Question about Genie Company GV150 Wet/Dry Vacuum
Using my wet/dry vac - less than 5 hours on the thing - it just stopped - can't get it to switch back on. Tried different plugs - different days. Although I purchased over 2 years ago, it has hardly been used. Can it be salvaged?
  • 1,040 Answers
It may have gotten hot if you went too long before cleaning the filter. It sounds like you may have burnt it up. I hope not! You might also check to see if you tripped a breaker on the electrical panel. Try plugging it in an outlet that is not on the same circuit. If it works in another outlet, then you have just tripped a breaker.
Good Luck!
Jim
Posted on Oct 01, 2010
Testimonial: "Thank you!"
  • Jim Parker
    Jim Parker Oct 01, 2010
    Thanks for the rating
Can I use shop-vac without bag 5gal5.5 hp
If you are using it for wet pick up, you would not use the bag. If you are using it for dry pick up, I would recommend using the bag to keep dust from going thru the vacuum and back into the area you are trying to vacuum.
Apr 06, 2014 | Shop-Vac Corporation Shop Vac Wet & Dry...
My rigid shop vac 4 gal 5.0 WD4070 wont start
Check elecrical connection, or switch may be bad.
Apr 14, 2013 | Ridgid Wet/Dry Vacuums Wd4070 4 Gal...
My Shop-Vac 5870400 was working just fine, and then one day while i vac the floor its just stop working, tried to turn on/off a few times, swicth to different outlet. i did even tried to open it, but found...
Same thing just happened to mine. My solution is to get another one but a different brand. I think it should have lasted longer than four years of fairly light usage. From what I read, if it does as we both described, the motor is shot and not worth replacing.
Feb 18, 2011 | Shop Vac 587-04-00 Canister Wet/Dry Vacuum
Older model shop.vac parts/owners manuel
Hi, I know on my Craftsman shop vac 2 different sizes of vacs that I use, I try and stick to the craftsman filters, but you can use other brands if they are not available or you want to save some ( $ ) ? As far as a manual for this vac, more then likely you will have to go to the maker and distributor as Sears, O.C.Hardware also sell there products. You may have to go with a manual that is the same peak H.P.and gallons that covers all different makes and models. Filter wise, make sure you have the right ones on or off when using the wet or dry pick-up settings.
Sincerely,
Shastalaker7
Jan 23, 2010 | Craftsman 17765 Canister Wet/Dry Vacuum
Dry/Wet vac is blowing instead of vaccuum
Check to see if the plastic ball is stuck . There should be a ball under the motor , make sure it moves freely. Make sure your vacum lines are not plugged . Best of luck Ed.
Jun 18, 2009 | Shop Vac 584-06-00 Canister Wet/Dry Vacuum
Craftsman shop vac no power when turn on
I just picked up a similar model someone was throwing away. turns out there is a thermal fuse inside the motor housing that blew. I just need to find the values of the fuse and repalce with appropriate size. motor runs when fuse is bypassed.
Apr 14, 2009 | Shop Vac 925-09-62 QSP Plus Wet/Dry Vacuum
Shop vac sucks water for a few seconds then it spits it back out
Don't use the paper filter for sucking water. It can ruin it. It will still be usable if you just set it out to dry but there is no reason to use it for water in my experience. I have a sears shop vac and it will fill up more than half full without ejecting the water.
Dec 22, 2008 | Shop Vac 925-13 Canister Wet/Dry Vacuum
Wont turn on
Could be a switch or the power cord. Most likely the motor went bad.
Jan 10, 2008 | Hoover F5866-900 SteamVac Deluxe Wet/Dry...
Genie Company GV150 Wet/Dry Vacuum Logo
227 people viewed this question
Top Genie Company Vacuums Experts
Michael Vincent Cruz
richie46
Are you a Genie Company Vacuum Expert? Answer questions, earn points and help others
