Question about VillaWare 5787 Double Smoothee Work Top Blender
NEED THE RUBBER RING FOR THE BOTTOM OF THE BLENDER TO FIT ON THE ROTOR
    President:
  • 1,796 Answers
Hi!!
If you measure the gasket or have an old one to take to any appliance parts store or restaurant supply, you'll get it for about $2. It is always good to have a spear. The other option is to order it form VillaWare.
Don't forget to rate this post!!
Posted on Sep 30, 2010
I have an older Waring blender, model WF1112218. My problem is I took it apart to clean it and now can't figure out how it goes back together. Is it rubber gasket then rotor or the other way around?
Hello, Carla -
For all electric blenders the rubber gasket is placed between the glass or plastic blender container and the rotor with the blades.
The assembly is easy to recall when one realizes the rubber gasket is the seal for keeping liquids leaking out of the blender.
See the image here (it's for a Black and Decker, but the assembly is the same):
http://stainless-steel.us/12-pictures-of-baby-bullet-blender-instructions/black-and-decker-blender-assembly-instructions/
The image here shows the assembly for a Waring blender (different model than yours):
https://www.etundra.com/restaurant-parts/parts-diagrams/waring-bb140-bb150-bb240-bb250-bar-blender-parts/
Best wishes.
Jun 01, 2018 | Waring Blenders
I can manually turn the blades inside the glass pitcher and I can turn the piece on the top of the motor base into which the pitcher blade attachment fits.
One of the parts is not being driven properly. Either the clutch on the top of the motor is not really attached to the motor shaft OR the clutch on the bottom of the blade is not engaging with the motor clutch OR the blade clutch is not properly attached to the blade shaft. On some models if you put the rubber sealing ring in the wrong place between the beaker and the blade housing it is enough to lift the clutches apart. The rubber wing goes between the beaker and the blade housing, not between the blade housing and the blade retaining ring.
Jul 14, 2015 | Blenders
How do you mount up a blender?
The rubber ring goes between the jar and the blade assy housing. It never goes under the blade assy, always to the jar.
Jun 01, 2014 | KitchenAid 5-speed Blender With Glass...
My blender appears to be leaking from the bottom. Is it likely to be the jug or the coupling to the motor?
It is likely to be the rubber washer on the jug. You will need to disassemble the mixing blades and remove the rubber washer(s) from the jug and take it with you to a Target, Walmart or kitchen store. They usually carry a varity of the washers and you should be able to compare yours to get the right size. Some actually tell you exactly what mixers they fit.
Nov 25, 2010 | Waring 6000CG 60th Anniversary Blender
The small rubber? ring on the bottom of the immersible bleder is black, and it smell burnt. What can I do? Is there a replacement part? What is the address(e-mail) for replacement parts? Thanks,...
First identify if it might just be an "O-Ring". Some of these can be found at auto parts stores or local hardware stores. Also check for O ring suppliers in your local phone book. Lastly, find an appliance part store near you.
Nov 06, 2010 | Wolfgang Puck Immersion Blender
Hamilton beach blender cleaning - food underneath cutter..does it screw off?
Usually the ring on the bottom of the jar unscrews. There is a rubber gasket beween the jar and the bottom hub holding the cutters.
Make sure you reassemble it correctly.
Apr 17, 2010 | Hamilton Beach Blenders
A blender parts
You can most likely find all kind of blender parts at www.thegourmetdepotco.com. I just bought a Krups blender rubber drive gear from that online store. It's the best lowest price, compared it to Amazon.com too. Try it.
Nov 20, 2008 | Blenders
Krups blender drive gear
Ed,
The problem I had was removing the grey rubber drive. The solution is that it screws off not pops off. The trick is to use narrow needle nose pliers to grab the post that attaches to the motor and turn the rubber drive counter clockwise. Removing the motor becomes easy. Pull out the 4 rubber feet under the base and the screws will be exposed. However my situation was the grey drive gear was stripped and would bottom out. My solution was to use a same size lock washer as the washer between the post and the drive. So far so good! If it fails I will need to buy another grey drive. Myron
Nov 04, 2008 | Krups 239 Power X Plus Work Top Blender
VillaWare 5787 Double Smoothee Work Top Blender Logo
292 people viewed this question
Top VillaWare Blenders Experts
Steve
Andrew Taylor
Andrew Taylor
ray gallant
Are you a VillaWare Blender Expert? Answer questions, earn points and help others
