Question about Garden
I have a slow-starting f555rc stihl weedeater. Is there a manual online for making gas feed adjustments?
    Scholar:
  • 150 Answers
There are probably limiters on the adjustments.(epa). If not 1 turn out on low speed 1and a quarter on high speed. Never adjust for max rpms this will lean it out.(could burn it up).
Posted on Oct 01, 2010
Carb settings for Stihl FS160
Here's a link to your owner's manual,look at page 26 for carburetor adjustments,I have 3 stihl's,a blower,weedeater and chain saw,had them a long time,never had to adjust the carb.What problems are you having?Clean your air filter or replace it if's real dirty and can't get clean,use 50;1 regular unleaded gas and oil mixture,put a new plug in it,same as you were using,Autozone has them cheaper than the Stihl dealer.Are you using your choke and throttle correctly when starting?On mine,I set the throttle,lock it in,put choke on close,pull a few times,no more than 5,then open choke and pull,it should start,is your spark plug getting oil-gas on it,if so then your flooding it at start up,use fresh gas mixture.I wouldn't adjust the carb. https://www.stihlusa.com/WebContent/CMSFileLibrary/instructionmanuals/FS160_180_Manual.pdf
Jun 14, 2017 | Stihl Garden
Wher can I find a free shop manual for stihl fs 110 r
Do you mean the operators manual, or the parts manual.?
http://www.mediafire.com/download/crnkf8e983bccx5
If you find this is what you're after, please click the 'helpful' tab
If its the owners manual you require, please get back to me.
May 21, 2016 | Stihl Garden
Does a stihl weedeaters have primary & secondary windings in their coils ?
which model.?? I have all the parts manuals so will gladly help with a little more info
Apr 22, 2016 | Stihl Garden
Spark plug gap on a stihl leaf blower shoulder strap
.0020 is the gap.Here's a link to your manual,it's listed in section 26,specifications. http://www.stihlusa.com/WebContent/CMSFileLibrary/instructionmanuals/STIHL-BG-56-66-86-SH-56-86-Owners-Instruction-Manual.pdf I also had a B56C and after 2 years,the engine locked up,am very disappointed in these ,also have a weedeater that the carb had to be rebuilt twice,if you leave gas in them over the winter,it messes up the carb,we'll I threw the blower away,got a huskvana from lowes,it is awesome,Stihl has let me down,will never buy another one,guess your having problems now,want to buy my weedeater and 500 chain saw.lol.
Aug 08, 2015 | Stihl Garden
I have a Stihl FS 90 Weedeater and the gas will not prime on the plastic bubble. The plastic bubble is in excellent condition. It may be missing a seal but I can't find a parts list online that gets into...
Had the same problem, dealer replaced the carburator, and claimed it's because of the gas. Only a year and a half old, and used less than a dozen times. Will not buy Stihl again!
Jun 09, 2010 | Garden
Poulan weedeater will only run with choke half way on
this could one or a combination of a few things
1 check inside the tank for dirt 2check that the filter screen inside the tank is not plugged3 make sure the gas feed tube is not restricted pinched in the case or kinked also you can try a simple carb adjustment.also check to make sure the plug is gapped to the right specs good luck and i hope one of these suggestions do the trick
May 02, 2009 | Poulan/Weed Eater No. Bvm200le 711482 24cc...
Stihl weed eater runs 2min. then stop
Stihl weedeater was running and stopped suddenly. Put in a new fuel filter and cleaner air filter with soap and water. Checked spark plug and it appeared fine. Started the weedeater, ran for a second or so and stopped. Spark plug wasn't gas fouled. Could it be the carburetor needing new diaphram gasket and spring.
Apr 23, 2009 | Ryobi Garden
STIHL FS110R weedeater won't start, does not hit at all. Cleaned plug, spark arrester and air filter, what's up? Like new!
my son flooded out my stihl weedeater, I took it had a new filter put in and it started right up. he went to use it again and now it wont start! It sat overnight and i still can start it! Any suggestions please
Mar 11, 2009 | Garden
Stihl FS85 Weedeater
I suspect carb. trouble. Is the compression OK? Look at the spark plug after trying to start it. If it is wet, you are getting too much fuel. The white smoke indicates that. You may need to overhaul the carb.
Go on the Stihl site and customer service for information.
Sep 17, 2008 | Garden
Garden Logo
286 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
