Question about Whirlpool LHW0050PQ Front Load Washer
Mildew accumulation within the gray rubber part of my LHW0050PQ washer. How can I clean it?
  • Whirlpool Master
  • 43,501 Answers
Here is a tip about how to clean your washer
Howto have a Clean Washer
heatman101
Posted on Oct 01, 2010
Kenmore 3.5 washer has developed mildew around the inside lip of the rubber surround. It has always had a terrible odor. I have used bleach to kill the mildew and now leave the door open. What do you...
The first thing to do is to CHECK IN AND AROUND THE RUBBER DOOR BOOT (called a bellow) for small articles of clothing (like socks and underwear) that may have gotten lodged in behind the rubber. Pull the rubber back where it meets the wash tub and look behind it. It is common for small items to get stuck here, become forgotten and start to mildew. You should check this area after each wash and clean it periodically to get rid of the formation of soap scum, mold, and mildew. HINT: When you get ready to wash a load of towels, take a dirty towel and clean the door boot thoroughly (including the areas behind the rubber). Immediately place the towel in the wash and run it on a sanitary cycle. This way you eliminate the need for cleaning rags.
PERIODICALLY RUN THE WASHER ON A CLEANING CYCLE. Place the washer on the hottest setting you have (usually a Sanitary cycle) with nothing but bleach in the wash tub. Some newer models actually have a "Clean Cycle" available now just for this purpose. This helps keep the wash tub, drain lines and pump sanitized.
CHECK AND CLEAN THE DRAIN PUMP FILTER. Accumulations of debris in the drain pump filter can also cause odors. HINT: If you own a shop vac, pull the drain hose from the standpipe at the wall and pull a vacuum on the line. This will drain any residual water left in the tub, pump and drain lines BEFORE you remove the drain pump cover. This will prevent a messy clean up later.
LEAVE THE DOOR OPEN IF POSSIBLE. When not in use, leave the door open to allow the tub to air out and to keep mold and mildew from forming on the door bellow. I know this may not be desirable in some households with small children. If too much mildew forms on the rubber and it cannot be removed, replacement of the bellow may be required.
NOTE: This problem is common with front loader style washing machines. The doors on these machines have an air tight/water tight seal that is great for sealing the washer during the wash cycle, but can be terrible for collecting small garments and for not allowing the tub to properly air out when not in use. Following these simple preventive measures can go a long way towards preventing harmful mold and mildew, and towards extending the life of the door bellow and pump.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.$$$$
Aug 02, 2010 | Kenmore 3.5 cu. ft. Front Load Electric...
Whites are grey
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.@@**
May 23, 2010 | Maytag Neptune MAH5500B Front Load Washer
Washer Odors of Mildew
Apr 12, 2010 | Whirlpool Duet GHW9150P Front Load Washer
I have a mildew smell within the washer and have
Leave the door open all the time and it will dry out and the mold and smell will subside.
Mar 15, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Maytag Neptune Superstack water accumulation and odor
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.!!%5
Jan 27, 2010 | Maytag MLE2000 Front Load Stacked Washer /...
I can not get rid of a mildew smell in the washer. I have cleaned the rubber tubing around, I have also used the tablets to eliminate mildew in washers - did not work
Oct 13, 2009 | Kenmore Washing Machines
Hi--I love my Whirlpool Duet washer, but how do I clean the door gasket and get rid of the mildew and mildew odor?
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.((((())))
Sep 28, 2009 | Whirlpool Duet GHW9150P Front Load Washer
I have sour mildew smell problem with my clothes
Look inside the door to the gray rubber ring gasket thingy. Pull apart the sides and look in. Betcha a dollar to a donut there's mold in there. It's a gross, nasty problem whirlpool customer service doesn't give a damn about.That's where water sets after wash cycles. There are tablets call "Affresh" which can be run with hot water for a cycle to attempt to clean out the mold/mildew. Not cheap, not fair, and probably will only be a start to a maintenance type cure if you've had the washer for awhile. May take some manual labor with bleach as well. NOT a sanitary washer. This is an unbelieveable problem with a washer. Piece of ****.
Aug 06, 2009 | Whirlpool LHW0050PQ Front Load Washer
Washer smell
Apr 06, 2009 | Kenmore 24032\24036 Top Load Washer
GE WASHING MACHINE GE PROFILE
There is a product out there called Affresh. It is a tablet that can be used on all front loaders that do not have a Clean Cycle. It works great. It comes three tables to a bag. You should use all three the first time that you do this. After that, once a month is all that is needed. Two suggestions to help eliminate the smell and mildew. One, keep a wash rag handy and wipe up any water that remains in the door seal. Second, leave the door open for a day so that the washer can air out. This applies to all front loaders, not just GE, that do not have a Clean Cycle. Also, water sometimes stays in between the inner and outer tub. This water can become stagnant and create mildew, mold, and odor problems. I hope this helps!!! -The Appliance Braniac
Apr 07, 2008 | GE Energy Star WCVH6260F Front Load Washer
Whirlpool LHW0050PQ Front Load Washer Logo
Dan Webster
Dan Webster
Sal De
