Question about Toshiba P205-S6267 Notebook
Problem p205 s6567 Replaced the Lcd screen and the inverter because of this problem and it still exists. Turn the computer on and the screen works great, after about three minutes it starts to get darker and darker and then goes blank. Please help
freddygon66
  • 93 Answers
SOURCE: my toshiba m35x-s111 laptop screen goes blank
According to the description of the fault and the symptoms that your equipment presents, you must replace the FL inverter, that is the one that gives the turn on of the screen of your equipment, if your you replace this piece that one finds behind of the mask of the screen in the low part and that is similar to a pen I assure you that your equipment it was working in perfect conditions
Posted on Jan 09, 2009
  • 526 Answers
SOURCE: my t41 ibm thinkpad screen
could it be a screen saver, or the unit is going into hibernation.
Posted on Apr 15, 2009
  • 83 Answers
SOURCE: I have a Toshiba Satellite p205 s7402. The Lcd
sounds like backlight bulbs, not easily replaced pretty much gotta send to manufacturer to replace them. The inverter may be failing but because you still get one is why i believe its the bulbs themselves
Posted on Jan 04, 2010
  • 226 Answers
SOURCE: lcd blanks out
It's the inverter. Part no. UA2031P01. Happens a lot with this model inverter and 13" / 14" screens. My guess is that there's some mild oxidation to both connectors of the inverter board, and if you can plug/unplug the cables on both ends (power/signal cable on the left, lcd backlight cable on the right) a dozen times or so, that oughta solve it.
Posted on Apr 05, 2010
n5kb
  • 349 Answers
Yes, that is one possibility. It could be the cable from the motherboard to the display. Inverters are fairly common problem.
Posted on May 16, 2010
Toshiba Satellite P205-S6267 screen is blank but backlight is on and external monitor out works
Your LCD panel needs to be replaced more than likely. There are plenty of youtube videos if you are a DIYer, otherwise take it to your local computer shop and they should be able to fix it up within a day or two for 50-100 dollars plus the cost of the part. Good luck... you can find all your parts on ebay if you decide to go DIY
Mar 23, 2013 | Toshiba Satellite P205-S7402 Notebook
Broken screen on toshiba p205-6337
LCD screens and Inverters for your laptop maybe available from this WEB site.
www.lcdparts.net
Jul 06, 2012 | Toshiba Satellite P205-S6337 Notebook
Polaroid LCD tv - model TLX-04244b . Flashes the blue polaroid screen then goes black ,I hear a buzz coming from the inverter board. I have replaced both inverter boards and the same problems exisis .
I just changed out the invertor boards and mine was fixed. I had the same problem. Im not a TV repair man but replace the board thats buzzing and it will work again.
Jun 23, 2012 | Polaroid 4226TLMB 42 in. LCD TV
My lenovo LCD screen is flickering black and striped lines, how to get it fixed in Richmond Hill Ontario
Laptop computers have LCD displays that are sensitive to many things. LCD displays have faults that sometimes produce a flickering screen, lines, dots or a faint display. These screens are sensitive to magnetic fields or electronic items near the computer. Speakers, cell phones, lights and other electrical items are examples. Your display also could be flickering due to software issues such as the video drivers or hardware issues relating to the inverter going bad or the LCD screen itself needing to be replaced. Trace the cause of your problem to come to a resolution.
1.Turn off the computer. Disconnect all external devices. Turn the computer over (bottom facing up). Take out the battery and reseat it. Turn the computer on.
2.Reset your resolution and refresh rate.
Windows XP:
Right click an open area on your desktop. Click "Properties" in the drop-down menu.
Click the "Advanced" button at the bottom of settings tab. Another dialog box appears. Click the "Monitor" tab. Change the Refresh rate to your default, or 60 hertz. Click "OK."
Windows Vista:
Click "Start, Control Panel." Find and click "Appearance and Personalization." Click "Adjust Screen Resolution." Change resolution to the default, or 800 x 600. Click "Advanced Settings." Click the "Monitor" tab. Change the refresh rate to the default, or 60 hertz. Click "OK."
Windows 7:
Click "Start, Control Panel." Find and click "Display" Click "Change display settings" on the left side. Change screen resolution to 800 x 600. Click "Advanced Settings" in the lower right. Click the "Monitor" tab. Change the refresh rate to 60 hertz. Click "OK."
3.Check the computer's surroundings. Move away any speakers, fluorescent lights, fans, cell phones, radios and any other electrical device that can cause flickering. Temporarily move electrical items away from the computer to see if they are producing this issue.
If the flicker stops, put back one item at a time to determine what is causing the problem.
4.Connect an external monitor to your laptop computer to see if that screen is also flickering. If there is no flicker, then the problem is strictly with the laptop, indicating a possible hardware failure. Contact the manufacturer for a replacement LCD.
If the flicker continues, go to next step.
5.Reset/Update your video driver. Click "Start" and right-click "My Computer." Click "Properties." The "System Properties" dialog box will appear.
6.Click "Device Manager." A list of items will appear. Click the (+) sign next to "Display Adapters."
7.Right-click the video adapter and click "Uninstall." Confirm removal. Restart the computer. The video driver will automatically reinstall itself.
8.Check to see if the flicker still exists. If so, go to the manufacturer's website. Download and install the newest video driver and BIOS for the computer.
9.Restart computer once drivers are installed. Continue to the next step if there is still flickering.
10.Open up your display screen all the way. If the flicker stops by opening it a certain distance, it is the display inverter. If the flicker still exists, the LCD screen should be replaced.
11.Contact the manufacturer of the computer for more information and a possible replacement inverter and LCD display. This will depend on the manufacturer and the computer itself.
I hope you find it very helpful. Thanks
Sep 05, 2011 | Lenovo 3000 N200 Notebook
My hp laptop turns on bt the screen will not come on how can i fix it
As per your description, there are two possible causes. Either the LCD is out of order and needs to be replaced, or that the inverter is defective.
The inverter is a electrical device which 'lits' the LCD. Without the inverter and the bulbs it powers, the screen would be too faint to be seen.
To test if the inverter is defective, just turn on your laptop in a dark space, then put a flashlight on the screen to see if you have a fainted display. If you can see something, it is the inverter which is defective and should be replaced.
If you are handy, you can also remove the screen cover to see if there is a neon like light which lits up behind the LCD. If you can see the light, it means that the inverter is just working fine and that the is with the LCD itself.
Picture of an inverter.
Replacing the inverter:
1. After removing the screen 'cover', locate a small circuit board (usually below the LCD). Unplug the electrical cables and replace.
In case the inverter is working correctly, try to check the LCD cables. If all cables are well connected, your LCD has to be replaced.
Hope this posts helps you.
May 09, 2011 | HP Computers & Internet
Hp dv1000 laptop, just replaced lcd inverter, still no back light. You can see the screen is working just no back light. The led is on on the inverter.
You need to verify that you do have 9~12vdc feeding the inverter board. Did you see the backlight turn on for a second? Worst case will be bad lamp.
Jan 12, 2010 | HP Pavilion F1703 17" LCD Monitor
I have a Toshiba Satellite p205 s7402. The Lcd backlight quit working suddenly while in use. when you first power it on it briefly (2to 3 seconds) and partially turns on(only one corner) I am not sure how...
Jan 04, 2010 | Toshiba Satellite P205-S7402 Notebook
The screen on my Toshiba satellite p205 went dark on me i check and u can see the window but really dark i replace the lcd screen and the problem persist help please what can the problem be my video...
To determine if the video card or the LCD is faulty, connect an external monitor to your laptop and power the monitor up first then the laptop, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight. Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight. It could be a faulty inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out; usually the CCFL lamp fails before the inverter.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out LCD Parts for service, parts, and DIY info Use this link to their WEB site: -
www.ladparts.net
Nov 24, 2009 | Toshiba Satellite P205-S7806 Laptop
Was inputing information into my laptop and it all of the sudden went dark. There is still power to the screen as I can see the mouse pointer. When I boot up, I can get to the safe mode screen, and no...
if you only have a dark screen then it is typically a problem with the fl inverter. they run about 10-20 dollars. if thats not the case then it is an issue with the lcd
Nov 03, 2009 | Toshiba Satellite P205-S8811 Notebook
Toshiba LCD screen spazzing out
its probably the lcd inverter, which is the little board inside the display panel. You can easily replace it. Its simple and cheap, and you should not have a problem finding the parts
Feb 07, 2009 | E-Machines M2350 Notebook
Toshiba P205-S6267 Notebook Logo
54 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
