I have a toshiba nb305 and the touch pad muse is locked. How do I unlock the touchpad mouse? I dont have a seperate mouse to pluig in.
SOURCE: Toshiba Satellite A85-S107 laptop touch pad L-R key not working
try using the fn and f9 to enable or disable the touchpad.
Posted on Aug 02, 2008
  • 232 Answers
SOURCE: touchpad on toshiba equium A200-1VO laptop not working
you have lost your driver for the cursor .
go to :
  • www.toshiba.com/taecdpd/support/drivers.shtml
  • this should have all the drivers required for your PC .
    give it a try and let me know how you go
    Posted on Sep 30, 2009
    SOURCE: acer aspire one mouse pad clicks not working stuck on right click
    I've got the same problem. I'm still running Linux on my aspire one, and synclient shows that the right mouse button is depressed. If I restart X (i.e. logout/login again) then it "lifts" the mouse button, which is then stuck "off" instead of on.
    I checked with a multimeter and the switch on the motherboard is working fine, so if it's a hardware problem it's with the electronics rather than the switch. (however the fact that people are seeing this with both windows and Linux seems to indicate that it's either BIOS or hardware)
    Posted on Mar 15, 2010
    • 157 Answers
    SOURCE: the touchpad of my laptop was being unlock. there
    HELLO, THERE IS USUALLY A SWITCH NEAR THE TOUCH PAD.CLICK ON THAT SWITCH AND SEE WHAT HAPPEN
    Posted on Nov 18, 2010
    immortal4u
    • 223 Answers
    SOURCE: I can not disable touchpad
    Go to the Control Panel. Under the 'Hardware and Sound' options, click 'Mouse'immortal4u.png
    Since you have a Dell laptop, you'll have a special tab called 'Dell touchpad' in the window that pops up. Click on the touchpad picture in the window.
    In the new window that appears, click 'Device Select'
    Click on the 'Disable' radio button to disable the touchpad completely. If you want to disable the touchpad of your Dell laptop only when an external device like a mouse is attached, check the last option that says 'Disable Touchpad/Pointing Stick when external USB mouse is present'
    That's it. You've disabled your laptop's touchpad for good. If you don't find an option to manage your touchpad in Mouse settings, you have to install Synaptics drivers from here. Similar options can be found in other laptops as well.
    Good luck ! if your problem is solved don't forget to rate
    Posted on Dec 30, 2010
    Unlock keyboard for a Acer AS7540-1284
    The Keyboard is locked? Or do you mean maybe the mouse pointer is locked? Look on your keyboard and see if you see anything that resembles a mouse touch pad. Some systems will lock the touch pad, but it can be unlocked by hitting a combination of keys, such as holding the FN key + the key with the touchpad icon.
    Mar 30, 2012 | Acer Aspire 4720 Notebook
    Toshiba touchpad not working
    Make sure you don't have the touchpad locked. On most computers right above the touchpad in the center is a little button that locks or unlocks the touchpad. Try toggling it. If that is not your problem see if your touch pad application program somehow has locked it. Normally at the bottom right near the time you will have the touch pad application running. Just scroll your mouse pointer over each icon near the time and it will tell you what the application is. If you find the touchpad app open it and reset everything to Default. Another way to find your touchpad app is to click Start/Control Panel then look for the Mouse Application. Open it, that's the touchpad. Set everything back to default. If the problem still is not resolved I would click Start/Control Panel/ System and look for device manager. Under device manger look for the mouse and other pointing devices. If it has a + beside it, click the + to expand it to see what is under it. Right Click on the items under it and click properties. Properties will allow you to see if the device is working properly and you can also update the driver just in case it is missing or corrupt. If all the above fails, then your touchpad probably needs to be replaced. Sometimes it could be something as simple as the touchpad cable has come aloose. Try your local repair shop and get a quote, then try these guys at: http://www.generalsystemsconsulting.com They will repair it and ship it back to you by Fedex or UPS. Their prices are probably better than any quote you find including the shipping.
    Mar 14, 2012 | Toshiba Computers & Internet
    Hp probook 5520 mouse pad is locked. The keyboard and mouse buttons are working but the touchpad is locked. how do i unlock it?
    there would be a small button right beside the touch pad LED. press the button and LED will turn to white or green and your touch pad is unlocked. pls rate the slolution however you find this....
    ....thanks...may
    Jul 12, 2011 | Computers & Internet
    My touchpad on my toshiba nb305 isnt working at all, i've tried pressinf fn+f9 but it still wont work.
    Hi plz uninstall & reinstall the driver. After all it is not working, it should be the problem with Touch Pad. Need to replace...
    May 17, 2011 | Computers & Internet
    My dell inspiron 6400 touchpad scroll not warking with window 7 ultimate
    Try going to Control Panel - Hardware and sound - mouse. Once you have the menu for the mouse open, go to device settings. Click settings, and all of the advanced controls for the functions of your mouse pad can be found there.
    Mar 12, 2011 | Dell Inspiron 6400 Notebook
    The mouse touchpad,stopped working and now the mouse usb,has stopped working.
    please chaeck the mouse pad lock mode or any light is glowing on top of the mouse touch pad?
    Sep 05, 2010 | Computers & Internet
    Touch pad refuses to work
    Try going to Toshiba's support page and re-install the driver for the touchpad. If this does not work. You may need to replace the touchpad itself.
    Apr 16, 2009 | Toshiba Satellite A135-S2386 Notebook
    Toshiba Laptop Satellite A15-S157 Mouse Cursor stuck in one place(Locked)
    To get enable or disable the Touch Pad you have to pulse the Fn + F9
    You can also set this function as follow:
    Start >> Control Panel >> Printers and other hardware
    Click Mouse >> Touchpad (enable or disable)
    Oct 27, 2008 | Toshiba Satellite A15-S157 Notebook
    Touch Pad Mouse not working unable to trouble shoot or properties for touch pad device to enable help please
    Connect and external mouse, then go to Toshiba website and download the touchpad driver for your laptop and reinstall them again.
    Oct 10, 2008 | Toshiba Tecra 9000 Notebook
    I need to disable touch pad and use a usb mouse
    Disabling touchpad for toshiba laptop is easy. Press FN and F9 simultaneously. Touchpad will stop working.
    Sep 26, 2008 | Toshiba Satellite Pro 4600 Notebook
    Computers & Internet Logo
    193 people viewed this question
    David Payne
    David Payne
