Question about Simplex Kaba Ilco Unican 1000 keyless lock
I have a kaba lock on a gun safe the battery got low i change it. the key pad beeps one time when i plug the battery in and thats it. i tried three different batteries the key pad has no response help please.
2 Suggested Answers
  • 963 Answers
SOURCE: my kaba gun lock will
I don't have a direct answer, but Kaba customer service can be reached here:
http://www.kaba-ilco.com/access_control/support_contacts/service_and_support.aspx
Tech Support from this link:
http://www.kaba-ilco.com/access_control/support_contacts/technical_support.aspx
Posted on Mar 06, 2011
GETTING IN A SAFE
You really have no choice but to break in or call a locksmith.
Sep 23, 2016 | Liberty FatBoy Jr. LFJ48 48-Gun Safe,...
How do I change the battery on a winchester gun safe door?
Winchester uses several different brands of locks. You need to be more specific as to the lock that is on your safe. However, most batteries are contained in a housing on the under side of the code entry pad.
S&G batteries are usually removed by simply pulling slightly forward on the tab on the housing on the base of the lock. The housing will then drop down and you can change the battery.
Some locks will actually have the battery contained inside the code entry pad housing which can be removed by grasping the entire key pad housing and rotating the housing a few degrees counter clockwise, and then pulling the unit straight toward you.
Some locks may require you to remove a screw, but most do not.
A more specific description of which lock is installed in your safe will allow for a more specific answer. A picture also helps.
Mar 01, 2015 | Optics
I have the key I know the3 combination but still i could not open because it's in low battery
if you know the battery is low then you need to open your safe using the keys and then change your batteries as the safe won't open using your 3 digit code if the batteries are low.
Jan 03, 2013 | Safe International Digital Electronic Safe...
Need to change lock code on a gun safe
In the case of a lost combination, Kaba Ilco recommends that you call their technical service department:
"This is a lost combination situation.
Please call our Technical Service Dept.
For further information at (800) 849-8324
or (336) 725-1331."
They are located in North Carolina, so the best time to call is probably during east coast business hours.
Good luck--and please provide feedback if this helps!
Jun 01, 2011 | Simplex Kaba Ilco Unican 1000 keyless...
My kaba gun lock will not open i put new batteries in it i have tried 3 different one but nothing will work. i try to punch in my code and it just peeps at me and i can not get into m gun safe.
Mar 01, 2011 | Simplex Kaba Ilco Unican 1000 keyless...
Just put new batterys in safe . but safe will not stop bleeping what is the problem
Please follow these steps
Programming a user code
There are two ways to program a user code.
A 1. Press the Program key.
2. Enter the Factory Code. The green LED remains ON
while you enter the 5-digit user code of your choice.
After 5 digits are entered the green LED turns OFF.
(To enter a new User Code, repeat these steps.)
B 1. Press the red button inside the safe. The lock will
beep and the green LED will come on.
2. Enter a 5-digit user code.
Keep your new user code secure.
For your records, please copy it here:
____ ____ ____ ____ ____
Programming a password
2. Press it a second time.
3. Enter your 5-digit User Code. The green LED remains ON.
4. Enter the 5-digit Password of your choice (any combination
except 00000.) After 5 digits are entered, the green LED
turns OFF.
(To enter a new Password, repeat these steps. To erase the
Password, press Program twice, enter your User Code and then
enter 00000.)
Battery replacement
Below When old batteries are removed for replacement, your Password will be voided; only Factory and User Codes will work. To
reestablish your Password, follow the directions above under
Programming a Password.
Key override
If your electronic lock fails or you do not have any codes
available, you may use a key override to access this unit.
1. Remove the battery cover, disconnect and remove the
battery holder.
2. Insert the skeleton key (second set of keys provided)
into the key hole inside the opening for the battery.
3. Turn the key to the right.
4. Turn the four bit key to the right.
5. Open the door.
Signals
Your electronic-lock safe communicates by means of several
audio/visual signals.
Red (Error) LED + three beeps indicates
one of the following:
1. You have pressed Program key out of sequence
2. You have entered an invalid code or password.
3. You have let 5 seconds or more elapse between key entries.
Green (Proceed) LED + single beep occurs
1. After entering each digit of Factory or User Code, or
Password
2. After pressing Clear key
3. After pressing Program key
Green LED only
1. Comes on after you enter a valid code/password and
remains lit during the 4-second period in which the safe
can be opened.
2. Comes ON in the Program User Code mode after you enter
the Factory Code and remains lit until you have finished
entering a 5-digit User Code.
3. Comes ON in the Program Password mode after you have
entered your User Code and remains ON until you have
entered a 5-digit password.
Yellow LED
Indicates low battery and will typically not turn ON until
battery has been in use approximately two years or longer.
Your electronic lock automatically performs a low battery test
during each lock use.
If a �low battery� condition is detected the Yellow LED will
come ON and remain ON during each subsequent lock
operation. (The lock will continue to function in a Low Battery
state, until battery failure.) The Yellow LED will turn OFF only
after three consecutive Good Battery readings or after the low
batteries are replaced. (Note: If the new batteries are installed
in less than 60 seconds the Yellow LED may come ON and stay
ON during the first lock operation before it returns to OFF.)
NOTE: It is recommended you replace the batteries after two
years, or when the yellow LED remains on.
Jan 09, 2011 | Safe International Electronic Digital Safe...
Batteries are dead and I've lost the keys. Its an old electronic digital safe and I have the key number that goes with it. Know where I can get replacement keys or if its cheap enough to have...
Only through a licensed locksmith. Provide the key numbers and possibly even take the safe to him/her as proof of ownership. Locksmiths have to record all attemots to open safe's or maling f keysto the police.
Please provide a rating for my help++++Thanks for using FIXYA
Jun 15, 2010 | Safe International Digital Electronic Safe...
Battery low and I can't get it open. Where does the key go?
The batteries are on the inside of the safe. It takes 4 AA batteries. The key lock is under the plastic to the left of digital key pad
Jun 18, 2009 | Check Point Network Adapter
Lost instructions for sandleford E.S.20 safe
The operating instructions on the ES20 as per the crappy manual:
Open safe using emergency key provided
Insert batteries in the box inside the door
Opening the safe
a. pre-set factory code 159
b. input 159 (the yellow light will flash and the buzzer will beep), then press B or A button, the green light will be on, rotate the knob clockwise, pull outwards, the door is opened
Closing the safe: close the door, input the code (the green light will flash for 5 secs). Turn the knob anti clockwise, the control system will activate and the safe will be locked
Changing the code: open the safe, press the red button located inside the door, the yellow light will go on indicating the code can be changed. Input the new code (1-8 digits), then press A or B button, it shall be confirmed by two beeps indicating the new code has been accepted and stored. If the yellow light and buzzer beeps 3 times the code is invalid - try again
Emergency Key - store in secure place NOT inside the safe. Remove the override cover in the centre of the face of Safe (its a silver plastic panel with Sandleford Electronic Safe ES20 on it), insert override key (a cyclinder key) - hidden underneath the override cover panel - and turn anti clockwise, rotate the knob clockwise to open door
Changing the Battery - If the red and green light are on this indicates that the batteries are low and require changing. To ensure the batteries have been installed correctly test before closing the door
References:
1. Operating instructions EA Electronic Safe
2. http://www.secustar.com/products-en/estype-safe.htm
Jan 09, 2009 | Sentry Fireproof Safe
I locked my key in the safe and I CAN'T REMEMBER THE CODE THAT THE MANUFACTURER GAVE YOU WHEN YOU FIRST PURCHASE IT. psf80 PRO-SAFE ELECTRONIC DIGITAL SAFE
Press 159 - safe will beep for each number pressed on the key pad, Then press A or B, the green light will come on. Rotate the knob clockwise and pull the door open.
Aug 18, 2008 | Office Equipment & Supplies
Simplex Kaba Ilco Unican  1000 keyless lock  Logo
174 people viewed this question
Top Simplex Locks & Locksmithing Experts
Michelle Balcom
JonSnell Electronic
JonSnell Electronic
Are you a Simplex Lock and Locksmithing Expert? Answer questions, earn points and help others
