Question about Radio Shack Pro-2018 Scanner
Need manuel for pro 2018 scanner - Radio Shack Pro-2018 Scanner
  • 8,197 Answers
You can get the manual on the link below.
http://support.radioshack.com/support_electronics/doc69/69290.pdf
Good Luck and please rate 4 thumbs up for the free answer
Posted on Sep 30, 2010
Mechanic688
  • 204 Answers
SOURCE: desk top radioscanner want scan can u help me
po66, first off this is a nontrunking scanner. Do you know the freq. coverage style for your area? Some are still the old standard, some are trunktracking, there is different versions of trunktracking and most are not compatable. I have very limited info to work with, so I'm going to take a best guess. Here is a basic guide for your scanner.
http://support.radioshack.com/support_tutorials/communications/20-424.htm
If your needing freqs for your location, go here.
http://www.radioreference.com/apps/db/
I hope this helps clear up your problem, and if not, reply back here and I'll try to walk you thru further.
Mechanic
Posted on Jan 26, 2008
  • 8 Answers
SOURCE: scanner
http://rsk.imageg.net/graphics/uc/rsk/Support/ProductManuals/2000424_PM_EN.pdf
Posted on Apr 10, 2008
Mechanic688
  • 204 Answers
SOURCE: Antenna for radio shack pro 2018
Hello, Radio Shack would be the first place i'd try for a replacement. Mechanic
Posted on Nov 01, 2008
SOURCE: i need updated scanner codes for antrim county
Posted on Jan 17, 2010
BillB-SA
  • 2761 Answers
SOURCE: my pro 2018 scanner wont
First try picking up the NOAA Weather broadcasts. They're transmitted on seven frequencies (162.400, 162.425, 162.450, 162.475, 162.500, 162.525, 162.550) and at least one should be active in your area. To check reception, just press the WX key on your scanner. If you can pick up one or more of the frequencies, you'll know that the scanner is functioning properly. If not, your scanner is likely in need of repairs - a questionable move due to its age.
If the scanner is functioning (receiving the weather band), try a quick RESET. use a paperclip or pen point to press the recessed RESET button on the back of the scanner.
Make sure that you have programmed local active frequencies into the scanner. For a comprehensive database, and a lot of other useful scanning information, visit:
www.RadioReference.com
After all of the above, if you are receiving weather but no local transmissions, I recommend that you try an external antenna.
If you need the manual for your scanner, you can download and print it, at no cost, here:
Bill B
Listening in since the 60's
Posted on Sep 28, 2010
Need to program a PRO-2018 scanner for puxico mo
Hi Jeff,
Try This Site: www.radioreference.com
They have all USA states covered, I'm sure you'll find what you're looking for there.
I hope this is helpful
Cheers,
Peter
Mar 01, 2013 | Radio Shack Pro-2018 Scanner
I want to modify for 800 MHz which diode do I clip or remove
Modern scanners are difficult to impossible to modify for frequency coverage, and there are no known modifications for the PRO-2018. Sorry, but if you want 800MHz coverage you'll need to purchase a scanner that provides it from the factory.
Bill B.
Dec 23, 2010 | Radio Shack Pro-2018 Scanner
I need to program a weather scanner for a pro 2018 weather scanner from rdio shack
Weather frequencies are factory programmed into the PRO-2018. Just press the weather button to start scanning them. You can also program one or more manually if you wish. For a list of NOAA weather broadcast frequencies, follow this link:
http://www.nws.noaa.gov/nwr/indexnw.htm
Need the manual for your scanner? You can download/print it here:
Bill B
Sep 05, 2010 | Radio Shack Pro-2018 Scanner
Need to find replacement padapter no. JoD-41U-02 for pro-2018. Can't locate one. Do you know where I can buy one.
The exact replacement power adapter for your scanner is out of production. Power requirement for the PRO-2018 is 12 volts with a minimum of 300 mA. Radio Shack has a universal power supply that will work, or you can pick one up on eBay for under $20, including shipment. You can also pick up a voltage-specific power adapter on eBay or elsewhere, but you may have to change the DC plug to match your scanner.
Bill B
May 21, 2010 | Radio Shack Pro-2018 Scanner
Loss manuel
You can download and print your scanner manual here:
Bill B
Mar 06, 2010 | Radio Shack Pro-2018 Scanner
Radio Shack Pro-508. The lock out key and program
Need to do a hard reset, turn power off, then back on. Hold down [CLEAR], press the reset button on the back then release [CLEAR]. I found it in the manual for the Pro-2018.
Oct 17, 2009 | Radio Shack Pro-2018 Scanner
Radio Shack Pro-2018 scanner manual
You can download/print the manual here:
Jul 14, 2009 | Radio Shack Pro-2018 Scanner
Oct 09, 2008 | Radio Shack Pro-2018 Scanner
Radio Shack Pro-2018 Scanner Logo
66 people viewed this question
Top Radio Shack Radio Communications Experts
John
John
Greg Cann
Greg Cann
Jason
Are you a Radio Shack Radio Communication Expert? Answer questions, earn points and help others
