Question about Magic Chef 9825 Electric Double Oven
What does error f3 mean on a magic chef , We used the self cleaning oven part and after it got finishe3d we tried to turn the oven on bake and after a few seconds it beeps and shows f3
  • 217 Answers
SOURCE: f3, f1 error mesage on magic chef stove, oven not working
http://www.applianceblog.com/mainforums/showthread.php?t=7643 click this link
Posted on Nov 30, 2008
  • 107 Answers
SOURCE: I have a majic chef oven, when i turn it on it beeps and flashes
Self clean on some older models can cause some issues. F-3 is a sensor error. This could have been damaged by high heat or in some cases if the sensor is ok, the control doesn't know it's there.
Posted on Mar 14, 2009
  • 1531 Answers
SOURCE: Magic Chef oven displays F3 everytime the bake or
this could be a an open probe or shorted probe connection.you need to check your temp probe harness to your main board.
there is a chance that you need to replace your temp probe.
last thing would be to replace the EOC
Posted on Feb 12, 2010
espressonist
  • 1711 Answers
SOURCE: I have a magic chef range. I ran the self cleaning
F1 Defective touch pad or clock (ERC) Replace touch pad or clock (ERC). Touch pad is a more common problem. Refer to F1 test at the top of this page for more information. F3 or F4 Shorted or open oven temperature sensor (RTD) Check sensor harness and harness connection between oven sensor and oven control. Replace oven temperature sensor (RTD) if wiring is ok.
Posted on Nov 25, 2010
remaker
  • 449 Answers
SOURCE: i was baking dinner and
Need to know the exact model to be sure, but usually there is a button that says "lock" or has a padlock icon that you press and hold for a minute or so to lock and unlock.
Also, if they started a cleaning cycle, that will lock the door, too.
Posted on Apr 21, 2011
I have a magic chef electric wall oven and it flashes an error code of F3 when I try to bake something. How do I fix it and what does it mean?
The F3 code means that the temperature sensor in the oven is not giving the signal to the oven control. This could be the result of a problem with the wiring or the wire harness between the control board and the sensor or indicate that the sensor itself has failed.
To identify the correct parts, you need to provide your oven model number. Try here: http://www.partselect.com/Magic-Chef-Parts.htm . There are other sources for parts.
I hope this helps. If you add a comment with the model number, I'll be glad to give you more specific information for your wall oven.
Sep 25, 2011 | Magic Chef Ovens
I pressed self clean on magic chef ceramic range oven and get a dr code.
Hi, Before you go working too hard to get you oven to go intothe self clean mode(self destruct)....check out this tip...
Self Cleaning Oven Problem
heatman101
" Wish I had read this first. I never would have used the self cleaningoption. Thanks for the info!!
Nov 28, 2010 | Magic Chef Ovens
I have a magic chef range. I ran the self cleaning on the range. Now when trying to use the oven I get a F1 and a F3 code. I unplugged it for a while to reset and still have the same problem.
Nov 25, 2010 | Magic Chef Ovens
I cleaned my oven. When the cleaning was finished the oven started beeping with an "F3" message... Please help!
Hi
Thanks for using FixYa. Error F3 in your range/oven means oven temperature sensor circuit failure. To resolve this issue you’ll have to check the oven temp. sensor circuit if the reading is more then 1100ohms then it should be replaced however, if the rating is fine then it is the Electronic Range Control (ERC) that has gone bad & should be replaced. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Jul 13, 2010 | Magic Chef Ovens
Getting an F3 code
try starting self clean again then cancle it
May 05, 2010 | Magic Chef 9815 Electric Single Oven
Magic Chef oven displays F3 everytime the bake or broil button is pushed. Not sure what the model # is. Electrical range.
Feb 12, 2010 | Magic Chef Ovens
Mar 14, 2009 | Magic Chef 9815 Electric Single Oven
Linking F3 when trying to turn on the oven
While using the self clean feature you burned out the oven temp sensor.
Replace the oven temp sensor.
Do not use self clean on any oven unless you want to replace parts,
Feb 24, 2009 | Kenmore 30172 / 30174 / 30179 Gas Single...
Magic Chef 9825 Electric Double Oven Logo
66 people viewed this question
Top Magic Chef Ovens Experts
Sal De
Oloyede Monsuru
Are you a Magic Chef Oven Expert? Answer questions, earn points and help others
