Question about Sony PlayStation Portable (PSP) Console
My originaal psp will not charge, all of the wires are properly connected and the ports are clean, the charger works with my brothers and mydads but not mine can you help?
  • 27 Answers
The problem may be from the battery it's self or the chargers port where if fails it may need to go get checked
Posted on Sep 30, 2010
Testimonial: "thanks a lot i'll go get it checked"
  • 30 Answers
You can solve this problem easily .................
first check your battery with others psp
change if necessary ...............
or do one thing wipe the tip with copper it will restore ...........
or else the problem may be of port so better download this repair for further problems click here
Posted on Oct 01, 2010
My Xperia 10i is not getting charged though my charger is working properly. Once charger is pluged charge light indicated gets on but no any battery charging indication can be found on the screen. My I...
when a phone does not charge, it means that the phone charger or the port at which the charger is inserted in the phone is faulty.
Might be due to dust or dirt. You can Clean charging port on the phone with a brush and alcohol to remove dirt.
After cleaning it,if still not charging, you can test charger with another phone to be sure if the charger is working. And if charger works with another phone,that means the charging port on the phone is faulty and will need to replaced.
Take care.
Jun 13, 2011 | Sony Ericsson XPERIA X10 Cell Phone
I HAVE A PSP 1002 (ORIGINAL MODEL). the problem is that i tried charging the battery with the wrong charger (i had temporary lost the proper psp charger) this seemed to work for a little while until one...
i do believe you have burnt out the inverter within the system :( i dont have an answer for you on how to persue a fix but i do wish you good luck .......keep in mind these are very cheap new nowadays so dont pay a big amount to fix it if possible ok :)
Jun 03, 2011 | Sony PlayStation Portable (PSP) Console
Samsung sgh z230 charging problem .. plsese help brother
Hi,having charging problem with your phone,you might not be too sure where the problem is really from, you will need to look out in two directions.
!.The charger your using,
! The charging port of the phone.
The charger might not be working properly and will not allow you to charge your phone properly.
You can use another charger to test if it will charge properly.
Also when you check the charger and it's working, You might need to replace the charging port area.
The charging port is the port that you insert you charger into the cell phone.
When you check those two out,am sure you will find a solution.
Take care.
May 25, 2011 | Samsung SGH-Z230 Cellular Phone
My psp will nt charge or turn on it has been in myy locker for a while now when i plug it into my ps3 it will not charge
Try keeping your psp battery in a dry place for a day,then try charging.If this doesn't work..
Try the following:
a) Try charging using a usb cable...
c)Also try cleaning the usb port and power port or the place were u connect the charger to psp...
b) Remove ur psp battery and plug in the charger and turn on the psp... When it turns on put the battery back in (do not turn off the switch or psp when u put the battery back in)...
Mar 15, 2011 | Sony PlayStation Portable (PSP) Console
No power mp5 i use a cell phone charger in my mp5
What you will need to do when mp3 player does not charge. First use another charger to test if it's the charger is working properly.
And secondly After testing for charger, and still it does not charge, that means the charging port on the mp3 player where the charger is been plugged in is not working properly. You will need to replace the charging port.
Alternately you can charge it from your computer by using USB cable. It automatically charges when connected to a USB port
Dec 06, 2010 | JVC XA-MP51 (512 MB) MP3 Player ()
Hi, I have an Acer Aspire 5600 which has problems charging. I have recently replaced the power cord as the other one had broken. the charging pin that goes into the computer only works when facing a...
This is a common complaint of the wire shorting inside, please go to my tips page so that this particular complaint was reviewed with some tips.
The short within the wire cuts off the adaptor votlage as it is in protect mode-- not a failure of the adaptor. so have the wire **** off and connected or use a new pin at the end.
Oct 30, 2010 | Acer Aspire 5600 Series 5610-2013 Notebook
My psp go has run out of batterie and no longer charges pls help
There are two possible causes for this, one your charger is broken, in which case you will need to buy a new one. Hopefully thats the problem, because the only other possibility is that the Charging port is broken, in which case you will have to send it to Sony to repair. However, there is a work around to the second problem. My psp has the ability to charge via its USB port, if you have a compatible USB cable, connect your psp to your computer and see if that will work.
Aug 20, 2010 | Sony PlayStation Portable (PSP) Console
My psp want charge l dont know if it is the charger or the battry
its probably both. take a qtip and dip it in some rubbing alcohal and clean out both the port on the psp and the one on the charger your gona have to downsize the qtip as you can telll its to big. just take off the cotton around it till it can fit. becareful not to break the pin inside the psp port and not to bend them to much
Dec 17, 2009 | Sony PlayStation Portable (PSP) Console
Psp won't charge when plugged into computer
u cant charge on a computer unless you have a charger that hooks up to it...are you sure your using a charger or are you using the cord that transfers data to ur psp! the data cord will not charge ur psp its not a charger all it does is transfer data sorry you need a charger for the psp not a data cable
Jun 18, 2009 | Sony PlayStation Portable (PSP) Console
Sony PlayStation Portable (PSP) Console Logo
119 people viewed this question
Top Sony Video Game Consoles & Games Experts
shaun taylor
marley mcelhinney
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
