Question about Dell AX210 2 Speakers
Cant get any sound out of speakers and everything is connected
    Genius:
  • 1,189 Answers
Hi, click on the "Start Button," in the (right pane) Control Panel, next in the category listings, select Hardware and Sound, open, and click on the "Manage Sound Devices." The Sound window will open; click on the "Playback" button, there should be a Speakers Icon, click on it, look below to find the "Properties button, click to open the next window. In the next window there will be (4) four buttons "General, Level... First click on the "General" button, in the top of the window there will be a "Driver" button, click on that button to open. Select to "Update Driver," just click on it, the Drivers will be updated for you. Next you can go back and press the other areas, Speaker Level etc... Next if you have a "MIC" do the same for the Microphone as you done for (Speakers) in the [Recording] category. Note: "Remember to click on the "Apply and OK buttons afterward to make sure the changes take effect. "Restart the computer to finalize the changes." "Rate the solution on it helpfulness, its away of letting me know if you resolved the the problem or you need further assistance, thank you."
Posted on Sep 30, 2010
How to splice factory speaker wires on 2004 grand am with monsoon
everything depence of system you putting in your car if u have no amplifire you connecting the speakers to radio as they marked i you putting one in, your speakers wires goes from amplifire to speakers there is no diffrent way of connection. also the diameter of your wires have to be adekwate to power u going to have in your system for optimizing the sound quality let me know if this help ya
Sep 22, 2012 | 2004 Pontiac Grand Am
My denon avr-985 has no sound coming out of it why could this be
Go though your menu on the reciever, Look for the speaker functions for your front end rear speakers ,It was probably turned off. Was it working before you got it from your friend,
Sep 20, 2012 | Denon Avr 985 7.1 Channel 945 Watt...
Sony BRAVIA KDL-40V2500 audio not working
I would Google the model number carefully for "problems" "no sound" and usually this set will display some kind of error code===it may even have a hard reset to try===service manuals are available on the net/web to allow you to see how the sound circuit is set up etc.
Mar 29, 2012 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
I just brought this computer to my house from my girl friends grandmas house speakers and all worked fine now i plugged everything in the the exact speakers that were on it are plugged into it and the...
Assuming something in the computer didn't mysteriously go bad during the move, there are two possibilities. First, make sure the signal cable from the speakers is plugged in to the right place. You may have plugged it into the microphone input or line input jack by mistake. Second, be sure the speakers have power. Most speaker systems require AC power, either from a plug-in adapter or a built-in supply that needs an AC connection. (Some newer systems come with USB-powered speakers that don't need an external adapter.)
A remote possibility is that in the move, the speakers got bumped enough to disturb connections on the circuit board inside. The amplifier chip in the speaker case gets hot (especially if the volume is turned way up), and the heat can degrade solder connections, and sometimes cracks form. The move may have caused connections that were iffy to go bad. But this isn't very likely.
You'll probably find it to be a very simple missed connection. Good luck, and thanks for using Fixya!
Oct 24, 2010 | Dell P4 2.8 GHz (DELLDIMREF1100) PC...
Why wont my sound come out from the speakers you cant hear nothing from the speakers it turns on and everything but no sound
if you have a factory amplifier you have to connect the blue wire from the amplifier plug into the power wire for the player
Jul 14, 2010 | XO Vision XOD1735 Car DVD Player
Cant hear anything out of my speakers connected to djio
Are you using a Mixer as a pre-amp for this set-up? For example, I have a Numark CM200 where I have all of the inputs and outputs I need to run. DJ IO is connected to Chanel 1 and Chanel 2 Lines in my mixer. The DJ IO is conected to my computer by USB cable. In Traktor souncard settings chanel 1 is set to (3&4) Chanel 2 (2&1) also, devise set up is Numark DJ IO and in External mode. Of course the mixer is conected to my amp and speakers conected to the amp as well.
Apr 26, 2010 | Numark DJ/iO Sound Card
Same thing.. no sound.. everything works but no sound
check speakers and speaker wire and connections with a multimeter
Aug 30, 2009 | Crystal Audio THX Center Speaker
Only got sound threw 1 speaker, everything is connected correctly.
were did u get the drivers from my mate as i am in the same sh..
May 27, 2009 | Cyber Acoustics CA-5150 Computer Speakers
I have acer al1917w A monitor but no sound
There is no sound driver, they are speakers, they work off of the audio output jack on the back of your PC, on the motherboard. If you have the sound drivers installed for the motherboard, and no sound, then you have plugged the monitor audio cable into the wrong jack on the PC, or you have the settings wrong just as MIKE said above.
Jan 09, 2009 | Acer AL1917W LCD Monitor
Dell AX210 2 Speakers Logo
152 people viewed this question
Top Dell Audio Players & Recorders Experts
Greg Cann
Greg Cann
Jax Planet
Jax Planet
Are you a Dell Audio Player and Recorder Expert? Answer questions, earn points and help others
