Question about Vacuums
When I turn on my Vicks vaporizer - when I stop it - it has grit residue in the bottom is it normal? is it coming from the mechanism I put in the water? what is the problem? can I solve this? Or do I have to take the piece apart?
  • 490 Answers
Howdy, It could be from impurities in the water. If it seems to be mineral, I would not be concerned unless it it appears to be impairing the function of the vaporizer. It is also possibly some form of residue from the manufacturing process. Try a round of distilled water and see if it still leaves grit, this will help you to determine the source. Unless it appears to me organic or plantlike material, I would not worry about it being a health hazard. Farmerbear at FixYa.com
Posted on Oct 01, 2010
The roller shutter does not stop while rolling up, noting it has a motor, what would be the problem?
The "up" limit switch is not working. there will be one to stop the door going up and another to stop it at the bottom.
They could be magnetic or a contact micro switch, check the door track and look for something at the top of the track with wires coming out and see if it lines up with something on the door when it is in the normal open position.Similar to a burglar alarm contact on a door or window. You could try putting a magnet next to it as the door is opening to see if it stops or if it is a mechanical switch try operating it manually (preferably with an insulated screwdriver)
Nov 08, 2016 | Vacuums
How do I remove roller brush, it is seized and there doesn't appear to be anything on it stopping it from turning.
OK, I will assume the motor runs. Usually there are screws holding the roller brush cover (bottom of the machine toward the front). I think mine has four. Remove these and the cover should come off revealing a roller brush and a small rubber rubber drive belt.(Check belt for wear) The roller should come out easily when the belt is slack. There is a shaft running through the roller with bearings on either side to let it spin smoothly. These do wear out, or grit can sometime cause them to seize. Check by spinning the roller. If it spins then it's ok, If it does not then try WD-40 in each end and try to work them free. This is not a permanent solution but it will help. If it is freed up get something like A-1 oil and a few drops of that can help as well.
You might go to the company website and read the FAQ's. They may even have a manual or a diagram of your model.
This is only a guess on my part, but I hope it sheds some light on problem
Apr 18, 2016 | Vacuums
Dirt devil has had a new belt replaced now i am getting black goey residue coming from the bottom of the vacuum
If that black gooey stuff wasn't on the bottom of the vac when you started, it could be coming from a mis-installed belt. If the belt is not installed correctly around the agitator and checked after it is installed to be sure it turns freely with the agitator, then it can easily make lots of black, gooey, melted rubber. Check the belt, it's probably bound up somewhere.
Nov 03, 2013 | Vacuums
How can i get a replacement part for my vicks v3500 humidifier?
"How can i get a replacement part for my vicks v3500 humidifier?"
Knowing which part you're looking for would help immensely.
Aside from that, you can check here:
http://www.appliancefactoryparts.com/humidifiers/kaz/?gclid=CJOU4qTV4KgCFUMUKgodYmwIDQ
or here:
http://www.kaz.com/kaz/humidifiers/products/vicks-v3500-replacement-tank-m-gc.7206/
or just "Google" for the specific part you need.
May 11, 2011 | Vacuums
I am trying to find a replacement water tank cap for a Vicks V4450 humidifier. I dropped the cap and broke it on the edge. Everything I see on line does not say it will fit the V4450. My e-mail address is...
http://pg.custhelp.com/app/ask This is a link for Vicks online help section. I'd shoot them an email and simply ask if they can send or sell you a new one. Have the model number available.
http://www.pg.com/en_US/brands/health_wellbeing/index.shtml Here is the link for Proctor and Gamble who is the parent company of Vicks.
Good luck !
Mar 02, 2011 | Vacuums
My brand new dyson dc33 vacuum ($399.00) is making an annoying sound when applied using a carpet setting. This only occurs on my thinner carpets, not on my thicker carpets. Do I have to inspect the...
If there are no obstructions and it still makes the grinding noise here is something to try. When you take the bottom plate off which is real easy to do (3 plastic screws turn 1/4 turn with a coin) there is also on the bottom of the vacuum a rubber seal. This is located just above where the screws are inserted. Take a butter knife and remove this seal...it is very thin and runs the width of the bottom of your vacuum. Put plate back on and try vacuuming again..problem should be solved. The suction on the machine is tremendous...with the seal in place the vacuum literally sucks itself down on the carpet causing the brush to stop spinning. This wwill not hurt your vacuum in any way. Hope this helped.
Reply
Jan 05, 2011 | Vacuums
Every 3 swipes on the floor I have to push the reset button to engage the roller brush. Is this normal and if so why?
No, it is not normal for the brushroll to stop that often. You may need to clear any thread, etc from the brushroll underneath the vacuum. Remove the screws from bottom of unit, stand unit upright, turn height adjustment dial to either side to allow hood to come off. Check the belt for any stress marks, stretching, etc. Replace the belt if necessary.
Sep 05, 2010 | Eureka 5893AVZ Bagless Upright Cyclonic...
The roller on the bottom isn't moving
Nope.. Your belt is bad or the flywheel on the brushroll has come off. depending on the age of this oreck belt access may be as easy as a side panel. Older models require the removal of the screws in the bottom of the unit. If your not mechanically inclined take it to a vac shop. The cost will be minimal. Belts are normally 3 to 5 dollars.. they'll probably charge 10 for labor.
Dec 21, 2009 | Oreck XL Ultra Bagged Upright Vacuum
Is there a drive belt on the heritage 84
Yes it has a belt. Could be the belt or a worn out brush roller, or you don't have the height adjustment set right. But I would check the belt first. It is the cheapest part and if you haven't changed it lately it probably needs it anyhow.
If you haven't changed the belt before it's a little tricky.
Turn the knob on the front to the belt off position, and unlatch the top of the nozzle to remove it. Pull the nozzle off and turn the knob to the belt on position. Take off the bottom plate and take out the old brush roller and belt. Pay special attention to how the roller comes out. You don't want to get it in backward.
Put the new belt on the roller and center it. Put the roller back into the nozzle and put the bottom plate back on. Turn the knob to the belt off position you should be able to see through the hole in the back, the hook pick up the belt and stretch in up.
Put the nozzle back on the unit, latch the top, and turn the knob to the belt on position. Simple Right? LOL
It has to be one of the most complicated machines to change a belt on .
P.S. they usually give you extra belt when you buy it, and the new style knurled belts work fine as well.
Good Luck-Don't be afraid to ask another question if that doesn't solve your problem.
Dec 01, 2008 | Kirby Heritage II Vacuum
T2100 S Ladybug Canister Steam Cleaner
Visit the Ladybug Ladybug 2200S Vapor Steam Cleaner page and scroll to the bottom. There's a link that says, "Download owners manual."
Oct 20, 2008 | Vapor T 2200S LadyBug Canister Steam...
Vacuums Logo
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
