Question about Kenmore 20.3 cu. ft. / 575 liter Upright Freezer 23024
Unit has been un-plugged for about a year, I plugged it in today it started right up and was cooling fine, it made a snap and the blower and compressor both quit running. The inside and door lights are still operating. Any help would help.
  • 316 Answers
Just in case, leave it plugged in for another 60 minutes, its quite possible it went into the defrost cycle, in which case no motors will run. If it continues to remain silent, re post your problem.
Posted on Sep 30, 2010
  • ohiofatboy48 Oct 01, 2010
    You were correct the unit restarted about 30 minutes later and has been cooling fine, it fact since it restarted it has dropped internal temperature 35 degrees in 25 minutes.
Frigidaire ffhi7f7hw stopped working, the controls are not respomding, the display reads "OF" seal is okay freezer is level, and the compressor wont kick in, this unit is only six and a half years old
Start by unplugging and cleaning it gets dusty of course then they cant circulate air, also if your freezer has too much stuff the air cant circulate an they sometimes over heat, did you notice it running all the time before it quit, was the temp good need more details after you first clean the bottom andunder neath, un plug first hope this helps
Apr 04, 2016 | Frigidaire Freezers
Frigidaire upright freezer
If your freezer is a frost free, then it has probably stopped in a defrost cycle. The defrost timer is in the back lower left side of the unit, it has a little nub in the center on one side, if you can turn it clockwise and the unit comes on, you will need to replace the timer part #297318010
Oct 21, 2017 | Freezers
I have to push on my freezer door to keep the blower running
there is a loose connection at the rear of the freezer near or around the compressor unit , i strongly advise you to get a professional to look it.
Regards
Dec 16, 2012 | Haier Freezer HUF168PA 16.8 Cu. Ft....
Vulcan 300 chest freezer has been in storage for a few years! i plugged it in & all seems to be working fine, but alarm light is on & it is not cooling
the compressor can freeze(as in seize up not cold) when in storage for a while. it is always best to run the unit every now and then as the oil for the compressor is self contained and only works when running
Mar 12, 2012 | Freezers
My chest style freezer will not cool. This unit operated without issue for several years. We moved to a new house and did not want/need to use the unit for a year or so. When I plug it in I can hear a...
its the ptc overload relay on the side of the compressor body,it aids in starting the compressor by momentarily putting your start and run windings in parallel to overcome" locked rotor current",then drops out start windings after unit has come up to operating speed,it also protects the windings if the compressor cant start,they simply unplug off the compressor and the replacement plugs in the same,replace the capacitor connected to this if applicable as this protects the ptc's overload relay contacts
Mar 22, 2011 | Frigidaire FFN15M5H Chest Freezer
I have a woods freezer model # V17NAB I defrosted it and after all cleaned ou I plugged it back in. The compressor kicked on but shut back off about 30 Seconds later and will not stay running. It turns...
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Nov 22, 2010 | Woods Freezers
Yesterday, my dad brought me a working GE upright freezer from his house, transport time about 45 minutes. The freezer was working fine before he left his house, he did tip it little bit to load, unload...
You should try to un-plug the freezer and let it stand up-right over night to re-settle the freon back down inside of the compressor.
The compressor should normally get hot if it is doing it's job right, and there is a starter for the compressor motor (usually it looks like a large capacitor) that could have failed, or the defrost timer (if it has one) could be stuck, and you should be able to see the small dial on the defrost timer slowly turning, and if it does not turn, then replace the defrost timer.
Jun 07, 2010 | GE 13.7 cu. ft. General Electric Upright...
Fridge wont cool but frezer is fine
looks like you have a problem with the damper control. try to locate the sensor for the damper control and relocate it, if still not cold, replace it.
May 04, 2009 | Freezers
13 months old Kenmore compressor very hot.
lacdoi,
huuum At your service!
You said,
The warranty just ran out, Sears came out told me needs a control board ($210 for just labor to replace) not sure about part price. I though a new freezer is about twice his labor and parts, so I sent him away minus $65.
I did some troubleshooting today, pull the plug for 2 days. Plug it in, temp alarm goes on all the time. Turn alarm off, left the freezer running for 4hrs.
Not cold at all, some cool air. Fan is on, compressor is on (can hear humming noise and is vibrating). Compressor is very hot to the touch, could burn finger.
Should I call Sears again, wonder how much to fix all the problem? Or just give up, look for another brand new one (not Kenmore).
MY ADVICE:
Sounds like a big repair bill and multiple problems
How old is the appliance?
If the appliance is 10 years old or more you may not be advisable to put good money into bad!
New appliance are so much more efficient today that they can save you a lot of money in energy!!!!
Replace it.
You will be fine
Bless You huuum
Please give me the best rating for my fine advice before you sign off.
Thank you
Sep 17, 2008 | Kenmore 20.3 cu. ft. / 575 liter Upright...
UNIT NOT COOLING(IS RUNNING WHEN PLUGGED)
only reason refrigerent may be needed is that there is a leak so adding more will achieve nothing. unlikely to be needed. i assume compressor is running. probable causes of no cooling are compressor fault or a blockage in the pipe sysyem. not diy
Jun 30, 2007 | Avanti 1.4 cu. ft. Chest Freezer...
Kenmore 20.3 cu. ft. / 575 liter Upright Freezer 23024 Logo
252 people viewed this question
Top Kenmore Freezers Experts
Charles T Nevin
Charles T Nevin
AJMAL KHAN
christian nielsen
Are you a Kenmore Freezer Expert? Answer questions, earn points and help others
