Question about Avaya 4610SW IP Phone
Enable mute - Avaya 4610SW IP Phone
How do I enable the mute button on my new Emerson tv remote
find the mute button on the remote and press it
it may be shown as a speaker with a cross on it
Dec 09, 2015 | Emerson Televison & Video
Huawei ascend g300
At what point do it mute itself? Is it during calls, music playback, playing a video? Does the mute option get enabled, can you immediately increase the volume or un-mute?
A generalised piece of advise is that a factory restore on most devices including phones can be quite quick and easy, if your are not worried about data stored on the device this can often be the quickest way to cure software issues.
Mar 21, 2014 | Cell Phones
Mute button on probook 6450b
sounds to me like the indicator light is stuck in the on could be something touching the wires and causing a bad connections
Nov 06, 2013 | HEWLETT-PACKARD ProBook 6450b Notebook
Have Callmaster lll phones. We want mute button disabled. Agents have figured how to enable the mute buttons on individual phones. Looking for way to permantly disable mute feature on 700 phones. Thanks
First make sure headset/handset adaptors are not plugged into the phone
Press Select
Press Mute
Dial 68 (this will show the current setting)
Press * to change the setting
When the setting is at what you want press # this will save tyhe setting and exit programming mode
Hope this helps.
Mar 16, 2011 | AT&T LUCENT / AVAYA CALLMASTER IV PHONE...
My laptop microphone is muted when I Skype. How do I un-mute it?
For you to un-mute the inbuilt microphone on your Laptop follow the procedure given below.
  • Left Double Click on the sound icon present in the system tray. (Bottom left of your Screen)
  • Un-chech the box for the MUTE option in the Mic-in Volume section.
This should enable your Mic and you the laptop will be able to hear you. Don't forget to rate the solution.
Jan 05, 2011 | Computers & Internet
I can hear but people can't hear me
Try to unmute the headset. This may be your problem. The mute function is enabled through the volume buttons. Simply tap both volume buttons at the same time until you hear a mute tone. The mute tone when unmuting the call will be a descending tone. When you tap both volume buttons, if you hear a descending tone you have just disabled the mute function and your problem is solved. If the mute tone is ascending tones you have just enable the mute function and this was not the issue. If this is the case consult your user manual or contact Motorola for trouble shooting.
Aug 27, 2010 | Motorola Mobility H710 Bluetooth Headset
My I use my H 710 I can hear my customers but they can not hear me. How do I remove mute? Thanks
Aug 23, 2010 | Motorola Mobility H710 Bluetooth Headset
I can hear the other person but they can't hear me
Your headset may be muted. Try to unmute the call. The mute function is enabled through the volume buttons. Simply tap both volume buttons at the same time until you hear a mute tone. The mute tone when unmuting the call will be a descending tone. When you tap both volume buttons, if you hear a descending tone you have just disabled the mute function and your problem is solved. If the mute tone is ascending tones you have just enable the mute function and this was not the issue. If this is the case consult your user manual or contact Motorola for trouble shooting.
Aug 18, 2010 | Motorola Mobility H710 Bluetooth Headset
When I hit handsfree button it says it is muted cant figure out how to un-mute the phone
If handsfree is enabled on your telephone, any line or intercom button activates the handsfree, if you press the handsfree button after selecting the line then the button activates handsfree mute, Press the handsfree mute button again to un-mute the line.
Jul 04, 2010 | NorStar Meridian M7310 Phone
Microphone muted
In Vista you should be able to right click on the mic icon and select enable, in XP just untick the mute box
Sep 08, 2008 | Computers & Internet
Avaya 4610SW IP Phone Logo
214 people viewed this question
Top Avaya Computers & Internet Experts
Michael Vincent Cruz
RSole
Are you an Avaya Computer and Internet Expert? Answer questions, earn points and help others
