Question about Phantom The Compact Size Scooter - Red Color
How the this unit break down for travel? - Phantom The Compact Size Scooter - Red Color
  • 692 Answers
Mpl goto to this web site www.spinlife.com > Mobility Scooters > 3-Wheel Travel Scooters - Cached and you will see at the bottom right a video for assembly view that video and it should help you break it down for travel Hope this helps
Posted on Oct 01, 2010
Horrible break pedal.
Is there any grinding? You may need new front brake pads. I might also have the brakes bleed for there may be air in brake line. Thank you and Please leave feedback
Jul 11, 2016 | 2006 Mazda 3
My break light swithes on sometimes without me even pressing the breaks. The break light also sometimes stays on even when I have taken my feet off the break. I have tried changed the break light switch...
Did you adjust the brake light switch correctly? To adjust the brake light switch, first press the brake pedal down a few inches, then pull the switch plunger rod out of the switch toward the brake pedal arm, as far as you can without using excessive force. Next, return the brake pedal to the pedal stop position against the pedal stop and pull the brake pedal toward the rear to push the brake light switch actuating plunger rod into the switch housing limited by the travel of the brake pedal arm rear travel stop position. This procedure automatically adjusts the brake light switch correctly.
If the brake lights still don't turn off with the brake pedal released, check the brake pedal arm for sticking or binding that is preventing the brake pedal arm from returning fully to the pedal stop when the brake is released.
Feb 21, 2011 | 2002 Audi A4
I have a craftsman 3/4 garage opener. When it is traveling down it will contuniue past the adjusted stopping point and keep going untill it runs out of track and then travel back up.. It seems to only...
It sounds like your door is traveling just a bit too far in the down direction. Locate the 'down limit' adjustment on the side of your motor unit and turn this control a bit in the opposite direction of the arrow printed on the cover. Some tweaking will then be necessary to get it just right.
Oct 13, 2010 | Sears Craftsman LiftMaster Chamberlain...
The opener seems to want to continue closing the door once it hits the ground. Seems like the closing mechanism needs to be adjusted back closer the the garage door closer unit. This did not just...
Try to re-program travel and force limits. Make sure that travel limit (down) does not go too far (thus excessive force). Apparently this system has a force sensor that senses if there is something in the way of the door. This is different from the safety sensor "eyes". The problem in your setup is that you have programmed the door to travel down too much and he system looses its ability to use force sensor. Adjust travel limit (down) to a little less travel and you will be fine.
Jun 18, 2010 | Chamberlain 1/2-HP Whisper Drive Belt...
My sewing machine keeps jamming and the needles keep breaking
maybe it sounds like the feed dog is out of alignment, and the needle hits when it travels up and down breaking the needle
Dec 05, 2009 | Kenmore 12912
Can u lay a rear screen 52inch projection tv down for travel
Absolutely. The biggest danger is the mirror breaking which is in the big bulge at the back of the set. If the set got bounced around it could break. You're probably best to lay it on it's face on a blanket.
Apr 27, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Garage door won't close
your door travel screw is set to go too far on the downward travel. you need to set the down travel. It is set to go too far down. find the screw adjustment on the unit that says close and back off the screw a full turn until door stops short of floor. then start turning screw other way until door just touvhes floor.
Feb 24, 2008 | Sears Craftsman LiftMaster Chamberlain...
Feedback problem
Gordonshere
Is there a spot you can install the Garmin that will reduce the heat build up within it? I've noted some audio issues (however not a loud high pitched sound) when my Garmin gets too warm from direct sunlight baking it (along with it's own internal heat build-up) I get a crackly, nasty sounding voice that goes away if I cool the unit down. I've since put mine on a stalk between the front seats out of direct sunlight, heater outlets and away from other audio output devices (heat and RF sources) and have eliminated any audio break down. Before I isolated the unit, allowing it to stay as cool as it could, I also noted that when one of my units gets very warm it would also drop satellite connection. Because of the delay you're experiencing (15 minutes) it sounds like a heat build up issue for you as well.
Dec 03, 2007 | Garmin StreetPilot c550 GPS Receiver
Phantom The Compact Size Scooter - Red Color Logo
70 people viewed this question
Top Phantom Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Phantom Health and Beauty Expert? Answer questions, earn points and help others
