I connected my usb cable and the printer is not working
  • edge2 May 25, 2008
    Kodak Easyshare 5000 Series Aio printer
    installed with disk
    cartridge
    Setup instruction fllowed
    printer turn kon
  • AlmostBob
    AlmostBob May 11, 2010
    More info required.....
    Printer make n model
    OS
    Driver installed (y/n) from disk or website
    ink/toner/foil/ribbon cartridge(s) installed, and plastic tabs pulled
    paper filled
    Printer self test completed, some will not print until heads are aligned
    Setup instructions followed
    printer turned on
    or just plug in and cross fingers, only works half the time.
    Sergeant:
    Champion:
  • 326 Answers
Goto the control panel - add/remove programs and remove all Ur printer programs. Goto the control panel - printers and uninstall Ur printer. Leave printer connected. Reboot. when system detects the printer, load only the driver for it from the cd. Try printing, if it works then U can load the printer programs from it's cd. Make sure that the printer programs are compatible to Ur os.
Posted on May 26, 2008
Set-up won't recognize that the USB cable is connected to both printer and computer and therefore printer won't work. What's up with that??
1. Confirm the USB port on the computer you are connecting your printer to is being recognized by your computer. The easiest way to do this would be to plug a known good USB Memory stick into the USB port you want to use. If you can read the contents of the USB Memory stick then the port should work. Remove the Memory stick, start the printer installation program (Make sure you don't the printer connected), want until the setup program tells you to connect the printer before you attach the Printer's USB cable.
If the printer isn't recognized try a different USB port, when picking a new USB port to try select a higher priority port, for example in increasing priority from, an external USB hub, a powered external hub, a monitor based hub, USB ports on the front of the computer, up to the USB ports at the computer rear. For USB ports on the same circuit select an USB 2.0 before an USB 3.0 port
Aug 04, 2015 | HP OFFICEJET PRO 6830 E-ALL-IN-ONE PRINTER
My dell 924 printer has stopped working. I get an error message that there is no USB connection. All connections & USB cable are fine. For some reason this printer is no longer on a USB port - have...
Hello.
It sounds like a issue with the hardware inside the printer. if possible try the printer on another PC, or try another USB Cable. Sometimes the cable can appear fine but can have small breaks inside it. You can also try your current cable on another persons printer to rule out the cable.
If you can not get the printer working on another persons computer I would suggest replacing it. it is cheaper than getting a tech to fix it.
Regards GM
May 27, 2011 | Dell 924 All-in-One InkJet Printer
Printer does not respond to computer
Check the type of connection - are you using a USB connection or a Wireless connection?
- If USB, turn off the printer. - remove the power cable at the back of the printer, then remove the cable to the wall outlet. Wait for 10 sec. then reconnect all cables. - turn on the printer and check if the computer detects the printer. - If not, try to remove the USB cable at the back of the printer and computer. Wait for 5sec. reconnect the cable back. Try other USB port if not detected. - If still not detected try to use another working USB cable. - If replacing the cable did not resolve the issue, try to install the driver of the printer.
- If wireless connection try to check if the printer is connected to your router. Run the Wireless Setup Wizard in the front panel of the printer. Select the name of your router. - Download the Network Diagnostic Utility on the HP.com website to check what is causing the issue. It will give you the instruction on how to resolve the problem.
Apr 03, 2011 | HP Office Equipment & Supplies
MY Samsung scx 4521-f all in one is not Recognized with I connect through USB Cable . Changing the cable din't work What to Do.??
For USB Cable to work, you need to install USB driver compatible for your printer. Otherwise your printer will not be detected. Try to download USB driver for your printer to make it work. Because it is not the same as parallel port that can be connect directly.
Dec 08, 2010 | Samsung SCX 4521F All-In-One Laser Printer
Printer connected but not printing
If your printer has a network port you should be using the network adapter.
Otherwise you want to make sure you connect the printer with a USB cable to the appropriate port on the D-Link.
Once the USB cable is connected you should be able to add the printer from your computer as a shared printer.
You will not normally see any activity lights on your router for the USB connection because it does not send or receive information the same way the LAN cables will.
I do recommend a LAN cable though as it works much better with routers. If your printer does not have one I would look into getting a network printer.
Thanks,
Pat
May 12, 2010 | D-Link DP 300U (DP-300U) Print Server
Connecting from a Mac via wireless print server
Dissconnect USB cable add ethenet cable find printer on Mac set to default should work fine then worry about the wireless side inkypete
Apr 21, 2009 | HP OfficeJet 6310 All-in-One Printer...
HP laserjet 2200D connected via USB gives problem
try plugging into another usb & reinstall the driver that may help.
Jan 16, 2009 | HP LaserJet 2200D Printer
USB CABLE
the printer is designed to work with a parallel cabel connection. usb to parallel conversion cables may or may not work.
now for the second part is, about the driver (visit manufacturers website for updated drivers), usb driver behaves differently compared to parallel drivers as it expects a usb printer connected to a computer. try both drivers. remember, it may or may not work.
Dec 03, 2008 | Argox OS-203 Thermal Label Printer
G85 USB failure
You will have to replace the main board in order to get a new USB connection. Have you tried using the parallel connection. Looks like a regular parallel connection but smaller. It takes a special cable that was originally sold with the printer. We have those cables for $15 if needed. The USB cable may be out but the parallel connection may work fine.
Inkworks
866-381-0541
Jul 28, 2008 | HP OfficeJet G85 All-In-One InkJet Printer
Open Questions:
The Best Unlimited Online Backup and Cloud Storage Services Cloud backup, in simpler language also known as online backup, is a way to backup data by storing a copy of the data over Internet to secured cloud servers. Unlike the traditional ways to store data on local hard drive media the data is stored on cloud servers that are accessible through Internet. Cloud backup technology also help us retrieval of stored data on the go using a variety of devices all connected to the cloud servers. With Cloud backup, end users can upload documents, photos and videos to the cloud and then fetch them at their ease. This helps them save storage space on Server Cloud Backup Solution their computers and mobile devices. Furthermore, the cloud based structure allows end users to upgrade software more quickly - because software publishing companies choose to offer their products via the web rather using traditional, tangible methods that involve discs or flash drives. Top software publishing companies have chosen to turn their business models to subscription based and they deliver their product offerings through cloud solutions. All data is critical for businesses. It's a treasure trove of information. Problem is, they are drowning in it. Datalign provides a lifeline. We provide Cloud Backup For Small Business companies with a unique approach to backup, analyze and organize their data with the use of artificial intelligence Capabilities. Not all data file types should be treated in similar manner. Data may be accessed or stored depending on the requirement of the users; some users may want the data at their fingertips whereas others may want to store it for archival and compliance purpose. To rectify this problem with one solution, we have introduced the world's first Tribrid Backup. Without sacrificing any data, it enables businesses to protect all produced data and save storage costs. Our innovative platform has been designed while keeping you in mind. To provide Online Backup Pricing optimal user experience we focus on simplicity and this in turn ensures that you will be able to backup and access large data quickly and smoothly. Our Cloud services are available on demand and always up and running. We ensure 99.9% uptime for our cloud services. This ensures un-interrupted data transfers and practically no downtime.
Apr 21, 2018 | VIA Computers & Internet
Computers & Internet Logo
David Payne
David Payne
