correctly. Isn't there a video on the interneet available
  • 340 Answers
Hi
Do you have a manual?
There is one available to download free on the Singer website.
http://www.singerco.com/accessories/manuals.html
Just type 1634 and click on search.
On the next page click on free download!
If the instructions in the manual aren't clear enough have a look at videos on Youtube.
http://www.youtube.com/watch?v=5kF5ilPxR4Q
This is one of a series of four videos for threading a White Speedy Lock 1600 which should be almost identical to your machine.
Hope this helps!
Posted on Oct 01, 2010
Upper looper thread keeps breaking
try a new needles
check for burrs
make sure the thread is not caught anywhere
Feb 04, 2016 | Sewing Machines
My bobbin and thread are constantly breaking. I have the correct thread to needle, but I don't even get one stitch before both break. Tension is on auto; should it be less or more?
is the needle in the holder the correct way ( groove in the needle facing the thread )
Is the needle eye the correct size for the thread in use
remove it from auto tension setting and adjust it your self
make sure that the top thread is between the tension plates and not around the thread behind the plates
the thread tension is close to correct when you need a bit of a pull to pull it along to the needle
is the method of threading to the needle correct as any areas where the thread reverses direction will cause it to break
what do mean that the bobbin is constantly breaking or is it the bobbin thread that is breaking
have you got the thread down the case slot and under the flat spring correctly
the bobbin has to be inserted into the case in such a manner that when the thread is pulled , it flows down the slot freely as the bobbin turns
if the direction is wrong , the thread has to move across the sharp edge of the slot and will cut easily
Dec 21, 2015 | Brother Sewing Machines
Instructions for threading
search on Google make, model,manual or threading instructions
Dec 07, 2015 | Sewing Machines
I just got my sewing machine 2 months ago just started to use it icant because it keep breaking the thread ihave a fleeling i have it sat up wrong like the teason als may be t o tight
I would return the Unit to the Seller who usually has People that can Visually show you what you may have done wrong. Or go to Joannes or any Fabric shop (Not Walmart) and I'm sure there is some Lady (usually) who would be so joyous to help you!!! Really the fabric world isn;t to exciting!
Sep 30, 2015 | Singer 5400 Sew Mate 60-Stitch Sewing...
I have a brother xl 5500 it keeps breaking the top thread no matter what i do
Go back to your instruction manual, some available online. to Re-thread the machine completely and make sure you are threading correctly. If that's not it, you may have thread jammed in a mechanism and it needs a technician's tools to get at it properly.
Cheers,
Kelly
Embroidery Services
San Diego, CA
Feb 25, 2015 | Brother XL-5500 Mechanical Sewing Machine
The fourth thread (green in the map) keeps snapping after a few inches of working
try changing the needle
also try adjusting the thread tension
make sure the threading is correct for that fourth thread and needle
Jan 25, 2013 | Sewing Machines
How to thread a bobbin on singer 4411 sewing machine
If you've threaded the bobbin per instructions... then make sure your needle isn't damaged, bent, or dull. Also make sure the needle is seated fully and correctly oriented into the needle bar.
Aug 24, 2012 | Singer Sewing Machines
The 4th (bottom) thread on my overlocker keeps breaking, any ideas why please, I have re-threaded it and also changed the needles but with no joy - HELP PLEASE
When threading the fourth thread (Green) make sure that the needle threads (1, 2 - Orange and Blue) are not over the fourth threader. This would cause them to tangle up with the fourth thread. This is caused when manually advancing the machine to thread the fourth thread. I run a piece of cardboard through the feed mechanism to free all threads before using the overlocker.
Mar 05, 2011 | Janome MyLock 644D
Thread Keeps snapping on my 4th reel brother 1034d overlocker
I was having the same problem. I was trying to thread only that 4th one because it keep breaking. It did not stp til I rethreaded all the threads and did it worked fine
Apr 06, 2009 | Brother 1034D Mechanical Sewing Machine
Singer White Speedylock 1634 Logo
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Level 1 Expert
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
