Question about LG DLE2532W Electric Dryer
LG DRYER MODLE DLE0332W
WILL RUN BUT WONT HEAT UP
  • kasbill May 16, 2009
    6 thermostat replacements in 1 year!!! What is the deal?
    Champion:
  • 210 Answers
If it is running, chances are one of the thermostats are gone. You have two on the heater bank, a high level and a safety, have them both changed.
Sgt 48
Posted on May 30, 2008
  • 525 Answers
Check your fuse or circuit breaker box first. Look for 2-30 amp fuses in the fuse box and replace both fuses if using a fuse box. Look for a double pole 30 amp circuit breaker if using a breaker box, and flip the breaker to OFF then back to ON.
If nothing helps get back with me and we can delve deeper into the issue.
Thank you for contacting FIXYA.com
Dave (Illeagle)
Posted on May 29, 2008
My LG Model DLEX3360 dryer will turn on, run about 20 seconds and stop running -- but displays still says it is drying.
Dryer Thermal Fuse Replacement - LG Electric ... - YouTube
? 5:29
https://www.youtube.com/watch?v=b74Mt5sSgRI
Dec 21, 2012 - Uploaded by RepairClinic.com
Dryer Thermal Fuse Replacement - LG Electric Dryer Repair (Part ... The most common reasons for replacing the thermal fuse are when the dryer won't start or ... I have an LG GAS DRYER model # DLGX8001V and it will not ... My front load dryer won'tturn on. .... My LG dryer recently stopped working.Missing: seconds
LG Electric Dryers, no heat? Try this first... - Home Forums
ths.gardenweb.com > Home Forums > Laundry Room
Apr 1, 2006 - I own an LG Electric Dryer model DLE0332W. ... Serviceman: The part you need is a heat regulator and its going to run you about $20 and the labor ... Look into the hole to the left and you will see the Heater Unit right within reach. .... Came back a second time because it still wouldn't dry my clothes (maybe ..
Nov 24, 2015 | LG Dryers
Lg model #dle0332w dryer won't turn open it up
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Jul 29, 2011 | LG Dryers
LG Electric Dryer (DLE0332W) change all thermostats, HEATING ELEMENT, THERMISTOR, MOISTER SENSORS, HOUSE CIRCUIT BREAKER BUT STILL WONT HEAT AT ALL
Hi hamptonmd,
If you have replaced all those parts, and it is still not heating, the problem is most likely the Main PC Board (Comes in 2 parts, front electronic and back electronic)
To test if this is the problem, activate the T/D and test if power is going to the element in cycle, use an advanced current protective multimeter to do this. If no power goes to the element at all, then the PC board is not providing power to it, thus it is faulty.
Hope this helps :-)
If you found this solution helpful, please rate it accordingly :-)
May 11, 2011 | Dryers
DLE0332W--dryer continually runs like its in wrinkle free mode. Will not complete regular dry cycle.
You may have an issue with the control board and it will not shut down once the cycle has been completed. You will need a qualified LG technician to diagnose the problem.
Good luck
Sep 29, 2010 | LG DLE3777 Electric Dryer
LG dle0332w dryer won't turn off automatically when set to Cotton/Towels mode
You may have an issue with the control board. You will need a qualified LG tech to diagnose your problem.
Good luck.
Sep 22, 2010 | Dryers
I have a LG DLE0332W Electric Dryer. I push the
Yes, the motor is bad.
Replacing the motor is a bit involved, but if you want to attempt it I can walk you through it.
There should be a 5 YEARS warranty on the motor, so you might consider a repairman. Make sure they are LG certified and there will be no cost to you for the motor. The labor, however, may be up to you and could be expensive.
I'm willing to assist you on whatever you decide. The motor itself should be under $100.
Best, G
Aug 03, 2010 | LG DLE2532W Electric Dryer
How do I remove the front panel from an LG DLE0332W electric dryer. It is kicking the circuit breaker and I want to check the drum rollers.
Hello alloyd1455,
Please find a link for the service manual for your dryer and note page 26 and up discusses how to open up and gain access to the inside compartment.
Hope this helps
http://136.166.4.200/contents/Laundry/DLE0332/DLE0332_Service_Manual.pdf
Regards,
Rick
Dec 01, 2008 | LG DLE5932W Electric Dryer
LG Front loader Electric Dryer want heat but will run and spin
If your dryer doesn't heat, check these:
Power from the house
Heating element
Thermal fuse
Wiring
Power from the house Check to see whether there's power getting to the dryer. Is it plugged in? Check for blown fuses or tripped circuit breakers--your dryer uses two fuses or circuit breakers. The dryer could tumble but not heat if only one of the two fuses is blown. If you have circuit breakers, one of the two circuit breakers can trip, even if the two for the dryer are connected.
Heating element Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable.
Thermal fuse On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it. (You can't re-set it.)
Wiring A common problem is for the main wiring connection from the house, at the dryer, to burn and break its connection. Because the dryer can still tumble with partial power, the connection may be only partially defective. You may need to replace both the power cord to the dryer and the terminal block inside the dryer that the wire is attached to.
This link will show teardown illustrations: Parts and more help available on other pages of the website.
http://www.repairclinic.com/0100_16.asp
Hope this helps.
Illeagle
Aug 27, 2008 | LG DLE2532W Electric Dryer
LG DLEo332W electric dryer not drying full time
you have to change out the timer motor...
http://www.partselect.com/repair.aspx?appliance=dryer&part=dryer-wont-heat
Jun 08, 2008 | Dryers
LG DLE2532W Electric Dryer Logo
1,002 people viewed this question
Top LG Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a LG Dryer Expert? Answer questions, earn points and help others
