Question about Gestetner DSc460 Copier
Color registration error - Gestetner DSc460 Copier
Put out image transfer belt and chek the belt and the registration sensors(music)
this problem can happened if the density of c-m-y colours are low!!
Posted on Oct 27, 2011
Error code P-21 showing on the screen, printing picking up cyan background. What is reponsible?
Color registration problem is P 21. Need to do a color registration procedure.
May 17, 2016 | Konica Minolta Minolta C224 Copier
How do fix error Color registration could not performed
Possible remedies for weak images.
-Loose connection between transfer roller and high voltage supply unit.
-Dust in the laser beam path
-Transfer belt not contacting PCU.
Check the transfer unit.
Defective PCU. Replace the PCU.
Defective transfer roller. Repair the transfer roller.
Defective fusing unit. Replace the fusing unit.
Defective engine board. Replace the engine board.
Feb 02, 2016 | Ricoh Aficio SP C410DN Laser Printer
Oki c8600 registration error 3
Registration Error 3
When a color registration error is detected with coarse
adjustment, or with the main-scan line adjustment.
PU firmware does not notify this warning to CU firmware
at the time of Shipping Mode. Therefore, this status
does not occur in a user environment.
n
2 = Yellow
3 = Magenta
4 = Cyan
Dens Shutter Error 2
DENS SHUTTER ERR
Check 3: Check to see whether the sensor shutter opens and closes normally, by the
MOTOR & CLUTCH TEST of the self-diagnostic function. If the shutter operates
imperfectly, replace the shutter unit.
May 06, 2014 | Oki Electric Industry C8600n Led Printer
Error p21
as I said before Color registration is off check the sensor under the transfer belt and mite want to have e tech run color registration procedure. black is the reference for the color registration having developer problems with black drum does not help
Apr 24, 2014 | Konica Minolta Office Equipment & Supplies
Error p-28 konica c353
registration error have tech come out and run the proper registration procedure to align color to the black unit
Jan 09, 2014 | Konica Minolta bizhub 250 All-In-One Laser...
Define 54.18 ERROR code on a Hp Laserjet 5500
According to the HP Service manual, there is no 54.18 error.
The listed errors are:
54.1 Temperature error
Check the fuser. See 50.X fuser error.
54.3 Image density sensor error
Check the connections. Replace the color registration detection assembly.
54.5 Colour registration sensor error
54.6 Image density error
54.7(Y), 54.8(M), 54.9(C), or 54.10(K) Drum phase sensor error
Check the connections. Replace the drum phase sensor for the indicated color.
54.11(K), 54.12(C), 54.13(M), or 54.14(Y) Toner sensor error
Check the connections. Check the cartridge and replace it if necessary.
54.19 Transfer Belt error
Check the ETB connection. Replace the ETB. Replace the DC controller.
It is most likely that you have a faulty Toner Cartridge.
Jun 21, 2010 | HP Color LaserJet 5500 Printer
Error code: color registration error and ultra-light, smudged printing on right side of paper
have you replaced all of the consumables?
drums X2 black and color
developer units X4 CMYK
transfer imaging belt X1
Fuser unit X1
if the unit has over 60k prints it will need to have these items replaced and once that is done the color registration will come back inline.
Jul 28, 2009 | Ricoh Aficio CL3500N Laser Printer
LED reads color registration error
The black along the side of the paper is usually the black photoconductor , it also could be the fuser. If the color reg says can't be preformed it probly needs a new transfer belt. If the color reg completes and the colors still don't line up it might be the laser. It also could be dirty reg sensors.
Mar 24, 2009 | Ricoh Aficio AP3800C Laser Printer
Tech support
F45-20 Color registration correction
results in abnormality.
Printer control board (PRCB)
Color registration sensor /F (PS8)
Color registration sensor /R (PS9)
May 16, 2008 | Office Equipment & Supplies
Ricoh Aficio Color Registration Error
One of our Ricoh CL3500N printers- less than a year old- gave us a "color regist error" after changing the transfer belt.
Ran the "adjust color regist" without results. It would just finish and pop back up with the same error.
Color test page printed no color, just BW
I reseated everything, and even replaced the PCU without positive results.
A couple hours later I went back, took everything out (be sure to keep the pcus out of the light!), and vaccuumed the heck outta that printer.
For whatever reason- maybe there was a chunk of toner hanging out, maybe I knocked something loose or back in place, whatever- but when I put all the parts in and turned it on, the error was gone and color printed great!
Dec 11, 2007 | Ricoh Aficio CL3500N Laser Printer
Gestetner DSc460 Copier Logo
50 people viewed this question
Top Gestetner Office Equipment & Supplies Experts
Bernard D'Souza
quennie732
OfficeServiceAjnc
OfficeServiceAjnc
Are you a Gestetner Office Equipment and Supply Expert? Answer questions, earn points and help others
