PICTURE IS GETTING DARKER AND DARKER
PICTURE IS VERY DARK DO I CHANGE MY LAMP?
THANKS CHANTAL
Without more information, assuming its a Halide lamp, and the viewing angle of the TV hasn't also got worse I would say yes and quickly, if the image has degraded badly the lamp is close to failure which could cause further damage.
Although only a guide as some lamps last longer than others you should always keep an eye on the lamp hour counter The manual should tell you how long to expect from a lamp.
Posted on May 25, 2008
  • blah123456 May 25, 2008
    Sorry, did forget the obvious, Its probably wise to check that no one has fiddled with the brightness and contrast controls especaly if the lamp timer is saying the bulb is young.
Why does the television power off by itself when color is fading in and out
Not real likely it is the lamp unless the picture is dark and has been getting darker.
I doubt it is the lamp.
Mar 16, 2012 | Toshiba 62HM95 62" DLP HDTV
My sony kdf-e42a10 lcd projection tv has good sound but for some reason the picture has gotten real dark, you can still see it barely, what could be causing this
Cause of darker picture is lamp that has reached at end of its working life span and need to be replaced for brighter picture in tv.
Replace lamp in tv to get problem solved.
Thanks.
Jul 24, 2010 | Sony (XL-2400) Projector Lamp for...
Tv very dark what can i do brightness tured up full still very dark
First check this points:
1. How old is your TV.
2. How many times you have change your lamp.
3. Any sort of weird sounds on the back of the TV.
If you are having problems whit the brightness of your TV or you are seeing a dimmer picture, you might have to change your lamp or your ballast, if it comes to a point where you do not see any image at all but you still hear a sound, then its definitely the lamp, if you dont see image or hear any sound, you might have problems with your ballast, also when your ballast begins to run out the picture can get dimmer due to it sending less amount of voltage to the lamp, i suggest to check with a tech to confirm it, or get a second opinion. Hope i could be of assistance.
Mar 16, 2010 | Sony KDF-E50A12U 50" LCD HDTV
Screen getting dark
If you have never changed the lamp this is more than likely the issue, as the tv ages the lamp looses brightness. Most lamps are rated for 3000-5000 hrs of use. Replace the lamp assembly part # UX21514 and you will notice a much brighter picture. You do not mention if the tv plays the right colors on the entire screen. These have had light engine issues.
Good luck with it
JOTVGUY
Apr 07, 2009 | Hitachi 50VX915 Rear Projection Television
Screen getting darker
your case is the back lights inverter or lamp damage, you have to send to repair, find a laptop hardware specialist to do that, my repair cost (lowest)
1) repair the inverter board if repairable, $50
2) change the new inverter board $80
3) change the lamp $60
Feb 02, 2009 | Acer Aspire 5610-4648 Notebook
Picture seems to be alot darker than before. toshiba 62hm95
I just replaced a lamp in a Sony LCD projection that was just over a year old and it was bad. It was a VERY dim picture. You have a DLP but, in either case a dim or dark picture is almost always caused by the lamp.
Feb 23, 2007 | Toshiba 62HM95 62" HDTV
Televison & Video Logo
171 people viewed this question
Top Televison & Video Experts
