Question about Mitsuba DV9002 Flash Media Camcorder
Can get it out of the protected card mode - - Mitsuba DV9002 Flash Media Camcorder
  • 567 Answers
Some memory cards have a Write Protection switch on them.
To check this please remove the Memory card from the camera. Check if there is a "lock" switch on the left side.
Slide this switch to the "Unlocked" position, and reinsert the card into the camera.
This should resolve the issue and the error should go away.
In case the issue persists, it could mean the the write protect on this card was perhaps set by mistake while it was connected to the
computer.
You will need to use the computer to cancel the read-only setting.
Please connect the card to your computer through the camera or a card reader and cancel the write protect on the card.
Right click on the card and go to properties and uncheck the "Read Only" box.
If this doesn't work for you, please comment and let me know, and I will be more than happy to assist you to further resolve your issue.
I will appreciate your feedback and positive rating for this free solution.
Posted on Sep 30, 2010
  • Steven Weintraub
    Steven Weintraub Feb 28, 2014
    Same issue here for a SanDisk Everio 16G SD. It was working fine, but is not set read-only and can't correct this. There's no external switch and properties under Windows does not show attributes, so can't unset there. Need help!
Kodak easy share c183 memory card protected how to reset
Camera LCD: "Memory card is protected (Reset ... - Kodak
support.en.kodak.com/.../camera-lcd%3A-memory-card-is-protect...
KodakAug 25, 2010 - The camera screen displays "Memory card is protected (Reset switch on card). ... The memory card is locked so that data (pictures, videos, or files) ... The disk is write protected." when writing to or formatting an SD card. Share.
[PDF]KODAK EASYSHARE C183 Digital Camera
resources.kodak.com/support/pdf/en/manuals/.../C183_xUG_GLB_en.pd...
Kodak, EasyShare, Max, Perfect Touch, and Pulse are trademarks of Eastman Kodak. Company. ..... Access to more manual settings than Smart Capture mode. ..... NOTE: To delete protected pictures/videos, remove protection before deleting.
Jan 26, 2016 | Kodak Easyshare C183
I want to delete protected pictures
If the picture on the camera is protected, unprotect the picture first. In playback mode, scroll to the protected picture, then press the AE-L/AF-L button on the back of the camera.
If the memory card is protected, take the card out of the camera. SD cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Apr 20, 2013 | Nikon D40 Digital Camera with G-II 18-55mm...
How to remove write protect mode from GE J1456W
Look at your memory card. SD cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Feb 21, 2013 | GE Smart Series J1456W 141 Megapixel...
Turn off protected mode
Look at your memory card. SD and SDHC cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Jun 10, 2012 | FUJIFILM FinePix JX310 14.1 MP Digital...
When I want to take photo a message says: memory card is write protected.How can I solve this problem
Take the memory card out of your camera. SD and SDHC cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card. If the switch is already in the proper position, slide it fully the other way and then back again.
Jan 14, 2011 | Nikon COOLPIX S200 Digital Camera
I have managed to put a lock on my memory card in my camera... (it is on protection mode and dont know how to get it off as i want to delete all the pictures on the card. I have the old pentex optio wpi...
If your pictures are on the SD card in your camera, many of the sd cards have a small micro switch on one edge that will lock your card... you may want to pull it out of the camera and make sure that the physical lock isn't set..
Dec 02, 2009 | Cameras
How do I get rid of memory card protection?
There is a lock switch on the memory card that you can set to protect the card. Have a look at the card and check if you can see the switch. Just push it in the other direction than it is at present and all should work fine.
Please rate.
Cheers
Sep 30, 2009 | Panasonic Lumix DMC-FX01 Digital Camera
Write Protected
When I try to delete the files Kingmax 1GB Micro SD Memory Card it says that The disk is write protected or insert other disk
Oct 29, 2008 | Kingston 1GB Secure Digital Memory Card
Disk is write-protected
You need to take uot the memory card, and slide the small tab on one side of the card that activates protect mode on memory card.
If that does nopt work, then memory card is faulty.
Oct 25, 2008 | Nokia 3230
my memory card had the same problem. it has a tiny switch on the left side(its gray) move it up. it worked for me now mine is fine and when ya flick it back down it locks again so thats the problem just flick the switch back.
Jun 26, 2008 | Microtek Take-it MV320 Digital Camera
Mitsuba DV9002 Flash Media Camcorder Logo
64 people viewed this question
Top Mitsuba Video Cameras Experts
prouddad_1
Tom Chichester
Are you a Mitsuba Video Camera Expert? Answer questions, earn points and help others
