Question about HP 10s Scientific Calculator
I'd like to know the position to insert the battery.
    Sergeant:
  • 168 Answers
I suggtes check the right information about this job in the HP 10S User Guide (page 6 - Battery).
I hope this helps to solve it (remember to rate this answer). Good luck.
Posted on Sep 30, 2010
How do I change the battry in a toshiba tecra laptop
Most laptops of external (replacable) batteries. However, if this is not true for your laptop, the battery is located inside and it is best to have a computer expert remove and replace the battery as any and all warranties valid on the laptop may be void if you attempt this yourself. There should be an indicator on the bottom of the unit with words to this affect. If the battery IS external, look to see if there are two "clips" that slide back and forth on each end of the battery. You'll know them when you see them. These "lock" the battery in place once the battery is inserted and usually automatically lock when battery is inserted. Hold each one in the indicated "unlock" position and pull out on the battery. These should not need to be "held" in the unlock position, and should stay on on their own once moved. Pull battery out and insert new battery if applicable. Please let me know if this was helpful, and contact me if further assistance is requested. Thank you.
Nov 28, 2014 | Toshiba Computers & Internet
How do I replace batteries on aerolatte pro
Check that the end cover is on properly and that the contact in the lid is intact (positive terminal).
Oct 31, 2014 | Aerolatte Milk frother with Stainless...
Dont know what size battery to use for a nady ht-3 mic transmitte
To insert the battery, You will need to unscrew the below button part of the hand held mic (anti-clockwise), and after unscrewing, you will see the space to fix in the 9 volt battery..
When you buy the battery,before fixing the battery in, check the polarity before placing the battery in (positive + and negetive -)...After inserting,screw back the cover in and locate where the power switch is..It always has an indicator to know if the power is on...
Note..make sure the Transmitter is on for it to be able to work properly with the hand held microphone....
Good luck..
Sep 07, 2011 | Nady Systems HT-3 Professional Microphone
Inserting batteries in correct position.
From page 6 of the manual:
"Insert the two top batteries with the positive terminal facing out and the two bottom batteries with the negative terminal facing out. Note: If the battery door does not shut, please check the position of the batteries."
Jul 22, 2011 | Franklin KJB-1840
Have a delcotron alternator ,what to know where no.1 terminal and no.2terminal wire goes it is on my 1946 cj2a jeep my amp hand does not show a charge had alternator checked out and is ok
  • Use a wrench to remove the negative and positive battery cables: They are clearly labeled "+" and "-." Always remove the negative cable first, as this isolates the power to the metal parts of your car. Tuck the cables away from the battery as you don't want them to accidentally touch a battery terminal when you're wiring your alternator.
  • 3
    Locate the alternator terminals. There are two: one marked "live," "pos" or "+" and the other marked "neg," "field" or "-."
  • 4
    Locate the two cables. The positive (red) cable goes to your battery via a wire loom or harness. The negative (black) cable attaches to a metal part of your car.
  • 5
    Check how the cables attach to the alternator terminals. Some connect using eyelets that hook over the terminal and tighten with a bolt; others connect by inserting the wire under the terminal and tightening a bolt.
  • 6
    Loosen the two bolts using a suitable-sized wrench or, if the cables connect using eyelets, remove the bolts.
  • 7
    Insert the exposed end of the negative (black) cable under the loosened bolt on the negative terminal of the alternator, then tighten the bolt. If the cable has an eyelet, hook it over the terminal and screw the bolt back in place and tighten using a wrench.
  • 8
    Insert the exposed end of the positive (red) cable under the loosened bolt on the positive terminal of the alternator, then tighten the bolt. If the cable has an eyelet, hook it over the terminal and screw the bolt back in place and tighten using a wrench.
  • 9
    Replace the positive battery cable on the positive battery terminal using a wrench. Replace the negative battery cable on the negative battery terminal.
  • May 17, 2011 | Jeep CJ Cars & Trucks
    Ignition switch replace
    It is something you can do yourself (for alot less money)
    I am assuming you are removing just the Lock Cylinder and not the entire Ignition switch?
    For JUST the Lock Cylinder:
    1. Disconnect the negative side of the battery.
    2. Remove the lower steering column cover under the steering column. It has three (3) screws.
    3. Insert the Key and turn to the RUN position.
    4. Using a small screw driver - depress the Lock Retaining Tab. It is located right of center on the column in the area of the Key insertion area.
    5. Remove the Lock Cylinder.
    To Install:
    1. Insert the Lock Cylinder in the "Lock" Position.
    2. While pushing in - insert the Key and turn it clockwise to the Run Position.
    Let me know if this helped. If it is the entire Ignition Switch, let me know with an email to this post. I will send the additional infomation (for free).
    Jan 05, 2010 | 2002 Chrysler Town & Country
    Ignition Switch replace
    To Install:
    Jan 05, 2010 | 2002 Chrysler Voyager
    Sterring wheel unlocked key won't turn 2002 Dodge CAravan
    03 dodge grand caravan - key will not turn in the ignition. i have replacement ignition lock cylinder and have followed your steps on replacing until the step of "insert key and turn to Run position" - i can't turn my key at all. How do I proceed from here? Thank you for your help!
    Jan 03, 2010 | 2003 Dodge Caravan
    How do change batteries on mouse
    HI,
    All you have to do is flip the mouse over and remove the battery cover by pulling it up gently.Next remove the batteries from the mouse and insert the new batteries.Make sure the positive and negative connectors are lined up properly.
    Insert the battery cover again and your mouse is now ready to use.
    If you need any more help let me know.
    Thank you.
    Aug 07, 2009 | Dell U0636 Mouse
    Direction to insert batteries
    Look inside the piece that opens to expose the battery area, it is a tiny little area that has the indicators. One side is negative up the other side is positive up.
    Feb 18, 2009 | Sakar 81480 Digital Camera
    HP 10s Scientific Calculator Logo
    183 people viewed this question
    mukhtar21 shaikh
    mukhtar21 shaikh
