Question about E-Machines eMachines Desktop PC
Need more memory
I need more memory for my desktop I have a W2060e machines it already has 256 mb ddr how much more do I need ? Runs really slow
Depends on the operating system you're running and the applications you use. I'd suggest at least 512MB for XP and 1024MB (1GB) for Vista.
My personal computer has an AMD 64 3400+ processor and I run Windows XP. I do a lot of gaming on it also so I have 2GB of ram in it. At 2GB it runs most games well.
Also, take a look at RAM Def. http://www.download.com/RAM-Def/3000-2086_4-10109174.html?tag=lst-1&cdlPid=10185812
While I haven't used it much for actually fragmenting ram, it displays some useful stats about how much ram you are using and how much virtual memory (swap file) you're using. Adding these number may give you a better idea of how much ram you use for various tasks.
The virtual ram is hard drive space that windows uses as ram when there isn't enough physical ram. The problem is that virtual ram is inherently slow, so ideally you want enough ram so that your computer doesn't have to use virtual ram.
Posted on May 26, 2008
    Guru:
  • 859 Answers
Your machine takes PC2100 memory modules and yes you should have more memory to run WindowsXP.
For an eMachine the best way to upgrade your memory is to contact eMachine directly and have them advise you or provide you wit memory to suit your needs because their motherboards are pretty specific to them and the specs as sold to you are not available to us.
Use the below to get on your way. Hope this Fixed ya and thanks for using Fix ya.
Regards,
Worldvet
Telephone Technical Support
Customer care representatives are available 5 AM to 12 midnight PT seven days a week.
United States 408-273-0888*
Canada 604-637-1419*
*Long-distance charges may apply, depending on your calling area.
I upgraded my RAM to 1 Gig but it's still showing only 256 meg. Why?
Hi this model sopport 2Gig Memory Ram.
RAM Technology DDR SDRAM Installed RAM 512 MB Max Supported RAM 2 GB Number of Memory Slots 2 x DIMMs Supported RAM Speeds 400 MHz • 333 MHz Installed Cache Memory 256 KB
Please check in to your Bios system maybe share memory Video or capacity is setting
Nov 03, 2010 | Dell Dimension B110 PC Desktop
I have compaq presario 2.6ghz with Max Capacity 1gb Ram- is there anyway i can increase capacity to 2gb or even higher?
Unfortunately, if the manufacturer states that the max RAM supported is 1GB, that's going to be all you're going to be able to install - unless you replace the motherboard. This can be a considerable expense.
One last thing you could do is go to Crucial - there, you can run a scan on your computer to find out what memory options you have. I would be very surprised to learn they differ from what Compaq is telling you (unless the motherboard was replaced by someone already).
Please rate this reply - good luck!
Sep 02, 2010 | Compaq Presario S5100NX (E120866) PC...
I want to add memory to my computer but do not know what brand or type to get. I have an Emachines desktop PC with the current memory of 256 mb (DDR SDRAM). I play graphic games alot.
Hello
The best way for you to upgrade your ram DDR SDRAM, is to take your current chip to your nearest dealer and they will tell you exactly what the price and brand will be. You can even try to bargain so that you do a trade in with your current chip. Really hope this can help you.
Best regards
Sep 28, 2009 | E-Machines T3504 PC Desktop
I want to upgrade my ram what type of ram should i use and how what is the maximum amount of ram i can upgrade to?
Memory Upgrade for Sony VAIO PCG-K35 Laptop, the Sony VAIO PCG-K35 Laptop takes the PC2100 DDR SDRAM SODIMMs Memory Type, and comes installed with 512 MB = 256 MB (removable) + 256 MB (removable) of Memory. You can upgrade your Sony VAIO PCG-K35 Laptop to up to a maximum of 1.0 GB Memory, the system has 2 sockets to install Memory, already with 512 MB = 256 MB (removable) + 256 MB (removable) standard Memory installed. For best Laptop performance use the maximum amount of allowed Memory per slot for your Laptop.
Regards
Jun 29, 2009 | Sony VAIO PCG-K35 Notebook
Upgrade Gateway AMD Athlon 64 Processor 3500+
friend
looks like your machine has two memory modules
1. 256 mb ddr 1
2. 128 mb ddr 1
module of 2 gb in ddr1 are hard to find
but all you can do is take out these two modules and replace with 2 x 1 gb ddr 1 modules
easy...
thanks
Apr 11, 2009 | Gateway GT4015E AMD Athlon 64 3500+ 2.2GHz...
Need to know mem spd...333...400 etc to add cards
Memory Installed 512 MB (2 x 256) Maximum allowed 4 GB* (4 x 1GB) requires the replacement of the installed 256 MB DIMMs
*Actual available memory may be less Speed supported PC3200 MB/sec Type 184 pin, DDR SDRAM DIMM slots Four Open DIMM slots Two
Thats the sticks you need
Good luck
Nic
Feb 26, 2009 | HP Compaq Presario SR1630NX PC Desktop
Hp system board
the machine uses ddr 1 memory and hold a max of 2 gb of ram
RAM 128/2700 MB DDR SDRAM
Maximum 2 GB (2x1024MB DDR SDRAM)
Sockets Two 184-pin DDR DIMMs
Size 128, 256, 512 and 1024 MB DDR DIMMs
the motherboard is a socket 478 board , the Dual-Core chips are socket 775 so you couldnt use them unless you change the motherboard
Dec 08, 2008 | HP Computers & Internet
My name is Siavosh Eskandari. I have a desk top PC Compaq presario Desktop with Intel celeron processor 2.7 HHz Model SR1010NX, Prod. # DW25AA-ABA,Serial # MXK4180P8Y with 256 MB PC 2100 DDR SDRAM. The...
the model SR1010NX can take upto 1gb max of ddr 1 ram and must be done a 2x 512 ddr 1 chips
Memory Component Attributes Memory Installed 256 MB (1 x 256) Maximum allowed 1 GB (2 x 512 MB) requires the replacement of the installed 256MB DIMM Speed supported PC2700 MB/sec (messages at PC2100 Type 184 pin, DDR1-333 SDRAM DIMM slots Two
Nov 28, 2008 | HP Computers & Internet
RAM cuantity
The motherboard you mentioned supports DDR1 RAM.
For windows xp and general application 512 MB is enough.
But if you use memory intensive applications like image/video editing then you can opt for 1-2 GB RAM.
Nov 24, 2008 | Intel D845EPI (INTELKD845EPILPAK10)...
Want to kow how much ram I can add and where to buy it.
Hi
Dimension 2350 Series has two memory connectors and supports non-ECC PC2100 (266-MHz) DDR SDRAM memory modules. Supported memory capacities are 128, 256, or 512MB. The maximum (total) memory is 1GB.
Regarding where you could buy? I suppose you can check you local PC store. There is always eBay if you fancy.
Mike
May 16, 2008 | Dell Dimension 2350 PC Desktop
E-Machines eMachines Desktop PC Logo
90 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
