Question about Quinny BUZZ 3 Capri Stroller
My quinny frame keeps clicking dwon on one side mostly need to fix it fast what can be the problem
  • Quinny Master
  • 1,629 Answers
Good Afternoon
If it is under 2 years old please return it to your retailer with proof of purchase for it to be sent to the engineers for inspection & repair work required under warranty terms and conditions.
If it is over 2 years old or you do not have your proof of purchase please contact the customer care department on 01284 413 141 Mon-Fri 8.30-4.30 to discuss chargeable inspection & repair work required.
Posted on Nov 10, 2011
I bought a second hand Quinny Buzz, and the clip for the frame lock is broken
Hi
The transport lock is available as a spare part item - who did you speak with that advised you it wasn't?
RRP for the transport clip is 10GBP and you can order via your local Quinny retailer or direct from the customer care team on 01284 413 141 Mon-Thur 8.30-6.30 / Fri 8.30-4.30 (Excluding Bank Holidays)
Sep 11, 2012 | Quinny Buzz Baby Gear
I want to know what the dwon side of the front passenger door is made of?
dwon side?
the lower part, is steel, the door has shell frame,
its cold rolled punch pressed steel.
the covers inside are plastic.
Jul 24, 2012 | 2007 Suzuki Forenza Sedan
Bought quinny buzz 3 second hand, the frame has dropped on one side, how do i fix it?
Good Evening
Unfortunately there is no quick fix for this; It sounds as though one of the knuckles has broken, causing a one sided chassis collapse.
What country are you in?
May 18, 2011 | Quinny Buzz Three Wheel Stroller
Main frame and worn wheels of the quinny buzz
This happened to my wife the other day, I found that the main pivot bolt had pulled through the plastic pivot/collapse assembly. This part is rivoted to the frame so without drilling it out and replacing with an ugly nut and bolt you will have to source a new frame. I got mine from Ebay, I found someone selling lots of quinny buzz bits and asked if he still has the frame he said yes but the handle bar no longer extends (Hence im on here looking how to swap the two), Problem solved!
I also found out from Quinny that the Buzz has a 2 year manufacturers warranty, where Motercare insisted it was 1 year, so dont let them fob you off.
Hope this helps
Chris.
May 18, 2009 | Quinny Buzz Jogger
Quinny frame saftey clicking and giving way
Hi if you are putting bags on the handle this causes it to do it, if not you will need a new frame ebay has loads of used frames very cheap.
Mar 17, 2009 | Quinny Buzz Jogger
Quinny Buzz Frame Problem
Try contacting them directly!
This may be a manufacturing problem that they are not aware of !
Click on the link below.Copy and Paste your problem into the email if you like.
http://www.quinny.com/quinny/forms/contact.aspx?mode=contact&language=nl-nl
Hope this is helpful.
Good Luck!
Jan 22, 2009 | Quinny Zapp - Olive Green Umbrella...
Hi I got a nearly new frame off ebay for a bargain! There are loads of spare parts to be had on there.
Aug 03, 2008 | Quinny Buzz 3 Sulphur Jogger
Quinny buzz
Tyres-press the light grey button on the chassis next to the wheel slot as you push on the wheel (this is also the button you press to release each wheel).
Opening it is easy - With Buzzwheels on the ground, remove safety hook (plastic loop on left side of handle fixed to peg inner left rear wheel) ten simple lift handle and Buzz frame should automatically pop up.
Closing takes more practice-put on brakes (press red foot pedal) stand to side of chassis and at bottom end of handle there are two large grey buttons. With left hand on left button push button forwards (ie direction of chevrons on button) then press in. At the same time push in right button with right hand. Whilst doing this you also need to push down and forad on frame and it should fold down. If you don't push buttons enough it can click. When folded remember to put on safety hook before transit, otherwise it might pop up on its own. Hope this helps. You can download the manual with instructions from Quinny website too if pictures are helpful!
Apr 25, 2008 | Quinny Buzz Jogger
Quinny buzz
Ours did exactly the same thing - collapsed with our son in it. This happened several times and we were constantly having to pull the chassis up on one side until it clicked again. Emailed Quinny - no response. Took it back to John Lewis and they sent it away and gave us a loan chassis. Quinny couldn't fix it so sent a shabby second hand replacement (outrageous!). We and John Lewis went mad and they finally supplied a new chassis. good luck!
Apr 03, 2008 | Quinny Buzz Jogger
Quinny buzz footrest
Hi just today i tried fix that. i opened lock parts. there are parts which are broken. no chance to fix that you need to change all frame. otherwise use screw and screw thru plastic parts to be in one position for good.
Oct 30, 2007 | Quinny Buzz Jogger
Quinny BUZZ 3 Capri Stroller Logo
59 people viewed this question
Top Quinny Baby Gear Experts
Dorel UK
Dorel UK
Jennifer Rock
Jennifer Rock
Michael Vincent Cruz
Are you a Quinny Baby Gear Expert? Answer questions, earn points and help others
