Question about Kenmore Heating & Cooling
My kenmore ac wall unit model 75135 display powers on but the fan wont come on and you can hear the compressor try to start but stops within one or two seconds. The unit tries to start every minute or so. Any ideas
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 141 Answers
Look for the capacitor its usualy oval or round if its bad it usualy is swollen or leaking fluid it sounds like its bad if you need more help e mail me a airforceac@live.com
Posted on Oct 01, 2010
I have a Kenmore Elite model no is 59673502201 and it stop cooling in both the frig and freezer i replaced the condenser fan motor and it worked so i replaced the back and the unit will STILL NOT GET
Do you hear your evaporator fan running in the freezer drawer area?
If not, then that's the fan you should have replaced.
If your compressor is running and both the compressor fan and the evaporator fan are running, check the back wall of your freezer compartment. If it is frosted up, then you have a defrost problem.
If it's not frosting up, disassemble your freezer drawer section and remove the back panel in the freezer to look at your evaporator coil.
If it's partially frosted at the top, or bottom, but the rest of it is dry looking, then you've got a leaking sealed system.
If it's lightly frosted all over, then you have good coolant flow and you need to start looking at your thermostat and damper up in the fresh foods section.
Nov 10, 2014 | Kenmore Refrigerators
Kenmore AC window unit model 253 70151 cuts on and off.
Circuit board could be the problem but compressor needs to be checked and there might be a loose electric connection or high voltage causing the ac to trip
Apr 04, 2014 | Heating & Cooling
Repeat, corrected model number
Try unplugging the fridge and replugging it in. On this model if it doesn't cool, the display/temperature reading for the unit may start beeping like crazy. Resetting it sometimes fixes this. If you hear the compressor motor kick on, and it doesn't cool within 24 hours, your fridge will need a major repair. If it doesn't turn on at all, you may need a less expensive repair.
Nov 27, 2013 | Frigidaire FRS3R5EMB Side by Side...
I have a dometic penguin ac rooftop unit. Model no. 630215.421. Fan blows Compressor does not kick on. Fan blows just no cold air. If put on auto and go up or down in temperature On the thermostat The fan...
Bad run capacitor or bad compressor. If you hear an occasional click from the compressor try a new run cap and then a hard start kit. Otherwise it's more economical to purchase a new unit.
Sep 25, 2013 | Dometic Rooftop RV Air Conditioner
Fan will come on but compressor wont kick in on wall unit ac
The start capacitor on the compressor is bad. Replace it and the compressor will run.
Jun 30, 2013 | Heating & Cooling
My old Kenmore window unit has all of a sudden stopped working. Was working fine then just stopped coming on. The wall outlet checks out fine. Is there a re-set on the unit? What else can I check?
Hello, if the unit is receiving power check the capacitor, this is a round or oval can located inside the control panel of the Ac, it controls the fan and compressor operation.
May 23, 2012 | Kenmore Heating & Cooling
I need an installation manual for ac 75135 This is a closeout.
It is the either the fan bearings is going out of the motor or you just might clean the fan blades it the fan blades has any play on the shaft probably the bearings are going out to the motor.
Jun 03, 2010 | Kenmore 75101 Wall/Window Air Conditioner
Hello, I have a Kenmore 580.75124500 ac/heater
It is probably the compressor. You will need to check if the compressor is being called to come on. Do you hear the compressor running? If you do, I would remove the unit from the wall or window, and wash it down real good with a hose being careful not to get the electronics wet. If not and the unit sound different than it did before, it's probably time to buy a new one.
Mar 31, 2009 | Frigidaire FAC125P1A Window Air...
Heating & Cooling Logo
96 people viewed this question
Top Kenmore Heating & Cooling Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
1STHVACMAN
Bill Long
Are you a Kenmore Heating and Cooling Expert? Answer questions, earn points and help others
