Question about Mackie SWA1801 Subwoofer
Hi I have a problem with mackie swa1801, the thermal protect kicks in intermittently even on low volume levels from cold boot, opening her up shows 2 greens LED lit up internally Diode 9 and Diode 12 on the amp board Close inspection shows serious heat damage around the R7 R8 C5 and Q3 area and also around R56 R57 Q18 area also having a loose electronics knowledge and seeing how burn up C5 was (10pF 500v) I suspect the cap if failing hence the intermittentcy I've already read http://www.fixya.com/support/t5203561-thermal_light_comes_swa1801_lose and am out to buy the listed parts of usual suspects any help greatly appreciated and recomended reading for all audio electronic repair many thanks ndotk
5 Suggested Answers
SOURCE: Mackie srm450 not making any sound at all
It sounds like the thermostat didn't shut the speakers down before they were damaged. There is probably a very fine wire leading to the speaker coils which is burned/broken. Fixing this broken connection my solve the problem unless the coil itself is damaged.
Another possibility is that the crossover circuitry in the speaker cabinet is damaged from overheating.
Sounds like you need a service tech to look at the bad speaker, unless you want to tackle the job.
Posted on Apr 22, 2009
SOURCE: The Amp on Mackie SWA 1501 sparked and burned today
The Mackie SWA 1501 subwoofer is one on the best subwoofers but it's a heavy one. I have it since 2007 and have no problems with it, still working. I would recommend to buy the new SWA 2801z. If you're in germany check this site: Mackie Subwoofer in Cologne
Posted on Dec 20, 2009
SOURCE: the thermal light comes on on my swa1801 and lose
make sure its plugged into a large circuit over 30AMP! Turn down the gain on the back. They can't take too much punishment so turn the bass down on the eq. Get a stronger sub
Posted on Aug 02, 2010
  • 5603 Answers
SOURCE: mackie swa 1801 power amp
You likely have other parts blown as well, but Q3 (MJE15033) AND/OR r8 (1 OHM/0.5 Watt) are blown. I suspect that Q3 has a base-collector short and you will find several of the output transistors are fried as well Q4, Q5, Q15, Q16. I suspect that the Zeners D14, D25 may be blown.
When restarting this, put a 100 Watt lampin series with teh 120 volt power to limit current and avoid destroying freshly repaired parts due to a few bad ones not found.
Posted on Aug 11, 2010
I have two mackie c300z speakers but cut off at
It sounds like protection circuitry is kicking in to protect the speaker from being overdriven.
Oct 16, 2014 | Audio Players & Recorders
Hi. I have problems with my SWA1801. When I try to start the amp, the Thermal light goes on. Even if the amp is cold ! What can it be? I have turned down the gain on the back and have good cables to the...
Power it ON, without anything connected to the input.
If it powers On without the thermal light, then rejoice,
If it powers On with the thermal light it means something...
Oct 23, 2012 | Mackie SWA1801 Subwoofer
Components Q12 & Q13 (2N 3906) PNP transistors fried. Would there be anything else blown?
It is sad your having a problem with Q12 and Q13, check the regulator
that supply voltage on the transistor 's your referring to.
Q13= 2SA1478 for Mackie SWA1501 Active Subwoofer
the supply is about +15V and -15V
Aug 20, 2012 | Mackie SWA1801 Subwoofer
The thermal light comes on on my swa1801 and lose all audio what could be causing this to happen?
Jul 01, 2010 | Mackie SWA1801 Subwoofer
Ould some one send me a copy of that schematic. I
Sorry, not really a solution yet. Just contacted the Belgium Service center. They say they're not allowed to give the schematics. Maybe Mackie is ashamed to show what's in it? Any way, this is all but a good publicity for the service of Mackie
Gerdy
Gerdy's Music Shop
Belgium
gerdy@gerdysmusicshop.be
Nov 07, 2009 | Mackie SWA1801 Subwoofer
How to open SWA1801Z
Please follow the guide given in the link.. there is a chapter on woofer replacement..
http://www.mackie.com/pdf/repair/SWA1801z%20repair%20guide.pdf
--please give your comments..
have a good day
sree
Jul 01, 2008 | Mackie SWA1801 Subwoofer
Mackie SWA1801 NO POWER, NOT TURNING ON
  1. I have blown capacitor in my mackie swa1801, Can you send me schematic g_man001@hotmail.com thanks Georgie.
Feb 24, 2008 | Mackie SWA1801 Subwoofer
MACKIE SWA1801--Sound quality is not same
I suggest, go out and buy a heavier duty 18 and replace it.
Aug 24, 2007 | Mackie SWA1801 Subwoofer
Mackie SWA1801 Subwoofer Logo
298 people viewed this question
Top Mackie Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Mackie Audio Player and Recorder Expert? Answer questions, earn points and help others
