Question about Maytag Neptune MAH5500B Front Load Washer
Maytag neptune front load model MAH55FLBWW
The front panel lights up , but you cannot change any of the selections one the panel adn the machine will not start.. we changed the control panel and it still does the same thing. any ideas
  • 1 more comment
  • txtadpole May 25, 2008
    the pamel board has connectors and they will only go in one way so they are correct
    My Maytag Neptune fron load washer..the front panel lights up but you cannot change any of the settings on it any it will not start..The panel board has been changed and tha did not make any deffience. what could be the problem??
    No the front door doesnot lock. but the door is closed tight.
  • 2,296 Answers
Click here to get more info on more detail troubleshooting for your appliance.
Posted on May 25, 2008
  • Jaime Hernandez May 26, 2008
    Here is more info from the link previously provided.
  • 13,433 Answers
I would recommend you have a tech look at it.
    Genius:
  • 3,587 Answers
Hmmm..that's odd...are all the wires back in correct locations? or does this have a connector?
  • Patrick Michaels
    Patrick Michaels May 25, 2008
    ok..that's good...so..new control board..no action..on any of the cycles, right?
  • Patrick Michaels
    one more question...is the front door switch closed and latched..the interlock can cause this problem..
    nods to Eske..not a bad idea, but it's a holiday weekend here in USA, and they are all gone fishing
Tip
Maytag Neptune Front Load Washers No Spin Problem
A class suit was filed in the State of Illinois, USA and then later on won against Maytag in 2004 due to the high failure rate of the wax motor used in the door lock mechanism of their Neptune Front Load Washers. The wax motor is used to activate the door lock switch by extending its shaft when a voltage from the machine control is applied across its terminals. Its failure then leads to the breaking down of components in the expensive machine control board. This is the fact that angered the customers which led to the filing of the class suit.
The obvious symptom of a failed wax motor is the inability of the washer to advance to the spin cycle and the door lock lamp is not turned on. The washer stops momentarily at the end of the wash cycle then continue to tumble as the machine control checks the activation of the door lock switch. The control will not allow a spin speed higher than 51 revolutions per minute (RPM) unless the door lock switch is activated by the wax motor. It is a safety feature of the washer to prevent accident due to accidental opening of the washer door during a high speed spin.
Customers who purchased the Neptune Front Load Washers in the USA after April 1, 1997 and before August 9, 2004 are Class members and eligible for the repair reimbursement, replacement cost, or purchase certificate depending on the length of service of the machine. Call up Maytag at 1-888-MAYTAG (1-888-629824) for more information.
The models included in the class suit are as follows: MLE2000AYW, MLE2000AWW, MLE2000AZW, MLG2000AWW (Gas Stack Unit), MAH3000AAW, MAH3000AEW, MAH3000AGW, MAH3000AWA, MAH3000AWW, MAH3000BGW, MAH4000AWW, MAH4000BWW, MAH4000AWQ, MAH4000BWQ, MAH5500AWW, MAH5500BWW, MAH5500BWW, MAH5500BWQ, MAH55FLBWW, MAH55FLBWQ, MAH6500AWW, MAH6500AWQ, MAH7500AWW, MAH7500AWQ, MAH7550AAW, MAH7550AGW.
on May 06, 2010 | Maytag Neptune MAH5500B Front Load Washer
How do you get to the wate level pressure swith on a maytag neptune front load washer model #mah55flbww
First make sure the washer is unpluged. Remove the two screws on the back side of the top cover. Then you can slide the top cover off by pushing backwards and lift. Now you will expose the controls. One of the controls on the right side of the washer that has a clear 1/4 tube hooked up to it is your pressure switch.
Jun 07, 2014 | Maytag MAH6700AWW Neptune Front-Load...
I have Neptune clothes washer model number MAH55FLBWW. Do you know what its capacity is? 3.8? 4.0? What????
First of all, do you know there is a class action suit against maytag on this machine?
See this pdf file.
http://www.maytagfrontloadsettlement.com/pdfs/notice.pdf
From what I have read, you have a 4.0 cu. ft. machine.
Nov 25, 2010 | Maytag Neptune MAH5500B Front Load Washer
Need to know what light bulb to use in Maytag Nepture washer
how do I get to the light bulb on the Maytag Neptune front load washer, to change it?
Feb 06, 2010 | Maytag Neptune MAH5500B Front Load Washer
The belt keeps coming off my maytag washer mo. mah55flbww. tub bearing seem good motor seems ok
That is a tough one, especially since you indicate that the bearings are okay. The belt not wanting to stay on a Maytag Neptune washer usually does not bode well. It is usually an indication that the drum bearings are shot. Look for brown splatter on the back of the drum and the inside bottom of the washer. The presence of any brown discoloration is a pretty good indicator that the bearings are going. Anyway, hope this helped, sorry for your problem, and best wishes.
Jul 27, 2009 | Maytag Neptune MAH5500B Front Load Washer
MATAG NEPTUNE WAHER LEAKS FROM FRONT DOOR
hi there,
base on your problem, and other like what you say they changed the seal gasket of the door to avoid the water from spilling or leaking on the front door.
Hope this initial info helps.
Jun 04, 2009 | Maytag Neptune MAH7500A Front Load Washer
We have a Maytag Neptune washer Model # MAH4000 AWW it is leaking from the front at the bottom of door. Water pours out like a water fall when it wants to rinse. Any ideas?
TO ELLIESHIRK, I SEE YOU POSTED YOUR PROBLEM ON MAR. 19, 2009. I HAVE A MATAG NEPTUNE FRONT LOADER WASH MACHINE MODEL #MAH55FLBWW. I AM HAVING THE SAME PROBLEM WITH MY MACHINE LEAKING WATER OUT THE FRONT DOOR. MY WASH MACHINE SEAL LOOKS FINE. IF YOU HAVE FOUND A SOLUTION TO YOUR WASH MACHINE LEAK PROBLEM, PLEASE LET ME KNOW, OK. YOU MAY EMAIL ME AT: CJA931@FRONTIERNET.NET , MY WASH MACINE IS NOT VERY OLD EITHER 4-5 YEARS IM GUESSING, IT WAS LEFT WITH THE HOUSE I PURCHASED. THANK-YOU FOR YOUR HELP AND TIME. CONNIE
Mar 18, 2009 | Maytag Neptune MAH7500A Front Load Washer
Nd error essage
nd= no drain. loud buzzing noise sounds like something stuck in pump assy.remove the door(2screws) adn other 2 screws oppisite side, and hte front panel comes off giving you acess to the drain pump, pull the hoses and look for the obstruction
Mar 14, 2008 | Maytag Neptune MAH5500B Front Load Washer
Maytag Neptune MAH5500B Front Load Washer Logo
261 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
