Question about Maytag Dryers
I have an, MED5740 TQ0, it runs but does not heat, all thermostats check out. But it gets no power to the heating element.
    Sergeant:
    Champion:
  • 351 Answers
Maybe heat selector switch or timer are you getting 220 v
Posted on Sep 30, 2010
Dryer runs but will not heat i checked thermistor and the thermostat and the heating element
Either the heating element is open or it is not getting power. It is one of the two!!!!!!!!!!!!!!!!!
Jun 14, 2017 | Dryers
Got 5 minutes of hot water then cold. replaced both elements and thermos. still 5 minutes of hot water. power bill increased nearly 400% in 30 days. HELP!!! please.
When the top of the tank is hot the upper thermostat removes power from the upper heating element and transfers the power to the lower thermostat and heating element. If the lower thermostat is defective, then the lower portion of the tank will not be heated and the supply will be greatly reduced. You replaced both elements however check that the lower element is coming on after ther upper one cuts out and is acutally working.
Check for power at the upper thermostat terminals where the power is sent to the lower thermostat and heating element. If there is no power then the upper thermostat should be replaced. If there is power then check for power at the lower heating element. If there is no power at the lower heating element then replace the lower thermostat.
If there is power to the lower heating element then it should be getting hot. If it is not, maybe defective. Another possibility is a broken dip tube. Check for a broken dip tube and replace if necessary.
If the dip tube is broken, the incoming cold liquid can mix with the out going hot liquid and cause it to seem as though you are running out.
Nov 04, 2011 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
My maytag lde8824ace dryer has stopped heating. i replaced the heat element assembly about an hour ago and still no heat. vents and ducting are clear. dryer run as normal. was wondering if it was a...
The heating circuit is composed not just by the heating element alone but also the high-limit thermostat located on the heating element housing including the four-terminal cycling thermostat on the blower housing and the motor centrifugal switch. The most prudent thing to do first when a heating problem is experienced is by checking the continuity of these parts and making sure the dryer is getting 220VAC supply. Note that the dryer works both on 110VAC for the controls and drive motor while the 220VAC is solely for the heating circuit. The 110VAC supply may be present which will make the dryer run but the 220VAC may not be present and consequently there's no heat at all.
Check the circuit breaker including the power outlet and make sure the dryer is being supplied with 220VAC. Check the continuity of the components located on the blower housing and the heating element housing. All of those components must have continuity for the heating element to turn on. Note that the cycling thermostat has four terminals. Continuity check must be done between the two outer and "thick" terminals. Replace the part found to have no continuity and as a preventive measure, it is necessary to also replace the other part that comes side-by-side with the faulty part.
Aug 21, 2011 | Dryers
Hi...I have a Whirlpool water heater and the water only stays hot for a few minutes. How do I adjust the temperature or settings so that I can have hot water all the way through the shower instead of...
I am guessing this is an ele water heater and the temp setting are not the problem.
Problem: Not enough hot water or water temperature too low. When the top of the tank is hot the upper thermostat removes power from the upper heating element and transfers the power to the lower thermostat and heating element. If the lower thermostat is defective, then the lower portion of the tank will not be heated and the supply will be greatly reduced.
If there is power to the lower heating element then it should be getting hot. If it is not, replace it. Another possibility is a broken dip tube. Check for a broken dip tube and replace if necessary.
The dip tub is located under the fitting where the hot water comes out.
Feb 03, 2011 | Whirlpool Water Heaters
I'm getting hot water for 2 minutes , then it gets cold
Most electric hot water heaters have two thermostats, one near the top of the tank and one near the bottom, and are covered by removable metal cover plates. The thermostats are pressed firmly against the bare metal wall of the hot water heaters tank.
The top thermostat usually has a high limit switch that will trip if the water gets too hot. When it trips it shuts off the electricity to both the upper and lower heating elements.
To reset the high limit switch there is usually a red button that you must press. When the upper limit switch trips it is often an indication that something else has gone wrong with the heater.
Hope this helps out
Feb 02, 2011 | General Electric GE SmartWater Household...
No hot water
Check your panel breaker to make sure its on. If it is, it's possible that the upper thermostat or element has burned out in your heater.
First remove the upper thermostat cover plate and check the high limit switch button. If it has tripped, press it to reset it.
Check for power at the input terminals of the upper thermostat. (usually marked L2 and L2) If no power is present then check your circuit breakers or wiring to the water heater.
If there is no hot water then the upper thermostat should be applying power to the upper heating element. Check for voltage at the upper heating element. If there is power at the heating element but the element is not getting hot then the heating element needs to be replaced.
If there is no power at the upper heating element then the upper thermostat needs to be replaced.
Hope this helps.
Mar 14, 2010 | Welding Tools
My dryer is no longer heating up and it does not time out, what parts would i need to fix the problems?
Q - My electric dryer runs but will not heat, what could stop my dryer from heating?
A - Things that could stop a electric dryer from heating:
- house fuse or breaker ( needs two of them ), heating element, burnt wire, thermostat(s), thermal fuse ( not all models ), motor heat switch, timer, selector switch, burnt power cord/plug
Whirlpool style dryer - no heat problems:
Electric dryers - See the "how to take apart" section first if needed. Always check the power supply first...if one house fuse blows or 1/2 of the breaker trips, it is possible for the dryer to run with no heat. If you have a volt meter, you should read 240 volts between the red and black wires, 120 volts between the white and black and 120 volts between white and red, check for this at the main power connection. If you have 240 volts to the dryer, remove rear access panel, turn dryer on and test for 240 volts to the *heating element wire connections (#4). If you have 240 volts there and no heat = bad element, the element must be broken physically to be bad. If you have no power at the heating element, remove power, remove wires to the heating element and isolate them so that they can't touch anything. Reinstall power and check each wire for power from the wire to the dryer cabinet, one wire will probably show 120 volts and the other will show zero. Make note of the color or # of the wire that has no power, remove power to the dryer and check the wiring diagram that comes with the dryer to find out where that color or # wire goes to. EG: - wires might be yellow and red, if the yellow wire (example only) was the one that had no power, look at the wiring diagram to find out where that goes to and check only those parts, no need to check the other colored wire parts as they are working. Things to check are, *thermostats, timer contacts, selector switch, motor switch heat contacts ( 1&2 on the motor switch ) and *thermal fuse. If the wires to the heating element are the same color, just remove power after test and slowly follow that wire that has no power with your hand to see what parts it goes to. If live volt testing scares you, try the ohm checkinstead.
*#1-Thermal fuse that controls heat. If the dryer overheats, this fuse will blow. One shot fuse. Does not reset.
#2-Canister for the heater element.
#3-Hi limit thermostat. This thermostat is a safety thermostat in case the dryer severely overheats. When this safety thermostat is defective, it should raise a red flag for air flow problems.
#4-This is the terminals of the heater element that is inside the canister.
#5-Thermal fuse that controls motor run.
#6-Control thermostat. This is the thermostat that controls the cycling of the heater in high heat mode.
#7-Heater for low heat. When you select low heat, 110V is sent to this heater that the control thermostat sits in. The heater helps cycle the control thermostat faster, therefore you get less heat than the high heat mode.
You can get required parts from www.repairclinic.com
This will help. Thanks please keep updated.please do rate the solution positively .thank you for using fixya
Feb 27, 2010 | Whirlpool GEW9250 Electric Dryer
My kenmore electric dryer is not heating I checked the heating coil and it seems ok could it be one of the thermostats?
Kenmore style dryer - no heat problems:
#7-Heater for low heat. When you select low heat, 110V is sent to this heater that the control thermostat sits in. The heater helps cycle the control thermostat faster, therefore you get less heat than the high heat mode.Things that could stop a electric dryer from heating:
- house fuse or breaker ( needs two of them ), heating element, burnt wire, thermostat(s), thermal fuse ( not all models ), motor heat switch, timer, selector switch, burnt power cord/plug.
A ohm meter test for these parts is here.
Jul 11, 2009 | Kenmore 62602 Electric Dryer
Model # lte5243bw2 not heating has power into & out of heating element
Your reading power on both ends of the element, but you will read
'0 volts' across the element. You have got to check continuity 'through' the operating thermostat & the 'high limit thermostat' and the 'thermal fuse'. Either one of which will case 'no heat'. The motor contacts have to close after the motor is running. This could also case no heat.
Jul 09, 2009 | Whirlpool Dryers
Heater element problems
Why did you decided that it is an heating element problem,it could be a thermostat issue as well. Check with a multi-meter whether you have power on the heating element tags. In case you have power on its tags, the heating element should be replaced.But in case you can't read any power on its tags, it's probably a thermostat issue. Good luck!
Sep 10, 2007 | Hoover 24 in. DT999 Free-Standing...
Dryers Logo
46 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
