Question about Sharp MX-M350 All-In-One Printer
I have an error code of L4-03 on my sharp MX 950, how do I fix it?
  • 14 Answers
SOURCE: Sharp MX-2300N with error code H3-00. . how do I
Ensure you are in COPY mode
press # * C * ( one after the other, fairly quickly)
when the screen changes enter the number 14 on the keypad
press the B&W start button
press 1 for Yes when the question displays
press thw CA button
machine will re-boot and fault should clear. If it doesnt you need a service engineer. This is a fuser temperature fault
Posted on Mar 09, 2010
hamzaskilltd
  • 316 Answers
SOURCE: SHARP AR--M207 Error L4-11
1. Main motor lock detection
2. shifter motor trouble
Posted on Jun 01, 2010
  • 46 Answers
SOURCE: I have a Sharp MX-6201N copier that is showing
U2-10 is 'SRAM user authentication check sum error'
Press P * C * to enter the service 'simulation' mode then enter 16 on the key pad and press the start button.
You will be in U code clear.
Press 'execute' on the screen.
The machine should reboot.
It may start to work again.
If not you will need to replace either SRAM chip or the main board.
Posted on Oct 31, 2010
  • 257 Answers
SOURCE: how can i fix error code h5-01 on my sharp mx
Hallow, this occurs due to the document glass problem. This may be due to powering it on when the glass is removed or the glass being locked in the reverse side. This may also be as a result of copy lamp being off.
Solution
  • Check that the copy lamp is lighting well. Check for the copy board of replace copy lamp.
  • Check that the document glass is well screwed and the white part should be in the front side.
  • This does not need resetting once you do the above , it should not show again.
Please do those processes with caution not to break the fluorescent lamp which is fragile.
Posted on Dec 08, 2010
hamzaskilltd
  • 316 Answers
SOURCE: Have MX 3501N Sharp Copier
H3. Heat roller High temperature detection
Posted on Aug 18, 2011
IM GETTING AN ERROR CODE C4-00 ON MY SHARP MX2314N. I HAVE CHANGED BOARDS, STILL NOT FIXED. HOW CAN I FIX THIS ERROR?
mx 2314n error code c4-00. You could have one or more of these bad-PTC unit, Secondary transfer PWB, PCU PWB, a connector or harness connection problem.
Apr 11, 2017 | Sharp Office Equipment & Supplies
Sharp MX-2600n has an E4-11 code. How do I fix that?
Search Results
    SHARP MX 2600N ERROR CODES Trouble Codes
    https://www.sosnfl.com/sharp-mx-2600n-error-codes/
    SHARP MX 2600N ERROR CODES trouble codes C1 10 C1 14 C4 00 E7 03 E7 10 E711 E7 ... Wait until the panel has gone dark and any flashing buttons have stopped flashing. ... A0 11 FIRMWARE VERSION INCONSISTENCY (MFP-PCU).
    [PDF]Sharp MX-M350N Trouble Error Codes - OlsonBros
    olsonbros.com/sharp/.../pdf.../trbl-mxm350n_m350u_m450n_m450u.pd...
    MX-M350/M450 N/U TROUBLE CODES 11 - 1. [11] TROUBLE CODES. 1. General. When a trouble occurs in the machine or when the life of a con- sumable part ...
    [PDF]Sharp MX-3500N Trouble Error Codes - OlsonBros
    olsonbros.com/sharp/support/.../trbl-mx3500n_3501n_4500n_4501n.pd...
    MX3500N SELF DIAG AND TROUBLE CODE 8 - 1 ... part has reached .... 11: When detected during other than a job, the operation is enabled in other than the ...
    Error Codes > Sharp > MX2600N - Printcopy.info
Feb 03, 2016 | Sharp Mx-2600n MFP Copier
Error code F2-40 in Sharp mx m314n photocopier
using third party toner or drum replace toner and drum with OEM
Jun 04, 2015 | Sharp MX-M314N Copier
H5-01 ERROR CODE
The following is from the Sharp website on error codes: SHARP MX M503N ERROR CODES Trouble Codes
H5 01 = 5 TIMES CONTINUOUS POD 1 NOT-REACH JAM
Mar 03, 2015 | Sharp Maintenance Kit 1 Mx-m700u Mx-m700n...
MX m354u. What does error Code U2-91 indicate?
This seems a common error across a wide range of Sharp printers/copiers. It means
PCU PWB EEPROM CHECK SUM ERROR
See the following two links (for example)
Thread U2 91 on MX 5000N and SHARP MX M363N ERROR CODES Trouble Codes
If haven't got manuals or other documents which may contain helpful information they can be downloaded here. This link also contains contact information for sharp so that you might get support
MX M354N MXM354N Digital Copier Printer Sharp
6.November.2015
Feb 27, 2015 | Sharp Office Equipment & Supplies
Sharp Model MXB401 Error L4-16 what is it and how do i fix it
Hello Joanne,
The error that you are receiving is due to worn gears going to the fuser assembly that need to be replaced!
The repair thread can be read at either link below:
Thread MX B401 L4 16 error
sharp mfp mx b401 error code c4 16
Good Luck!
Rich Lilja
Feb 24, 2015 | Sharp Office Equipment & Supplies
Sharp mx 2300N error code H5-01
http://www.copytechnet.com/forums/sharp/76512-sharp-mx-2300n-error-code-h5-01-a.html
Feb 15, 2015 | Sharp MX-2300N Color Copier
MX-M700U
This is a low fuser temperature error. Normally it can be reset by doing the following...make sure it's in copy mode:
pound, star, C, star
14, start
execute
once machine restarts the code should be gone. if not, and you're in Houston, we can get you fixed up.
Skelton Business Equipment Houston Copiers
Jun 11, 2014 | Sharp Maintenance Kit 1 Mx-m700u Mx-m700n...
Sharp MX 3100n showing code H5-01 , what is it,how do I fix
when your copier paper jam in fuser unit area. than show H5-01 error code.
if you fix it self,open right door and relese the jam paper carefully.
Feb 19, 2010 | Sharp MX-3501N All-In-One Printer
Sharp MX-M350 All-In-One Printer Logo
1,239 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
jasbo
jasbo
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
