Question about Homelite Garden
Oiler doesn't work on my homelite 180 classic. all the lines seam to be clear. i have not found any blockages anywhere
4 Suggested Answers
  • 4088 Answers
SOURCE: Homelite XL, UT 10618-A, 14
Likely problem with oil pump or it's drive gear.
Posted on Jul 04, 2009
dontbother10
  • 2220 Answers
SOURCE: auto chain oiler doesn't work homelite temberman 45
Oil System Plugged:
  1. Remove the clutch cover, bar, and chain, clean the bar groove, any holes and passages on the rear of the bar (both sides, consider rotating the bar), if equipped with a sprocket nose ensure it rotates easily at least one complete revolution. Clean the saw oiler hole and channel. Insert a blunted, hooked piece of wire through the oil filler hole and pull the hose in the oil tank out. Pay attention to the screen or filter on the free end (clean or replace, difficult to determine serviceability). Start the saw and see if it oils when revved up (oozes down side of saw). If yes reassemble your saw. If no, continue with 2.
  2. Work your way through the linkage (use IPL to identify components and locations) cleaning and replacing any defective parts as you go. Carefully check the hoses for cracks especially at bends and connections. If equipped with an oil pump it is usually behind the clutch (clutch is a left handed thread). Please make extensive notes & some digital pictures will help during reassembly.
If it does not oil on completion of 1 it is most likely a bad oiler or worm gear (see IPL).
Timberman 45 does not cross to an IPL I can find. If you can find an IPL it really simplifies disassembly/reassembly, provides component locations and component part numbers. Without the correct IPL I would not undertake a repair.
Homelite/Ryobi.com (authorized parts supplier)
https://www.gardnerinc.com/recons/disclaimer-lg.php - Agree; Choose “Product Line”; “Select OEM” & “Select Catalog” both to “Homelite Consumer Products”. A drop down list appears; self explanatory from here.
The numbers Homelite & Ryobi use do not match the numbers everyone posts. A careful inspection of your saw should find something that matches.
If you have more questions or need additional help please reply below and I will get back to you. Thank you for using FixYa and Good Luck. HTH
Lou
Posted on Mar 14, 2010
  • 2468 Answers
SOURCE: how to tighten a chain on homelite 180 classic
loosen the bar bolts in front of the power head and pull bar outward till you have very little slack in the chain,then re-tighten the bar bolts
Posted on May 10, 2010
I need to remove the automatic oiler in my homelight chainsaw z3850b
Chainsaw Oil Pump Replacement - Homelite ... - YouTube
? 5:57
https://www.youtube.com/watch?v=8dj0Voh3TTM
Jan 21, 2014 - Uploaded by RepairClinic.com
The most common reason for replacing the oil pump is ... ...Chainsaw Oil Pump Replacement - Homelite Chainsaw Repair (part #309514001) ... spark plug wrench, cord, clutch removaltool, adjustable wrench, needle-nose pliers ... The chainsaw guy shop talk Repair Homelite 150 chainsaw Auto Oiler ...
How to Repair a Homelite XL Chainsaw Oiler - Home Guides
homeguides.sfgate.com > Real Estate Advice > Basic Real Estate Advice
The Homelite XL chain saw is designed to use one tank of oil per each tank of fuel. Fill the oil ... Push the guide bar toward the saw, and remove it and the chain. Clean the ... Automatic Oiler and Oil Line Replacement ..... My Ridevisit'Cars-My
Dec 21, 2015 | Garden
Old Remington SL4 Automatic Oiler
Found a website with all the equivilant homelite XL12 illustrated parts lists. You may need to look down the list to find the exact match.
Jul 27, 2013 | Remington Garden
Oiler doesn't work
check the oiler worm gear and make sure it is in good condition and that the arm isn't loose or the tip broken off
If you need further help, I’m available over the phone at https://www.6ya.com/expert/kelly_69a0cf1b13789df1
Oct 12, 2012 | Stihl Garden
My homelite chain saw is not getting oil on the chain from the automatic oiler?
either a faulity oiler or oil lines cloged try using compresed air to clear the lines by blowing in the oil tank
Nov 15, 2011 | Garden
How to adjust automatic oiler on 455 husqvarna
I'm sorry, but I'm not aware of any adjustments that can be made to the oiler. Just make sure the ports are clean so that the oiler doesn't get clogged and that the oil lines are all clear and you should be good.
Nov 13, 2011 | Husqvarna , No.455 Rancher, 20" Gas -...
I just received a Recon unit of the Homelite model ZR10580 chain saw. Is there a bar oiler adjustment on the model ZR10580? In my opinion the oil delivered is excessive - oil drips from the bar.
Homelite/Ryobi.com
The numbers Homelite & Ryobi use don't match the numbers everyone posts. A careful inspection of your saw should find something that matches.
Once you find and open the IPL. If it has an oiler adjustment there will be an oiler adjustment screw listed. CW is usually less oil, make small adjustments of no more than ¼ turn. I suggest you contact them and check your Operator's Manual before making any adjustment. HTH
Lou
Nov 22, 2009 | Homelite Garden
Oiler not working
Had you provided the model number we could have provided a more complete answer. What little oil system routing detial there is resides on the IPL. It can be found here:
Homelite/Ryobi.com
Oil System Plugged.
Remove the clutch cover, bar and chain. Clean the oiler hole and channel. Start the saw and see if it oils when revved up. If yes reassemble your saw.
If no a blunted, hooked piece of wire can be used to pull the hose in the oil tank out. I recommend the filter be replaced. Work your way through the linkage cleaning and replacing any defective parts as you go. Carefully check the hoses for cracks especially at connections. If equipped with an oil pump it is usually behind the clutch (probably left handed thread). Please make extensive notes & some digital pictures will help during reassembly. GL
Lou
Sep 30, 2009 | Ryobi Factory Reconditioned 18" 40cc...
I cant get oil to the chain on my husqvarna 345.
You may have a problem with blockage in the oiler system somewhere. Try emptying out all of the bar oil and swishing some gas around in the bar oil tank to clean it out. This will work some of the time. Sometimes you have to take the oiler off and blow thru the lines into the tank,( make sure the oil fill cap is off) and blow into the oil tank out thru the line to clear out any debris . The adjustment for the oil pump should be on the bottom of the saw. Here is the manual with the procedure on page 32 of the manual. Hope that helps you.
http://weborder.husqvarna.com/order_static/doc/HOUS/HOUS2004/HOUS2004_1140235-95.pdf
Jun 12, 2009 | Husqvarna Forest & Garden No.967012396 345...
Ryobi Chainsaw - PCN 4545
Ryobi boasts a two year warranty. Have you contacted anyone about a warrantied repair?
An IPL (expanded parts list) for your saw with any oil system detail can be found here:
Homelite/Ryobi.com
Oil System Plugged.
If no a blunted, hooked piece of wire can be used to pull the hose in the oil tank out. I recommend the filter be replaced. Work your way through the linkage cleaning and replacing any defective parts as you go. Carefully check the hoses for cracks especially at bends and connections. If equipped with an oil pump it is usually behind the clutch (clutch is probably left handed thread). Please make extensive notes & some digital pictures will help during reassembly. GL
Lou
Aug 22, 2008 | Makita DCS6401 20 20",64cc Chainsaw 2...
Garden Logo
145 people viewed this question
Top Homelite Garden Experts
Jim Parker
Jim Parker
roeb
Mike Squire
Are you a Homelite Garden Expert? Answer questions, earn points and help others
