Question about Whirlpool Duet GHW9150P Front Load Washer
The door won't open fault code dl comes on when you try to use the machine how can i open the washer machine door.
    President:
  • 1,554 Answers
Disconnect power then remove the three screws attaching the lower front access panel to the cabinet then pull the panel down and off the cabinet. You can prop up the bottom front edge of the washer or cushion and lean it against the wall to access and remove the screws more easily.
Once the panel is off, reach up along the inside of the front panel and locate the bottom of the door lock and switch assembly on the right side. Locate the tear-drop shaped tab then gently pull it down until a click is heard, and then open the door.
The door lock and switch assembly may need to be replaced if the problem persists. The replacement procedure is here.
Posted on Sep 30, 2010
Washer was working.. electicity whet out... when emergency generator came in.. door lock message.. nothin I do works
Why is the "F dl" light come on - Kenmore Elite HE3 ...
https://www.ifixit.com/.../Why+is+the+%22F+dl%22+light+come+o...
iFixitThese are the errors for error code F/dL Door Lock Error Condition A Door Lock ... orrepair the following Door Lock Mechanism broken or removed from the Door ... these are usually indications of a failed door latch assembly and will require replacement. ...FdL code would not reset until I turned washer on to start load.
Troubleshooting - Support - Dexter Laundry
www.dexter.com/support/troubleshooting/
Dexter Washer Troubleshooting. Select your problem form the following list to reveal a list of possible solutions and supporting documentation. Constant ... F1 / Door Lock Error Door failed to lock properly. + ... Error Code F13, F15, F17, F19 +.
Washing Machine Fault Codes « Tips, Tricks & Recipes
www.appliancefactoryparts.com/blog/.../washing-machine-fault-codes/
Feb 20, 2010 - Failure Code, Condition, Check/Repair. "F1?, Water ... "F7?, Door lockrelease fault, ?· Bent pull-rod for door latch. ?· Bad door latch ... Water overflow error, Water supply does not stop after sensing an overflow condition. Turn off household water supply to washer and unplug power cord. ?· Check wiring ...
Why won't the door open on my Kenmore front-loading ...
Dec 10, 2015 | Washing Machines
Washer sometimes will not work and a code comes on f dl what does this mean?
The DL code indicates a problem with the door lock. These washers need to lock the door before they fill with water. Then the door will unlock at the end of the cycle. The problem can be with the lock, the sensor that detects the lock status or the main control unit not receiving the lock message. Sometimes the wiring is the problem with the unit.
When the DL code comes on, can you pull open the door as easily as when you open the washer before starting the machine? If you can, then check if the wiring is sending the appropriate current to the lock. If the power is there, replace the lock. If the door has actually locked, then the problem is with another part of the system. Most washers will have a sheet with the wiring diagram and expected readings inside the machine near then main control board. This is accessed from the back of the machine above the wash tub.
I hope this helps.
Oct 16, 2015 | Whirlpool Washing Machines
My whirlpool duet GHW9100L washer door will not unlock and code comes up F dl, any idea's?
Ff dl (failure fault door lock)
Door Lock Error
A Door Lock Error occurs if the door cannot be locked. It will try to lock it 6 times
before displaying the error.
Potential Causes
• Door Lock Mechanism broken or removed from the Door
• Check Door Lock/Switch Assembly
• Check the wire harness connections to the Door Lock/Switch Assembly and
Central Control Unit (CCU)
• Door Lock/Switch Assembly Failure
The door lock may have to be removed and replaced to get past this failure.
Mar 18, 2010 | Washing Machines
Kenmore Oasis has error code dl
The dL error code is a door lock error. The control board will attempt 6 times to lock the door before displaying the F dL error code. This is an indication that either the door lock is malfunctioning or the control board is not responding to the door locking circuit. Be sure the door is securely closed before attempting to start the washer. Open the door & check for clothing or something that may be stuck in the door boot area. If the door is securely closed & you still have the error code I would recommend having the door lock assembly replaced.
Good Luck and Please rate
Jan 11, 2009 | Kenmore Oasis HE 27082 Top Load Washer
Fdl code message
>"dL" indicates Door Lock Failure: dL flashes if the following conditions occur:
Door lid is not closed completely due to interference.
Wash media buildup is preventing the lock bolt from extending.
Machine/motor control detects open door lid switch when attempting to lock.
Machine/motor control cannot determine if door lock is in a locked state.
Check for lock interference with lid or lock bezel
Jan 09, 2009 | Whirlpool Duet GHW9150P Front Load Washer
F dL symbol on Whirlpool duet HT
It is saying there is a problem with your door Lock. when you close the door does it hold like it use too? try to open and close the door if it doesn't really close properly then you will just need a door latch. If the machine gives you an f11 code then its the main computer board that can also give your the door lock error. I would check the door first though.
Jan 09, 2009 | Whirlpool Gold Duet GHW9400P 3.8 Cu. Ft....
Washer stops
Initially, pls open the lower access panel (bottom of your washer) by removing the 3 torx screws. There would be a sheet that lists the error codes. The panel pulls forward and down, inside mounted on the right side taped to that inner panel would be the above described sheet. Additionally, to my knowledge, this indicates a door latch fault, the machine cannot activate the lock or senses that the door is not closed or the door is not locked.
In some instances, the error code F/DL could be triggered be a loose component. This could be that the plastic fitting on the door is loose and therefore will not latch on the locking assembly or the locking assembly itself is loose. You could then try opening and closing the door a couple of times.
Should this be not corrective, then the logic controller board may require close checking.
Good luck and Thank you for using FixYa. Happy Holidays.
Dec 31, 2008 | Maytag Neptune MAH5500B Front Load Washer
Not drain
DL is the fault code for door lock error and occurs if the CCU (Cental Control Unit)"recognize" that door is unlocked. Potential reasons for it: - Door Lock/Switch Assembly Failure - In this case it should be replaced. - Door Lock unit is broken or removed from the door. - Look for disconnected wires to the door Lock/Switch unit and to the CCU. - Door Lock/Switch unit Failure
Jul 21, 2007 | Kenmore 43142 Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
24 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
